Old January 9th, 2011, 04:17 PM   #1
GeneJunkie
GeneJunkie's Avatar
Whine/squeak from front wheel
Recently I am having this whine/squeal/squeak coming from the front wheel. It starting happening after I unfortunately had to ride in the rain. I think it starts at +5mph and I probably stop hearing it over 35mph probably because the wheel is going so fast. I can hear it when I pull in the clutch as well as when the clutch is engaged. It also continues through braking with both brakes, as well as using either the front or rear.
At first my fiancé thought it was the chain and complained that I never wash my bike, so I cleaned my entire bike and cleaned and lubed the chain. After having a clean bike, I hop on for a ride, and the whine is still happening. It is not the normal ninja tank whine, I know that sound well.
After complaining for about a week, Ryan went for a ride on my bike and took a video... it's currently being uploaded and won't be up for a few hours. He said he heard it and we put the bike up in stands. We can't reproduce the whine when it is on the stands. We even turned on the bike and went through 1st and 2nd gear and still no whine, so we determined it's from the front wheel and it isn't the chain or the rear brake. We can't spin the front wheel fast enough to get to the "whine speed."
I really dislike riding my bike with this sound, so is there anything else I can do at home to further diagnose this or do I need to bring my bike into a shop?
I will update this when I get the movie online.
GeneJunkie is offline   Reply With Quote
Old January 9th, 2011, 04:28 PM   #2
bob706
bob706's Avatar
oil the speedo gear
Old January 9th, 2011, 05:13 PM   #3
GeneJunkie
GeneJunkie's Avatar
What kind of oil/lube should I use? Also is there an easy way to do it without taking the whole wheel and assembly off?
Old January 9th, 2011, 05:16 PM   #4
Hi Cindy - some links and info up in our wiki:
http://www.ninjette.org/wiki/My_Bike...ont_Tire/wheel
Old January 9th, 2011, 05:29 PM   #5
GeneJunkie
GeneJunkie's Avatar
here's the vid.
http://contour.com/stories/127267
Old January 9th, 2011, 05:35 PM   #6
ztrack157
The Sportisi Master
ztrack157's Avatar
Just sounds like normal brake drag on the rotor to me.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old January 9th, 2011, 05:36 PM   #7
GeneJunkie
GeneJunkie's Avatar
If it were brake drag it wold go away when I mash on the front break, which it doesn't.
Old January 9th, 2011, 06:04 PM   #8
GeneJunkie
GeneJunkie's Avatar
Yaay thanks Alex and Sean! Some WD 40 at the speedo gear did the trick. I always check the ninjette wiki first, I don't know why I missed this one.
Old January 9th, 2011, 08:52 PM   #9
Glad you tracked it down. The WD40 is pretty light, so the squeak may come back. Some chain lube in the same place might last longer if it does happen to come back.
Old January 9th, 2011, 09:17 PM   #10
bob706
bob706's Avatar
I used some motor oil on the speedo once...two years ago
Old January 9th, 2011, 11:46 PM   #11
acadiantheone
Motorcycle(s): 09 NiNjA 250R
Can you tell me where is the speedo gear located on the 09 ninja 250r?
acadiantheone is offline   Reply With Quote
Old January 10th, 2011, 12:41 AM   #12
GeneJunkie
GeneJunkie's Avatar
Sitting on the bike its on the left side on the front between the wheel and the fork. You will see a cable running to it.
Old January 10th, 2011, 01:32 AM   #13
Old January 10th, 2011, 05:40 AM   #14
dubojr1
dubojr1's Avatar
I've replaced the speedo on a friends bike I believe due to this same issue. He had been telling me that he had a squeak coming from the front wheel and ultimately the gear on the inside seized and failed. You could see factory grease on the inside of the speedo gear. I know it's no fun but I'd suggest disassembling the front tire axle/speedo assembly and either re-grease or clean factory grease out then re-grease.
Old January 10th, 2011, 03:16 PM   #15
GeneJunkie
GeneJunkie's Avatar
I was planning on doing that if/when the squeak returns.
Fix for front wheel squeak noise/Front wheel removal cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 13 April 23rd, 2014 12:25 PM
250 ninja front wheel and 300 ninja front wheel JasonG134 2013 - 2017 Ninja 300 Tech Talk 2 March 30th, 2014 09:12 PM
wheel makes a squeak Old Lemon 2008 - 2012 Ninja 250R Tech Talk 8 November 22nd, 2013 12:09 PM
Front Wheel Squeak - Solved klewi 2008 - 2012 Ninja 250R Tech Talk 8 May 29th, 2011 01:50 PM
Help. When I accelerate, I get squeak from front poo poo 2008 - 2012 Ninja 250R Tech Talk 4 November 9th, 2010 03:28 PM
