Old June 16th, 2016, 06:30 PM   #1
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
Flashing ECU
Hey guys... While currently waiting for my bike for repairs, I think I have decided to add a few upgrades onto my bike.. However, due to the currency difference and the insane excise imposed on 250cc and above for accessories imported from oversea (it is considered as "luxury items". Taxes imposed are from 30% up to 100%).. So my first step is to flash ECU. Current speed recorded (as stated on odometer) was 170 km/h and RPM was 13.5K and the bike could not go any faster than that. Was thinking to flash the OEM ECU and was told that the bike could perform better and to add in HM Quickshifter.
Anyone done flashing their ECUs before? Any heads up on what to expect after doing that? Is it better to have a fuel controller unit rather than flashing the ECU?
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Old June 17th, 2016, 09:38 AM   #2
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
All the US EX250s are carbed, so they don't have ECUs. There's probably not going to be a ton of experience with that here...
An ECU is just a computer that tells the engine what to do. As long as the stock ECU is physically able to do what you want (the one in my truck can't support certain injectors without modding, for example), you can put the exact same programming into it that you have in an aftermarket ECU. Regardless of the computer's details, if it sends the same commands to the engine, the engine is going to behave exactly the same.
However, aftermarket ECUs are generally much more friendly to being reprogrammed. They're made for people to adjust them, and to support mods. They may have support for more fine-grained programming. The OEM ECU is designed to hold the factory programming, with a little bit of support for changing the programming by the manufacturer to address issues with the stock bike. If you can get your desired programming flashed into the stock ECU, it'll be fine. If you need finer control, extra features, or want to tweak your tuning, you'll probably need to switch to aftermarket.
Flashing an ECU is sort of like burning CDs. There's some technical knowledge involved in actually doing the process. But as the end-user, you're probably a lot more concerned about which songs were chosen to be burned onto the CD rather than which brand of burner was used to make the CD. The details of the program being put into the ECU are a lot more important to how your bike runs than which brand of ECU is holding the program. (But different brands of ECU may make it easier to get a good program running on your bike.)
ECU Flashing garth285 2013 - 2017 Ninja 300 Tech Talk 30 July 13th, 2015 11:47 AM
Dashboard flashing? arnoldc6 2008 - 2012 Ninja 250R Tech Talk 4 March 27th, 2013 05:55 AM
HELP PLEASE!!! Proton's now flashing on both sides b4idie 2008 - 2012 Ninja 250R Tech Talk 2 April 11th, 2012 02:30 AM
Help needed: Weird flashing rate chokne 2008 - 2012 Ninja 250R Farkles 8 June 28th, 2010 05:31 PM
Faster flashing signal randomwalk101 2008 - 2012 Ninja 250R Tech Talk 9 January 23rd, 2010 11:56 PM
