Old October 1st, 2014, 07:39 PM   #1
Qomomoko
Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4
Slip-on rivets on 93 Ninja 250 came off..
As video shows, the rivets finally came off. They had been loose since I got the bike.
I tape part of the exhaust in heat wrap so it wont melt ma boot.
Not sure how rivets work in this case ( just put them in with pressure)?
or
should I weld the slip-on?
or...
video link..
http://youtu.be/3UKcvUJF8CM
Qomomoko is offline   Reply With Quote
Old October 1st, 2014, 08:17 PM   #2
Kevin1956
Kevin1956's Avatar
Buy or borrow a pop-rivet tool and fix it. Steel or aluminum rivets are available, but I suggest the steel. This animation shows how the tool works. http://www.technologystudent.com/images2/popriv3.gif
Kevin1956 is offline   Reply With Quote
Old October 2nd, 2014, 03:47 AM   #3
Qomomoko
sweet! thanks.. why you prefer steel rivets?
Old October 2nd, 2014, 05:12 AM   #4
Kevin1956
Kevin1956's Avatar
Steel is stronger. They come in various size. Try a 1/8" rivet for fit. If it fits loosely in the existing holes, drill the holes to 3/16" and use a 3/16" rivet. You want them to fit snuggly so they don't pull clear through the metal.
Old October 2nd, 2014, 10:34 AM   #5
Qomomoko
Perfect.. got the right size!! thanks.. the ex owner/shop had put wrong rivet sizes tisk tisk tisk....
Thanks man...
Old October 2nd, 2014, 10:42 AM   #6
buy the highest quality rivets you can get. but just get that cheap $10 rivet gun from HF.
Looking for slip on pipes for 07 ninja 250 james250ninja Items Wanted 0 October 7th, 2013 11:51 AM
Yoshimura TRC Slip-On for Ninja 250 Bones85 Motorcycle-related 2 February 9th, 2013 12:21 AM
Ninja 250 after market exhausts or slip ons? Sungfooo 2008 - 2012 Ninja 250R Tech Talk 9 July 2nd, 2011 07:45 PM
1988 - 2007 Ninja 250 Two Brother's Slip-On's SV_Hadder Motorcycle-related 1 January 29th, 2011 08:04 AM
WTB: yoshimura slip-on exhaust for 08+ ninja 250 theAei Items Wanted 0 May 6th, 2010 04:28 PM
