February 26th, 2012, 02:45 PM | #1 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
brake light and signals not working :(
I just check the bulb and its find does any one have an idea y this is happening I dont hear anything on the turn signals(RELAY) but the brake light still works idk if this helps but Friday night i wheelied her for the 1st time that BIG in a strip by accident
THE GOOD LIFE |
February 26th, 2012, 03:21 PM | #2 |
Join Date: Oct 2011 Motorcycle(s): 2009 CBR600rr Posts: A lot.
So the brake light works, but the turn signals don't? Do they not flash at all? Both sides at once (like hazard lights)? Light up but don't flash?
February 26th, 2012, 07:00 PM | #3 |
cuz
The signal dont work at ALL & the brake light turns on when u turn the bike on but when i press the brake it doesn't light up
THE GOOD LIFE |
February 26th, 2012, 08:32 PM | #4 |
cuz
any ideas guys???
THE GOOD LIFE |
February 26th, 2012, 09:08 PM | #6 |
You probably popped a fuse...
February 27th, 2012, 06:37 AM | #7 |
Did you check the rear brake switch? If it is slightly askew or the spring is somehow off the lights would not work. Also if it is stuck the brake light may already be on and the tail light filament is burned out. You may have to inspect both both switches and all your connectors to isolate the problems.
March 1st, 2012, 08:41 AM | #8 |
cuz
all fuses are good can it be a relay ??
THE GOOD LIFE |
March 1st, 2012, 08:48 AM | #9 |
Its the tail light fuse under the front seat. When the tail light fuse blows, the signals also stop working. Even if the signal fuse is still good. There are extra fuses in the fuse box so just open it up, pull out the one marked "tail", and replace it. Should be good to go from there.
SOLD MY NINJETTE and got THIS |
March 1st, 2012, 08:57 AM | #10 |
Have you checked all the turn signal connectors, bulbs and relay?
What about the brake switches? If you say the bulbs and fuses are fine, these things are what's left to check. I'd double check the tail light bulb by replacing it with a new one, then make sure both filaments light up. |
March 1st, 2012, 12:23 PM | #11 | |
Join Date: Aug 2011 Motorcycle(s): RED 2010 Ninja 250r Posts: 304
goodluck |
March 1st, 2012, 04:51 PM | #12 | |
cuz
i could barely see the rip in it now the signals work but dont flash/click so im sure its the relay BUT still the brake light is not turning on
THE GOOD LIFE |
March 1st, 2012, 05:12 PM | #13 |
Okay, have you checked the connector going to the tail light under the rear seat?
Does the light come on when you turn the bike on, but not get brighter when you apply the brakes? Or vice-versa? If so, as someone said earlier, church that BOTH filaments are in tact in the bulb in the tail light. Sorry for any "swypos", I'm on my phone. Posted via Mobile Device |
March 1st, 2012, 06:06 PM | #14 |
cuz
unplug & pluged a few time now Does the light come on when you turn the bike on, but not get brighter when you apply the brakes? Or vice-versa? yes the light turn on just like normal but doesn't want to get brighter once i press the brake front&back If so, as someone said earlier, church that BOTH filaments are in tact in the bulb in the tail light. i dont see any type of rip or displacement in it Sorry for any "swypos", I'm on my phone. its cool dude thanks
THE GOOD LIFE |
March 1st, 2012, 06:12 PM | #15 | |
alrighty then, next thing would be to replace the bulb. Sometimes it can be very difficult to see if the filament is broken. Posted via Mobile Device |
March 1st, 2012, 06:20 PM | #16 |
cuz
yea i guess so to Auto Zone again replaced all the mini fuses
so for the not flashing signal lights(NON-LED) part is the relay?
THE GOOD LIFE |
August 28th, 2012, 07:52 PM | #17 |
Join Date: Aug 2012 Motorcycle(s): 2010 Harley Fat Boy Lo; 2005 Harley Custom Deluxe; 2011 Ducati 848 Evo; 2012 Ninja 250 Posts: 1
Tail Light Issues
If you checked the fuses and all are good. This may be helpful. I installed the Hotbodies undertail eliminator kit with the LEDs.
Once I hooked everthing up (black to black, green to red) the signal lights came on but did not flash. I checked fuses and relay. I bought two 8 ohm resistors from Radio Shack ($2.50 ea.) and hooked them up to each of the rear signals (black to black on one end and red to green on the other end). This solved my issue. All signal lights function properly. Good luck, JDIZON |
Horn and Brake Light not working | Daks | 1986 - 2007 Ninja 250R Tech Talk | 16 | September 7th, 2014 07:38 AM |
Tail Light + Brake Light Not Working (Bulb Replaced) | JayZE302 | 2008 - 2012 Ninja 250R Tech Talk | 11 | August 8th, 2012 05:03 PM |
LED's! (footpeg turn signals, brake light strips, front signals oh my!) | VeX | 2008 - 2012 Ninja 250R Farkles | 16 | June 29th, 2012 12:03 AM |
Brake light not working when I use the back brake? | ladyrocket | 2008 - 2012 Ninja 250R Tech Talk | 7 | November 9th, 2011 01:36 PM |
Front brake light not working, help please. | miks | 2008 - 2012 Ninja 250R Tech Talk | 20 | October 5th, 2010 08:01 PM |
