Old October 8th, 2017, 10:04 AM   #1
Jalequin
Motorcycle(s): 2011 Ninja 250
Question Can I use this coolant to top off?
Can I use this coolant to top off to the full line without flushing the whole system?
It's a 2011 250.
I've been reading conflicting info that you can never mix any coolant, or can only never mix colors and that mixing same color/different brands is fine. The linked one reads that its compatible with everything because of a "Cor-Guard" thing.
I already bought that gallon because it says it can be mixed. However I don't fully trust it so I'm asking here if it really is ok to use this to top off- has anyone used this one specifically or is the mixing an absolutely no-go.
Jalequin is offline   Reply With Quote
Old October 8th, 2017, 10:29 AM   #2
Your question is best answered by asking what type of coolant is currently in your bike? If it is the normal green ethylene glycol coolant, then you are just fine mixing or "topping off" with this premix, sometimes even if the color doesn't match. The color comes from the different mix of additives put into the coolant.
Ultimately, even if you make a mistake and mix the different types of coolants, even with a near 50% mix of types, all that happens is it becomes less effective (normal street usage) and the life of the coolant is compromised. You will know... just run the bike close to home in case you have to do a flush and fill. If you are running the bike on track... then the safer bet is to assume it will not cool properly.
Worst case of coolant mix I have seen is, the two coolants mixed together formed a very thin type of gel (like hot maple syrup from McDonald's). But even this... still cooled the bike normally. It was just a pain in the arse to flush. We ended up just running the bike with a water hose stuck to the radiator and the coolant drain bolt out to flush. Took forever. :\
Old October 8th, 2017, 10:34 AM   #3
Being that you're in Florida, if your coolant is currently a 50-50 mix, you can top off with water. If you wonder about the coolant concentration, you can get a hydrometer at an auto parts store and check it.
Old October 8th, 2017, 04:14 PM   #4
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Your in florida, top off with Distilled water.
TEAM ALFALFA
www.apexassassins.com
Old October 8th, 2017, 08:01 PM   #5
Colour is non-related dye and varies by manufacturer. Never use it as an indicator of anything. Different formulations came about due to different water available around the world.
Mostly you can mix stuffs except for Dexcool. That stuff is unstable and never lived up to its billing as 100k-mile coolant. In fact, even by itself, it will coagulate into gelatinous goo that'll clog your radiator and lock up your entire cooling system. Will do it even faster if mixed with other types of coolant.
Dexcool was major contributor to GM's bankruptcy, having already paid out +50-million in damages and repair payments with many hundreds of millions more in queue at court.
Old October 8th, 2017, 08:06 PM   #6
Jim's right on. Never assuming anything without sufficient supporting data. Measure and test to come up with concrete numbers.
Old October 8th, 2017, 09:58 PM   #7
Billy Bob, back around the early '80s a good friend bought a 1970 Cowl Induction Chevelle with a 427 (not stock) and a Muncie M21. It ran really well. The first or second night he had it, it got down in the 20s, and the next day we discovered the block was ruined. There were cracks everywhere, outside and in the vally. I guess the previous owner kept it in a warm garage. Too bad he didn't mention that to my friend. Anyway, that's why I check unknown coolant concentration before the cold season starts.
Old October 9th, 2017, 03:22 PM   #8
The other thing with coolant; a healthy engine doesn't treat coolant like a consumption fluid. If you're low on coolant, it's a good idea to attempt to figure out why.
-Do an oil change and see if the oil is milky and thick with coolant emulsified into it.
-Send the oil sample to an oil lab; does it have potassium and sodium in it in levels that are beyond normal?
-Open the radiator cap to check for oily coolant because a leak can go both ways.
-When the bike is hot, take a (cautious) whiff of the exhaust; does it have a sweet smell and/or does it appear to have a white steamy/smokey look to it?
Quick checks like that can be cheap insurance for your sanity.
Top Hose Coolant Reservoir Missing aurbz 2008 - 2012 Ninja 250R Tech Talk 2 March 14th, 2015 02:40 PM
Coolant SafetyPaws 2008 - 2012 Ninja 250R Tech Talk 33 May 17th, 2013 05:46 AM
Coolant leaking from the top of the engine... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 9 April 16th, 2013 06:56 PM
Coolant top up RAMN 2008 - 2012 Ninja 250R Tech Talk 19 August 17th, 2011 04:26 AM
Is OEM PRO-Honda HP coolant okay to use and top off? SF-Dug 2008 - 2012 Ninja 250R Tech Talk 4 October 28th, 2009 08:20 PM
