September 1st, 2013, 06:16 PM | #1 |
Daily Jap rider
Join Date: Dec 2012 Motorcycle(s): 2012 Ninja 250r Posts: A lot.
Horn only works when it wants to
I installed a louder horn a while back and it was working great for couple months, but now it only works at random times. I have checked the connections at the horn and everything is connected. Not sure where to go from here. Horn is one of those highway blasters. Any suggestions?
September 1st, 2013, 06:50 PM | #2 |
Turn the handlebar from lock to lock and try seeing where the cables that feed the horn bend more: you may find an internally broken cable at that point.
September 1st, 2013, 07:20 PM | #3 |
Daily Jap rider
September 1st, 2013, 09:02 PM | #4 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
check the relay
the fiamm freeway blasters can pull up to 8A of power. check fuses and connections thoroughly. |
September 1st, 2013, 10:02 PM | #5 |
Daily Jap rider
September 2nd, 2013, 07:25 PM | #6 |
next to headlight relay, at battery. replace with oem or similar. Our bike rape cheap relay's, they can't handle the vibration.
September 2nd, 2013, 07:37 PM | #7 |
Daily Jap rider
September 2nd, 2013, 07:42 PM | #8 |
20 amp should be more than adequate, though most automotive SPST relays are 40 amps
September 2nd, 2013, 08:05 PM | #9 |
sometimes these things happen. just relax. light a few candles. put on some nice jazz. pour a couple glasses of wine and bust out the massage oil.
September 2nd, 2013, 10:08 PM | #10 |
Daily Jap rider
Lol, trying to relax. Needed the horn yesterday when jackass came into my lane without looking or signaling. plus my bike is due for inspection next month and Texas is picky about **** like the horn working
September 2nd, 2013, 10:35 PM | #11 |
i don't think i've had a horn in 2 years. are you really required to have one in texas? i thought california was all uppity about inspections but i guess texas is worse
September 3rd, 2013, 12:23 AM | #12 |
Join Date: Mar 2010 Motorcycle(s): 2010 Ninja 250R (sold), 2012 Tuono V4R Posts: 512
Yes, you're required to have a working horn in Texas.
2010 Kawasaki Ninja 250R - "Aria" (sold) 2012 Aprilia Tuono V4R - "Perrine" Proof that Harleys and Ninjettes are friendly with each other |
September 3rd, 2013, 05:24 AM | #13 |
if it's not something obvious, like a loose connection, blown fuse, blown relay, etc. it could either be the switch, wiring, ground location, or the horn.
personally, I have a multimeter that I bust out frequently for troubleshooting this type of stuff. You can test for continuity, voltage, etc. to determine if it's a wiring issue, if the horn is malfunctioning, etc. You do need a bit of electrical knowledge to get started though. worth a shot if you understand the basics of DC electricity. They're pretty cheap. |
September 3rd, 2013, 05:56 AM | #14 |
MOTM - Mar '13, Jun '14
I read the title and tought of that old saying about girlfriends and wives. What was that saying again....
September 5th, 2013, 09:06 PM | #15 |
Daily Jap rider
Tested all wiring, ended up being the horn. Took it back to autozone and got it exchanged for a new one. I installed a 40 amp relay and larger gauge wires. Horn is loud as **** now
September 5th, 2013, 10:43 PM | #16 |
WOT WOT WOT
Join Date: Jul 2013 Motorcycle(s): '12 Ninja 250R Posts: 421
Glad to know I wasn't the only one who read that title wrong. Lol
Sorry, OP. Glad to know your issue's fixed though.
May your roads stay clear.... |
Thank you Horn! | nvxdiz | Ride Reports | 11 | October 20th, 2012 12:19 PM |
Horn Not Working | Liist | 2008 - 2012 Ninja 250R Tech Talk | 2 | October 30th, 2011 11:01 AM |
Installed Stebel Nautilus air horn, a.k.a. Wolo "Bad Boy" horn | FrugalNinja250 | 1986 - 2007 Ninja 250R Farkles | 8 | June 23rd, 2011 05:37 AM |
Horn mount | mohns6062 | Items Wanted | 2 | May 27th, 2011 06:31 PM |
no horn | Ntotot | 2008 - 2012 Ninja 250R Tech Talk | 10 | September 28th, 2009 07:04 AM |
