Old October 15th, 2013, 09:20 PM   #1
Insan3guy
Insan3guy's Avatar
Motorcycle(s): 2015 zx6r
Turn signals stopped working.
Pretty sure this is the right place for this. anyway...
I had a turn signal bulb go out on me. Left front. Went to change the bulb and the zipper on my sleeve touched the socket and there was a "bzzt" sound. Idiotic mistake to leave the turn signal ON while changing the bulb, I know.
Now the whole turn signal system doesn't work. Left, right, hazards, none. Tried changing the flasher relay but that didn't work. Haven't had a chance to get a multimeter on it yet. Fuses were checked, none were bad, but replaced them anyway.
I couldn't check the switch itself. The assembly is pretty tightly put together, and I couldn't get inside it.
Any ideas what the culprit could be? It's a fairly old bike, some of the electric bits look like they crawled out of frankenstein's lab.
Insan3guy is offline   Reply With Quote
Old October 15th, 2013, 10:17 PM   #2
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
If you shorted it out the fuse should have protected the switch and other electrical componets. I'd check the fuse again. If the fuse is OK then I would start checking for 12V power at each point from the fuse block to the bulb socket. That will show what is wrong.
greenaero is offline   Reply With Quote
no turn signals working kaosyin 2008 - 2012 Ninja 250R Tech Talk 3 January 29th, 2015 04:53 PM
Indicator Problem - Turn Signals Not Working alex192 2008 - 2012 Ninja 250R Tech Talk 6 December 7th, 2014 09:56 AM
Turn Signals not working correctly aspenratt07 1986 - 2007 Ninja 250R Tech Talk 5 April 1st, 2013 08:46 PM
turn light indicator stopped working... DaMan22 2008 - 2012 Ninja 250R Farkles 6 July 26th, 2012 07:52 PM
Turn Signals Stopped Working! DisciplesHeart 2008 - 2012 Ninja 250R Tech Talk 18 March 21st, 2012 08:45 PM
