April 4th, 2018, 10:00 AM | #1 |
[RideApart] - How it Works: The Motorcycle Clutch
Wherein we explore the mysteries of a motorcycle clutch Whether you are using your foot or your hand to operate it, we all know that when you engage the clutch our motorcycle engines are able to transfer power to the transmission and ultimately to the rear wheel. What actually happens when we engage or disengage the clutch can be a bit of a mystery, but I'm going to take you through the basics of how a clutch operates using my 1933 Harley-Davidson VL as an example. While this machine uses a foot operated clutch instead of the modern style hand operated one, the principles of operation are still the same. CHECK OUT: How It Works: The Motorcycle Kickstarter The heart of the clutch mechanism is a stack of alternating plates. The number of plates varies between different types of clutches, but no matter the number you will have a combination of fiber and steel plates. The fiber plates have a layer of material bonded or riveted to both sides of a metal core. The material was originally asbestos, but in modern times that has been replaced with organic resins. Whatever the material, its sole purpose is to create friction against the steel plates. The steel plates are just that, flat steel plates the are placed in between the*fiber plates. What you want to note in the picture below is how the*fiber plates are "keyed" on the outside and the steel plates are "keyed" on the inside. Top Row: Fiber plates Bottom Row: Steel platesOnce the plates are stacked together, they are mounted between the drive disc and the releasing disc. These are basically a top and bottom plate which are machined smooth so that the*fiber plates can ride against them just like they ride against other steel plates in the stack. On my VL, the releasing disc is shaped like a top hat that is keyed to the steel plates. You'll also note three alignment dowels that keep the drive disc and releasing disc locked together when assembled. Left: Drive disc Right: Releasing discWhen assembling the clutch, the fiber and steel plates are stacked onto the releasing disc in alternating order, starting with a fiber plate. The steel plates are locked to the releasing disc via their internals keys so they all spin together as one unit. Also, pay close attention to the fact that the keyways on the releasing disc are slots which allow the steel plates to move up and down. The*fiber plates on the other hand are just "floating" between the steel plates. Fiber plates and steel plates stacked on the releasing discCHECK OUT: Transmission Primer: 1933 Harley-Davidson VL Three-Speed Once the drive disc is placed on top of the above stack of plates, spring loaded screws are used to hold the entire unit together. The screws pass through both the drive and releasing discs before threading into three clutch spring nut sectors. This design keeps everything aligned, but also allows for movement between the drive disc and the releasing disc. The clutch springs provide the friction between the*fiber plates and the steel plates by sandwiching them between the drive disc and the releasing disc. When the clutch is engaged, the spring pressure is strong enough to hold all the plates together without any slippage. Remember that the*fiber plates are not locked to anything, so without this pressure they could spin. As you would expect, spring pressure is matched to the horsepower/torque of the motor, so if you upgrade the performance of your motor you often need to use stiffer springs to keep the plates from slipping. As the*fiber plates wear over time, the clutch spring screws can be tightened to take up slop and restore spring pressure. This entire unit is often referred to as a clutch pack. Transmission side of the clutch pack with the clutch springs and clutch spring nut sectors visibleThe last major component of the clutch assembly is the clutch basket which, as the name suggests, holds the clutch pack. On the inside of the clutch basket are keyways that match the keys on the outside of the fiber plates.* These lock the fiber plates to the clutch basket, but just like the keyways on the releasing disc, allow the fiber plates to move up and down. A gear runs around the outside of the clutch basket which is connected to the engine typically by a chain or belt.* In this particular example there are two gears on the clutch basket as a double row chain is used to connect it to the engine. Clutch pack installed in the clutch basketSo now we have a complete clutch where the steel plates are locked to the releasing disc, the*fiber plates are locked to the clutch basket, and the whole thing is spinning around via a chain attached to the engine. This entire assembly is mounted on a set of roller bearings that rides on the transmission's mainshaft. The mainshaft also has a keyway (yes, another keyway) that locks the drive disc to the mainshaft. This is the typical state of the clutch when the lever or foot pedal is released and the clutch is engaged. With everything locked together, the engine turns the clutch basket, which turns the clutch pack inside of it, which turns the mainshaft on the transmission. Clutch connected to the engineTo disengage the clutch, the clutch plates need to be separated from one another. Since the fiber plates are locked to the clutch basket and the steel plates are locked to the releasing disc, if the plates are pushed apart the clutch basket can continue to spin while the steel plates, releasing disc, and drive disc are all stationary. Once the drive disc stops spinning, the mainshaft also ceases to move and no more power is being transmitted from the engine to the transmission. To accomplish this on my VL, there is a rod which goes through the mainshaft, known as the clutch pull rod. On the clutch side of the transmission, it is attached to a three legged actuating plate whose legs pass through slots in the drive disc and press against the releasing disc. Close up of the clutch actuating plateCHECK OUT: Show Me Your War Face - A Day at the War Run Back over on the kickstart side of the transmission, the clutch pull rod rides on a throwout bearing which sits against the clutch release fork. Attached to the top of the clutch release fork is the clutch release lever. Position of clutch components when the clutch is engagedThe clutch release lever is what actually does the work of disengaging the clutch. When the lever moves back towards the rear tire, it rotates the clutch release fork which pulls the clutch pull rod through the mainshaft. This in turn pushes the actuating plate against the releasing disc, moving it away from the drive disc and eliminating the spring pressure on the fiber and steel plates.* Once the spring pressure is released, the fiber and steel plates are able to move apart and are not longer held together by friction.* In the next photo you can see how when the clutch release lever is moved back, the clutch pull rod moves out.* It's not a lot of movement, but enough to separate the fiber and steel plates. Position of the clutch components when the clutch is disengagedIt is somewhat surprising just how complex a clutch system can be. Even on my VL, which was designed over 80 years ago, there was a lot of engineering that went into building an operational system. If you have ever had issues with your own clutch, this should give you some insight into just how difficult it can be to successfully diagnose the problem correctly, especially on higher mileage machines. The next time you pull in your clutch lever just take a moment to consider all the operations it takes to disengage the engine from the transmission just so you can shift gears. More from RideApart:
Click here for full story...
[RideApart] - How It Works: The Motorcycle Kickstarter | Ninjette Newsbot | Motorcycling News | 0 | March 15th, 2018 12:50 PM |
[RideApart] - How It Works: Modern Airbag Suits | Ninjette Newsbot | Motorcycling News | 0 | February 22nd, 2018 01:01 PM |
[RideApart] - Turn Signal Gloves in the Works | Ninjette Newsbot | Motorcycling News | 0 | April 5th, 2017 04:30 PM |
[motorcyclistonline] - MC Garage Video: How A Motorcycle Clutch Works | Ninjette Newsbot | Motorcycling News | 0 | December 2nd, 2016 09:51 PM |
[RideApart] - How The New BMW ABS Pro Works | Ninjette Newsbot | Motorcycling News | 0 | July 28th, 2014 01:10 PM |
