Old July 9th, 2024, 07:06 PM   #1
Nbuck7
Motorcycle(s): 2008 Ninja 250
White smoke from exhaust+dying after a few seconds
Hey everyone,
After cleaning the carbs and adjusting floats, replacing head gasket and adjusting valves, my 2008 Ninja 250 was finally starting and running fairly well. I had taken it for a 5-minute drive around the neighborhood and it was doing pretty good, idling strong and going fast. Then when I came to a stop it died and I couldn't get it to run after that. It would start up, idle for a couple seconds, then die. Maybe engine is getting flooded with gas somehow?
In addition to this, white smoke is coming from the exhaust. This is why I had replaced the head gasket, although when I took the engine apart the gasket was fully intact.
Any ideas?
Thanks.
Nbuck7 is offline   Reply With Quote
Old July 10th, 2024, 04:57 AM   #2
What's the crankcase oil look like?
Old July 11th, 2024, 09:02 AM   #3
Nbuck7
Just drained some oil out and it smells like gas. Also the oil level has risen significantly. Confirms that suspicion. Can anything other than malfunctioning float valves cause too much gas to go into cylinders?
Old July 11th, 2024, 11:11 AM   #4
It takes two things to get fuel into the crankcase when the engine is not running:
1. A leaking petcock
2. Leaking float valves
The tendency to stall when riding adds more evidence of leaking float valves.
I assume you looked at the oil and it's not milky like it would be if coolant were getting into it.
New Bike to me - White smoke from Exhaust. mikesomass 1986 - 2007 Ninja 250R Tech Talk 3 March 5th, 2018 11:02 AM
Ninja dying at idle / dying when throttle / trouble starting heatdeath 1986 - 2007 Ninja 250R Tech Talk 26 February 5th, 2018 07:47 AM
Broken screw causing Exhaust leak and white smoke joshjooh 1986 - 2007 Ninja 250R Tech Talk 15 September 9th, 2016 12:53 PM
white smoke from exhaust and stall kittyslasher 2008 - 2012 Ninja 250R Tech Talk 5 November 8th, 2013 11:21 AM
[kropotkin thinks...] - 2010 Brno WSS QP2 Result: Lascorz Takes Pole In Dying Seconds Ninjette Newsbot Motorcycling News 0 July 10th, 2010 08:40 AM
Except where otherwise noted, all site contents are Copyright 2022 ninjette.org, All rights reserved.
