June 14th, 2012, 11:13 AM | #322 | |
In my humble opinion, there is no other dynamic force than what I have represented in my schematics. Bike not moving: Gross 50/50 weight distribution between rear and front. Bike moving at constant speed: Gyroscopic effect is the only dynamic moment. Gross 50/50 weight distribution between rear and front. Bike accelerating or braking: An acceleration or deceleration force appears (F=ma), which induces a pitch moment that upsets the gross 50/50 weight distribution between rear and front. Newton's second law of motion rules all that is happening (Gyroscopic effect increases or decreases, but it doesn't affect pitch or braking). Friction is static for a rolling tire, once the skid begins, the friction becomes dynamic (which is always a smaller force than the static friction). Copied from http://en.wikipedia.org/wiki/Newton's_laws_of_motion "Second law: The acceleration a of a body is parallel and directly proportional to the net force F and inversely proportional to the mass m, i.e., F = ma." Is OK that we disagree, but please remember that I only tried to grossly calculate what happened in this particular event. I just like calculating and testing better than just guessing, even if is not perfectly accurate. This thread explains some of the points that you and I have been discussing here: http://www.msgroup.org/forums/mtt/to...p?TOPIC_ID=980 Here are some real test numbers for some big cruisers, none above 1g (32.2 ft/s per each second): http://www.michigan.gov/documents/ms...s_182665_7.pdf
June 14th, 2012, 12:23 PM | #323 |
Jigglin' your Jiglets
MOTM - Apr '13
I must be very controversial O.o
It probably doesn't help that I spend too much time on the computer either
June 14th, 2012, 01:25 PM | #324 |
my hair matches my bike
Join Date: Apr 2011 Motorcycle(s): 2010 Red 250r Posts: 411
June 14th, 2012, 02:32 PM | #326 | |
http://www.bikesafer.com/detail/braketime.html http://www.promocycle.com/documentat...morfrein_e.pdf (the second is a good read for the no-rear-brake crowd.) they have measured results of average riders achieving over 1g of brake force. now this is a very tiny bit over 1g, but considering that you wont ever have a 1.0 coefficient of friction, there are other forces at play that allow you to achieve better braking that 1g. I agree with you on all other fronts, but there is more at play than basic physics. |
June 14th, 2012, 02:33 PM | #327 | |
Join Date: Apr 2012 Motorcycle(s): 2008 Kawi Ninja 250R, 2013 Honda CRF450R, 2008 Honda CRF250R, 2001 Honda XR400 Posts: 301
June 14th, 2012, 02:41 PM | #329 |
June 14th, 2012, 04:16 PM | #330 | ||
Join Date: Mar 2012 Motorcycle(s): '88 Hurricane 600, '09 Ninja 250 Posts: 237
To get into a stoppie on the 250 I have to "try" and make it happen. Intentionally grab the front bakes too hard too fast while letting ALL my weight transfer to my arms. I don't do that in a panic stop. What you can't see in a video is that, as far as weight transfer goes, when I panic stop I grab the tank a little with my knees while trying to keep my weight down on the seat and into the tank. And YES, during an actual panic stop if the "junk" isn't where it needs to be it can hurt like hell. Point being I do whatever I can to keep the CG as low and rearward as possible.
While no trees were harmed in making this post, a large number of electrons were severely inconvenienced. |
June 14th, 2012, 04:31 PM | #331 | |
Have to play around with that a little.
June 14th, 2012, 04:36 PM | #332 |
MOTM - Apr '13
I did a stoppie on the 250 with stock IRC tires.
June 14th, 2012, 04:42 PM | #333 |
Which pedal is the gas?
Join Date: Mar 2012 Motorcycle(s): '09 Ninja 250R SE Posts: 192
This really makes me want to practice panic braking more, just to see what I/the bike can do. I felt like I could push my stock IRCs to their limit but never felt like the rear was going to come up, I likely wasn't pushing them as hard as I could have. I want to try with my new sticky Rosso IIs.
In my "offroad excursion" I skidded the front (roadwinner) for an instant, but that was at a much higher speed than is being discussed here. I would really like to see what the new tires will do. My helmet-cam has a narrow angle so I will need to figure out a place to mount it on the tank/tree. |
June 14th, 2012, 05:08 PM | #334 |
If you braked hard enough to get the front tire squealing then where close to the limit. Like I said with my stock IRCs' I can do stoppies but I have to "want" to do stoppies.
If we are talkng about 15mph, grab a sh!tload of front brake stoppies they are a no brainer. But a 40mph, do a stoppie and ride the front wheel for 20 feet kinda thing you have to "make" it happen.
June 14th, 2012, 05:44 PM | #335 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 771
Post vid of said stoppie
June 14th, 2012, 06:01 PM | #336 |
Since my bike already has some broken plastics I will try to stoppie. I'm pretty heavy (250ish) so I have as many pounds as CCs but we'll see what happens. I will post a vid if I can pull it off.
June 14th, 2012, 06:07 PM | #337 |
Here's a guy doin' a couple........ Notice his ass is up off the seat. He's forcing his weight up on his arms to get it all over the front end.
http://www.youtube.com/watch?v=eKqk8LvD3mg You got what you asked for.
June 14th, 2012, 06:18 PM | #338 |
ಠ_ಠ
Join Date: May 2012 Motorcycle(s): current newbie stick is a loaner :P Posts: 257
a fast ride isn't necessarily a fun ride ;3 |
June 14th, 2012, 06:25 PM | #339 | |
They show the average reaction+braking distance for this specific case (close to 30 mph) to be 66 feet (61 feet with ABS), pretty close to the 67.1 feet calculated in post #296. The OP never had 66 feet to react and stop before colliding. From that first link: "You can only maintain peak emergency braking performance by taking the time to learn the skill, and by practicing it on a regular basis." From the second link: "RISKS ARISING FROM A LOCKED FRONT WHEEL Locking of the front wheel must be avoided at all costs during hard braking because it leads almost automatically to a loss of directional control and a sideways crash if it persists longer than a tenth of a second. Fear engendered by this physical reality means that the majority of motorcyclists under-utilize the capacity of their front brake, especially at the start of braking. Thus it is of paramount importance to become proficient at the start of braking because the distance traveled is relatively greater than at the end of braking. EFFECTS OF DECELERATION FORCE The mean deceleration for the group of 298 passes braking from 100 km/h to zero was -0.898 g in a mean time of 3.18 seconds. During these more than 3 seconds, the rider had to manage his braking while subjected to a considerable deceleration force against his arms and hands which must in large measure support his upper body. A simulator designed to recreate this force would have to incline the motorcycle on its front wheel at an angle of 64 degrees. THE EQUILIBRIUM STAGE Each emergency braking maneuver is preceded by a stage of stabilizing the motorcycle. Although it may be very short, it is no less important despite the fact that it is little covered in the literature. Even when the motorcycle gives the impression of rolling in a straight line, the rider makes constant adjustments to maintain equilibrium among different forces and the chosen trajectory. At the moment of emergency braking, this equilibrium must be perfect and be maintained for the length of the braking maneuver."
June 14th, 2012, 10:35 PM | #340 |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
@drac: I find that if I'm too snappy with the front brake, the front wheel will loose traction and skid. If I progressively apply it at a slower rate, it maintains traction and I stop quicker. Presumably those people who can do stoppies on the ninjette are applying the front brake smoothly and at just the right speed in order to keep the front tyre stuck to the ground while more and more rider+bike weight is transferred onto it.
June 16th, 2012, 06:24 AM | #341 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R SE GREEN! Posts: 562
Prove Keith Code and all of his racing experience, plus everyone else involved in the making of twist of the wrist, and his school with all the instructors who presumably believe the same thing wrong and then make your argument on how you can do it better
Trust me, I'm a banana! |
June 16th, 2012, 06:41 AM | #342 |
you cant test emergency braking with fixed objects at a known distance.
these tests only capture stopping distance. the only way this test could be replicated is with a hidden sensor that activates a light. the rider is actually moving at speed and the sensor and light signal an emergency, forcing a stop. this way surprise is added into the picture. their tests averaged around 65ft in a controlled environment but in the real world you can add an extra 10ft to those numbers. |
June 18th, 2012, 09:42 AM | #343 | |
Join Date: Jun 2012 Motorcycle(s): ZRX1200r x2, KZ1000, KZ1075 Posts: 5
**** happens
It was his first ride, according to what I read. Would that have happened to me? No. I am used to idiots after 24 years of street riding I read minds. Why it wouldn't have? Because I always look for the wheels on the cars, this probably happened way too quick for him even to notice till it was too late. This **** happens all the time. ALL the time. It's the reason I like to ride cause it's a life challenge. As far as all of the comments about what Jiggles could have doen I could say the same of that douchebag. When you crack a u-turn (they are illegal for the same reason by the way) you MUST LOOK TO MAKE SURE NO ONE IS COMING YOUR WAY!!! Point blank. No excuse for what she did and by the way you can sue her in a civil court for gross negligence. The lawsuit could still be on if she owns anything of value. Your downtime is full of pain. I broke my knee and had five pins and a plate. I KNOW THAT FEELING ALL TOO WELL. Three O'Clock in the morning like clockwork hits those incredible pains and why no one knows. But yeah, being laid up and having to have someone care for you? Ha 36k doesn't even begin to cover that let alone the excruciating pain nor the years off your life that you will endure with some sort of setback or other. Just wait till winter for a few years you will be, if you have metal in you, feeling it and the swell and cold will make you feel miserable. There have been so many times I almost lost my life at an intersection when people just up and run red lights, turn in front of you, which is probably the number one cause of accidents by the way, they cut your lane. THEY DON"T LOOK most of the time. That is a fact of life you will never change. Your approach to riding can change though. Sucks that it happened on your first ride. I don't know you man but you have my empathy. I totally commiserate with you on your plight. Go after her house and property, you will get more than that sorry excuse for a payout. Not like that will ease your suffering but you should get at least something for your ordeal. A little tip of advice: City riding sucks, you need to get out to the country where there are corners and after (better yet) do the mountain riding scene. Once you have done that you will have learned that in the mountains you can ride all day and rarely see any cars and most of the roads don't have intersections or parked cars that are potential accidents waiting to happen. Problem is now that I have experienced the best riding out there I just don't enjoy riding local too much any more. I gotta have those wild curves and lean over till that chicken strip thing is a part of history. You haven't experienced that feeling, you haven't truly experienced what it feels like to ride. |
June 18th, 2012, 09:55 AM | #344 | |
But in favor of what you said, yeah, trying to lock up the front brakes is foolish. Still, you don't wait to hit them hard if you need to stop right away. I had that issue a few times with old rubber where I was riding at 80 and a semi cut in to my lane with no turn signals. I gripped both brakes hard and wheels locked up, cheap rubber dunlops, a few days later an idiot slammed on his brakes in front of me on purpose and both my tires locked up. New tires eliminated that. |
June 18th, 2012, 10:55 AM | #345 | |
Nooblet
MOTM - Oct '13
@Jiggles: you're such a troll!
June 18th, 2012, 11:01 AM | #346 | |
MOTM - Apr '13
June 18th, 2012, 11:33 AM | #347 |
Someone posted this up on our website and I just saw the video and had to post up. Dude, I know those feelings and especially how the mind works when you are jacked up. Was there, had to comment.
The nice part was the sympathy sex that abounded from every chick I met. All my ex girlfriends stopped by to "comfort me" was unbelievably awesome. When you take a Vicadin and do the wild thing it's unbelievably great! Originally prescribed originally in Canada where I broke my knee on Friday the 13th afther some bare triple F Breasts stared me down and I freaked. Leaned back on my moto and well when I got up to go and find some action so did my bike. When we ignore cardinal rules we get PHOOKED. You can lean on kickstand side and knock bike over, look like idiot for falling on your bike but not the other way, bike fall on you and you look like the grandfather of all idiots plus you go to hospital with broken parts. And yeah, for the guy that talked about Canada, I'll take my healthcare here stateside. Sorry, for the jumping in but I had to post up. Carry on. |
June 18th, 2012, 11:36 AM | #348 | |
June 18th, 2012, 11:44 AM | #349 |
Here for you to peruse in your free time. Just thought you'd like to hear what other "motorcyclists" have to say about your get off. Not normal cagers who have no clue.
http://www.zrxoa.org/forums/showthre...-leaving-house |
June 18th, 2012, 11:56 AM | #350 |
Link to ZRX site fails for anyone who doesn't have an account on that forum.
June 18th, 2012, 12:56 PM | #351 |
MOTM - Apr '13
I registered and I still can't access it haha
June 18th, 2012, 09:19 PM | #352 |
So how fast were you really going dude...my guess was 33-35 based on revs and shifts.
June 18th, 2012, 09:38 PM | #353 |
MOTM - Apr '13
You are only 5-7 off lol
June 18th, 2012, 09:41 PM | #354 |
Nah dude no way you were doing 40
Just lookin for the truth...you wouldn't have blacked the speedo if you didn't have to worry about it If I was gonna be a dick I'd comment on your braking reflexes. |
June 18th, 2012, 10:24 PM | #355 |
MOTM - Apr '13
I was going 28, it's blocked out because if the insurance company could see the actual speed they could split the fault, i.e. Jiggles is X over the speed limit so he is Y% at fault.
And you can comment on my braking reflexes if you want but that's not what I was initally trying to do. My first reaction was get off throttle, hand on brake, go around her, then she kept coming and when I saw that she kept coming that's when I tried to brake
June 18th, 2012, 11:13 PM | #356 |
Join Date: Aug 2011 Motorcycle(s): None yet, yet. Posts: A lot.
lol @ the elites pulling out the math equations. Hindsight is always 20/20, and this is really good footage excluding the fact that you blocked out the speedo. don't do that next time, even if the insurance company dinks you for it, because it just looks bad IMO. I'd probably ride a little slower in an area like that, have my hand over the clutch maybe. You can't knock him for going 28 in a 25, that's a bit rough. It might be better if the speed limit in that area was lower though? idk. can't believe that witch asked you if you saw her.
The Rush is Addictive |
June 18th, 2012, 11:34 PM | #357 |
MOTM - Apr '13
What looks bad about the speedo? The actual title over it?
June 19th, 2012, 06:20 AM | #358 | |
Jiggles - It sucks you got hit. It really does. You were also going too fast for the conditions. You should have been doing closer to 20 MPH indicated. You mentioned earlier in the thread that noone goes that slow. I was *sorta* with you when you said that, because it does seem too slow. Well, guess what? EVERY day, I ride past the exact same conditions on my way to work. I did 28 MPH INDICATED to re-create your scenario a bit. And I felt like I was going way too fast; I felt like I would not be able to react in time if one of the parked cars pulled out. The next day, I rode at what I felt comfortable at (and what I felt like was a safe-enough speed so I could react if a driver does something stupid) and glanced down at my speedo.....I was at about 18 MPH indicated. My above post is pointless. You continue to claim that noone knows what they're talking about, you weren't going too fast, it was 100% unavoidable, blah blah blah. Even when riders with years and 100k of miles of experience say you were going too fast, you tell them they are wrong. So, it's pointless. You won't learn, you'll try and push yourself past that lump in your throat the next time you get caught in that situation, and you (hopefully not) might crash again in a similar situation. Keep that camera rolling. |
June 19th, 2012, 06:40 AM | #359 | |
June 19th, 2012, 10:57 AM | #360 |
MOTM - Apr '13
[roadracingworld.com] - Updated: Provisional 2012 MotoGP Entry List Totals 21 Riders, | Ninjette Newsbot | Motorcycling News | 0 | January 13th, 2012 04:20 PM |
[roadracingworld.com] - Provisional 2012 MotoGP Entry List Totals 21 Riders, Includin | Ninjette Newsbot | Motorcycling News | 0 | January 13th, 2012 10:50 AM |
[kropotkin thinks...] - Cost Of Motorland Aragon MotoGP Totals 41 Million Euros Throu | Ninjette Newsbot | Motorcycling News | 0 | March 9th, 2011 08:00 AM |
n00b Here | PeterJasonMN | New Members | 16 | June 11th, 2009 07:39 PM |
