February 17th, 2011, 08:14 PM | #1 |
ModMy250.com
Pics of my installed koso speedo
If you guys want a DIY, I can write short one. Just let me know. The pics should pretty much speak for themselves tho.
The www.ModMy250.com guy |
February 17th, 2011, 09:12 PM | #2 |
Join Date: Jan 2011 Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r Posts: A lot.
Lookin good! The ocd side of me just kicked in though, is the gauge just a tad off center (to the left)?.
February 17th, 2011, 11:08 PM | #3 |
ModMy250.com
Yeah it is. I'm too lazy right now to redo it tho. I'm sure it will eventually bug me enough to make me spend the 10 minutes to remount it.
February 18th, 2011, 02:46 AM | #4 |
Join Date: Feb 2011 Motorcycle(s): 2010 Ninja 250R (for the weekend's) and the Suzuki Fiero for office commute. Posts: 80
Looks like you have a bigger windscreen to accommodate the digital guage. Wouldn't this fit neatly along with the stock windscreen in place? I'm having my eyes on this guage but will wait till my factory warranty period expires (only a year away).
February 18th, 2011, 05:42 AM | #5 |
I'd be interested to know too if the odometer's run together or if they clock the miles differently...
Keep us informed!!!
February 18th, 2011, 07:45 AM | #6 |
Join Date: Jul 2009 Motorcycle(s): Ninja 250r 09 SE Posts: 172
i'm interested in a howto
February 18th, 2011, 07:58 AM | #7 |
ModMy250.com
No way to use the factory windscreen with where I mounted it. There's barely enough clearance with the zg double bubble.
February 18th, 2011, 08:24 AM | #8 |
self wrencher
you have the stock speedo and the Koso speedo? why?
February 19th, 2011, 11:43 PM | #9 |
ModMy250.com
I didn't want to spend $400 on a gauge cluster, but wanted something to have better accuracy. I also want something I can remove easily if I sell the bike.
February 20th, 2011, 08:34 AM | #10 |
ninjaholic
Join Date: Jun 2010 Motorcycle(s): 09' SE 250R (sold), 03' ZX-6R, 99' XL1200C SP Posts: A lot.
What is the thing that I circled in red? Also, do they make a larger one that could replace our speedo?
09' SE Ninja 250R $2,547.83 worth of mods installed... come on Unregistered, you know you want to know what? Check my Blog "Modification List" |
February 20th, 2011, 10:20 AM | #11 |
self wrencher
that's the BRT-TIS
February 20th, 2011, 10:49 AM | #12 |
IC2(SW)
February 21st, 2011, 06:43 AM | #13 |
self wrencher
Since you're now has electronic speed signal, you can install the gear indicator?
speed signal = from Koso magnet/sensor tach signal = stock neutral signal = stock ground = stock 12v+ = stock |
February 21st, 2011, 09:15 AM | #14 |
ModMy250.com
I don't think I will. I don't really need a gear indicator. I did find the off center gauge to be annoying on the ride in today. I'll need to pull the windscreen off and re-adjust it. I think I may need to just use window weld on it to keep it in place. I saw that it was slightly leaned over and I think it's because the bike was sitting in the garage for a week. Gravity took it's course.
custom koso bezel installed | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 15 | November 7th, 2016 11:20 AM |
Koso Installed! | ForceofWill | 2008 - 2012 Ninja 250R Farkles | 12 | July 29th, 2014 10:30 AM |
Speedo Cable connector missing? Koso. | MrHungryMonkey | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 12th, 2014 08:33 PM |
KOSO Gauges/Speedo Warning | dubojr1 | General Motorcycling Discussion | 4 | October 7th, 2011 09:27 AM |
Koso RX-2 and WC Clipons [installed!] | NikkitaNinja | 2008 - 2012 Ninja 250R Farkles | 19 | September 12th, 2011 10:24 PM |
