September 22nd, 2009, 08:36 PM | #1 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
Permatex Copper Gasket Maker High Temp
Has anyone used this product to stop the leakage after installing a 2 bros slipon were the slip slides over the midpipe? What is the cleanest application of the gasket maker compound and just when/where do you use the clamp to ensure the leakage is stopped as well as the location of the application so it doesnt squish out all over the place and look like a true mess from the get go. Their website is not very clear on the application for slip ons at all.
September 23rd, 2009, 10:49 AM | #2 |
Join Date: Aug 2009 Motorcycle(s): 2008 Ninja 250R Posts: 98
Put the Permatex on the outer portion of the slip on tube in a thin even 3/4" wide ring so when the pipe is inserted it pushes the sealant away from the midpipe side. Do not over clamp..15 ft/lbs is enough..more and things distort. Let the pipe "cure" for 24 hrs. before getting her hot. A wet swipe with a rag when first put on will clean off any excess. Remember to clean both surfaces really well with acetone or brake cleaner and dry before applying sealant. A really clean surface makes all the difference for this stuff adhering well. Some people will scuff up the surface for better grip but not really necessary in this type of application....needed for mild steel exhausts on cars where the clearances are looser between pipes.
September 23rd, 2009, 12:49 PM | #3 | |
September 24th, 2009, 06:12 AM | #4 |
You got it...Good Luck. BTW, let me know if you are running the bike w/o rejetting with that slip-on and if so...just shimming the needles, snorkel in/out?
[motorcycle.com] - Fieldsheer High Temp Mesh Jacket & Pants Review | Ninjette Newsbot | Motorcycling News | 0 | September 25th, 2014 01:30 PM |
oil temp vs coolant temp | cuong-nutz | General Motorcycling Discussion | 11 | January 23rd, 2013 05:44 PM |
High temp spray paint coming off of my headers/pipes, what next? | Monkeytofu | 1986 - 2007 Ninja 250R Farkles | 24 | December 20th, 2012 06:27 PM |
copper head gasket | Racer x | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 13th, 2010 05:08 PM |
[tilted horizons] - New Record High Temp Ride! | Ninjette Newsbot | Motorcycling News | 0 | June 12th, 2008 01:11 PM |
