September 4th, 2013, 12:17 PM | #1 |
Join Date: Sep 2012 Motorcycle(s): 2008 Ninja 250R Posts: 149
5 Action Cams - Where to mount them?
I have 5 action cams, im wondering where the best place to mount them will be?
I was thinking. 1- helmet 2 3 4- another bike pointing in my direction in front of me 5 - another bike pointing in my direction behind me should i even think about a 6th or 7th camera spot? what would be your ultimate camera mount setup? |
September 4th, 2013, 12:22 PM | #2 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
1. Helmet facing forward: Mounted top or side
2. Butt cam facing you: Mounted on the rear cowl 3. Left side facing rear: Mounted on the passenger peg 4. Right side facing forward: Mounted on the front right fairing so the front wheel is in view 5. Handlebar/front cowl facing you: Mounted so it captures your face and one of your hands. A remote mic mounted near the exhaust maybe in a pocket of clean air underneath the tail to pick up exhaust sounds. This is what I would do if I could afford 5 gopros. Some other mounting locations: - Tank facing forward: Gets the instrument cluster, view through the windscreen. - Left rear set facing forward: Gets your foot when you shift - Front fairing facing aft: Gets your knee when drag it |
September 4th, 2013, 12:29 PM | #3 |
so what you are saying i should get 3 more
September 4th, 2013, 12:31 PM | #4 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar Posts: A lot.
I like the way you guys think.
September 4th, 2013, 12:48 PM | #5 |
not an actual panda
hahah...i don't know if you want to have 8 cams on your bike. I imagine that'd be a disaster to edit, sync, and batteries would be crazy.
They're just suggestions for other mounting locations though. For other mounts if you get two cameras facing 180 degrees away from each other. If you put them on the ground near the apex of a corner you can get a cool clips of you approaching the apex then a quick cut of you as you head away. It looks pretty bad ass. EDIT: You should also talk to @urbaninja. He works in the film business and he has a ton of cool ideas for mounting locations. I think I actually stole all my ideas from him. |
September 4th, 2013, 12:52 PM | #6 |
Certified looney toon
MOTM Jul '13, Jul '14
oh, I'm going to have to borrow that idea. I have two forward mounts right under my turn signals and a rear mount behind the passenger peg.
September 4th, 2013, 12:56 PM | #7 |
dirty boy
MOTM - Apr '14
no A** shots, that is the last thing I want to see in a motorcycle vid is close-up of some guys sweaty *** in tight leathers.
If you are a hot chick...rock on
September 4th, 2013, 01:21 PM | #8 |
MOTM - Jan '18, Sep '13
Put a camera on the end of a 5ft. pole behind you so you can get an aerial view of you riding
September 4th, 2013, 01:40 PM | #10 |
Heh, that's pretty cool other than the lack of stability. The shakiness is a bit headache inducing.
September 4th, 2013, 01:50 PM | #11 |
it was shakey because it was literally a pvc pipe. watching that thing snap when kevin did an up-hill wheelie was seriously priceless. IIRC it is still on the side of GMR if you want to go get it.
September 5th, 2013, 01:27 AM | #12 |
Present. Somewhat.
Join Date: Sep 2012 Motorcycle(s): 2012 KTM Duke 200, 2011 Ninja 250r, 2011 Ducati Monster 796, 2014 Kawasaki ZX10r Posts: 227
Something on the swingarm to show that back tyre's contact patch in a corner?
Highest speed on two wheels- 230 km/h Beat that. |
September 5th, 2013, 09:27 AM | #13 |
Your face
Join Date: Jul 2013 Motorcycle(s): 2014 Honda CBR650f Posts: A lot.
Definitely either have someone follow you with a camera facing you. Unless you don't have another rider to do that, put a butt-cam on the rear seat. I'm a big fan of that angle when riders be draggin knee
September 5th, 2013, 09:37 AM | #14 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Haha makes him an the bike look tiny, like a circus monkey on a pocket rocket or somethin. That helmet is sweet
September 6th, 2013, 01:19 AM | #15 |
Join Date: Feb 2013 Motorcycle(s): 1999 Ninja 250ex 1989 Ninja 250ex 2005 Ninja 250ex 2007 Ninja 250ex 2011 Ninja 250r 1993 CBR600 Posts: 199
Side of Helmet
Camera on Front Fairing Facing you. (You Get to see Throttle Brake Hand plus you plus a bit behind you Rear Facing Camera that still catches some part of your bike. like the Wheel or Tail Then Give 2 to people around you. This is the result
"I had so much fun crashing my Ninja" - Said by No One Ever |
How to identify cams? | Zombarian | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 19th, 2014 01:06 AM |
Raw Video Footage from Action Cams | Maielstrom | General Motorcycling Discussion | 12 | January 17th, 2014 04:35 PM |
Web Cams (performance) | mgentz | 2008 - 2012 Ninja 250R Tech Talk | 6 | December 1st, 2012 08:53 AM |
Cheap <$50 helmet cams? | JoeLansing | General Motorcycling Discussion | 12 | August 13th, 2011 10:52 AM |
Motorcycle helmets cams | gogiburn | General Motorcycling Discussion | 4 | July 20th, 2010 04:47 PM |
