October 23rd, 2012, 10:16 AM | #1 |
Keeping rear wheel clean
When I lube my chain some amount of oil and other debris builds up on my rear wheel and its a huge pain to keep it clean. What methods do you guys use to help prevent this?
October 23rd, 2012, 11:04 AM | #3 |
Different chain lubes are better or worse in flinging off and getting everywhere. If too much is applied, it gets even worse. I've had good luck with Maxima's chainwax, and people seem to like the Dupont stuff as well.
October 23rd, 2012, 12:19 PM | #5 |
Use a chain lube like Maxima or Dupont Teflon Spray. These 2 tend not to fling if applied correctly. Use a rag or cardboard to cover areas to prevent over spray. Lube a section at a time and let it dry in between applications.
October 23rd, 2012, 12:31 PM | #6 |
Using a large piece of cardboard really helps as well. Cut a round notch out of it so you can slide it forward between the wheel and the sprocket, and presto! Temporary lube guard for when you apply chaing lube.
October 23rd, 2012, 12:38 PM | #7 |
i just have someone spin the rear wheel for me while i hold a rag behind the chain and spray the different areas while i'm wiping the chain with the rag...
October 23rd, 2012, 12:45 PM | #8 |
October 23rd, 2012, 12:48 PM | #9 |
Big piece of card board. Cut a semi-circle shape out of it so the cardboard goes further over the cush drive, covers more of the rim, and keeps it clean.
October 23rd, 2012, 12:57 PM | #10 |
you know, you're allowed to wipe down the wheels with a rag when they are dirty... the chain lube even helps to clean the dried crap on there off with the rag
October 23rd, 2012, 01:06 PM | #11 |
Eh, then it gets on the tires too. I'd rather just not ride in rain, and not goober up the rim with chain lube. That's more cleaning work.
October 23rd, 2012, 01:28 PM | #13 |
So, where's the reverse?
Some WD-40 on a clean rag and all the gunk on your rims wipes off easy.
October 23rd, 2012, 11:50 PM | #14 |
Join Date: Aug 2010 Motorcycle(s): Ninja 250r 2009 Posts: 396
Or just leave it dirty. Nothing bad will happen.
October 24th, 2012, 12:12 AM | #15 |
I told you bro
Join Date: Jun 2012 Motorcycle(s): 1996 Ninja 250r Posts: 680
Just buy a bottle of tire cleaner and try and not get any of it on your chain. I use it whenever I clean my bike and it just cuts through road grime on my tires and rims.
October 24th, 2012, 11:44 AM | #16 |
Tofu, you made sure to keep that stuff off the tread of your tires right?
October 25th, 2012, 02:02 PM | #17 |
Yeah, but it'll pick up grime that much faster. Ask me, the PC'd rim owner, how I know.
Last futzed with by CZroe; October 25th, 2012 at 05:28 PM. |
October 25th, 2012, 05:11 PM | #18 |
October 25th, 2012, 05:38 PM | #20 |
Join Date: Apr 2011 Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold) Posts: 479
October 27th, 2012, 05:20 PM | #21 | |
I've been using Meguiar's no-scrub wheel cleaner on 'em when I wash the bike and works rather well
October 27th, 2012, 06:02 PM | #22 |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
to help you when you clean the rims.
go out and but a wheel sealant just like wax but harder. http://www.carcareproducts.com.au/pr.../wheel_sealant |
October 27th, 2012, 06:27 PM | #23 | ||
I told you bro
This. I don't put tire shine on my wheels, just use cleaner to get rid of grime and dirt. You wash the tire off with water afterwards so nothing stays on anyways. I also use another brand which I can't remember, but it works well. |
Keeping your helmet clean | Roranninn | Motorcycle Gear | 7 | April 10th, 2015 08:13 PM |
Rear shock set to high (rear wheel slipping)? | passive101 | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 10th, 2014 08:45 PM |
08+ rear wheel, right rear set, rear brake system, seat | cuong-nutz | Items Wanted | 2 | October 6th, 2013 05:37 PM |
Rear wheel spitting up onto the fender & rear seat. Solutions? | uKER | 2013 - 2017 Ninja 300 Farkles | 21 | July 29th, 2013 01:00 PM |
keeping the pinion area clean | alex.s | General Motorcycling Discussion | 7 | July 17th, 2012 10:50 AM |
