Old April 15th, 2009, 02:55 PM   #1
Ash
Ash's Avatar
Any pics or DIY posts for the Shogun frame slider kit?
Hello all!
I just purchased the Shogun kit, and I was wondering if it comes with detailed instructions for the '08 250 install?
Has anyone documented their installation process? I'm worried about the "notching" step in particular since I am not very handy.
Thanks!
Ash is offline   Reply With Quote
Old April 15th, 2009, 04:19 PM   #2
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
Motorcycle(s): '06 R6/'08 250R
No need for a DIY here......shogun did an excellent job with the install instructions. Here is a copy so you know what you have ahead of you. Feel free to ask here if you have any more questions.
Shogun Manual>>>CLICK<<<<
Sloppy2nds is offline   Reply With Quote
Old April 15th, 2009, 07:03 PM   #3
Ash
Ash's Avatar
Thanks! I really appreciate it.
Old April 15th, 2009, 08:01 PM   #4
Broom
Track Junkie
Broom's Avatar
Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike
pictures of it installed on my bike here
post up if you have any troubles.
Las Escobas -- Track Bikes Save Lives
JonBroom.com
Broom is offline   Reply With Quote
Old April 16th, 2009, 08:56 AM   #5
1hardryder4life
Motorcycle(s): Nothing
great kit. I just installed one last week.
1hardryder4life is offline   Reply With Quote
Old April 20th, 2009, 05:09 PM   #6
Ash
Ash's Avatar
In the posted pdf it mentions acquiring the torque values for the kawasaki parts removed during the install. Does anyone here have those?
Thx!
Old April 20th, 2009, 08:29 PM   #7
Sound Wave
Ramen Rider
Sound Wave's Avatar
Thx!
which parts do you need the specs for? i may have missed it, but reading it over quickly, it seems to have them listed in the instructions for the kit.
Old April 21st, 2009, 08:01 AM   #8
Ash
Ash's Avatar
Step 3 of the install guide states: Remove shift linkage from shift shaft and take counter shaft cover off. Step 11 is the reverse, mount linkage to shift shaft.
It looks like that component is the "Shift Lever Link Bolt" at 104 in-lb which is about 9 ft-lb? Is that correct?
Thanks!
Old April 23rd, 2009, 02:20 PM   #9
Ash
Ash's Avatar
I received the Shogun kit today. It did not come with any instructions for the swing arm spools, the bar end sliders, or the frame sliders. I guess the bar end sliders and spools are self evident, but I am grateful to Sloppy2nds for the manual! Thx!
Old April 23rd, 2009, 02:29 PM   #10
1hardryder4life
You will have one hell of a time removing the bar ends to install the new sliders. There are several ways but here is how I did it without the use of a torch or heat gun to loosen the red loctite:
Used a drill bit that was slightly larger than the diameter of the bar end screw/stud to drill the phillips head off of the stud itself. From there, the stock bar end will slide off and you are left with the stud stuck into the handlebar ends. I then used some vice grips to tightly clamp onto the stud, then broke them lose with that to remove the stock stud completely. The new shogun bar end sliders go on with the new allen bolt.
Swingarm spools are self explanitory. You will have some spacers that go between the slider spool and the swingarm.
Old April 24th, 2009, 01:52 PM   #11
randomwalk101
self wrencher
randomwalk101's Avatar
sold the Intuitive slider and ordered the ShoGun
What do you guys use to cut the sprocket cover with?
Old April 24th, 2009, 01:57 PM   #12
Broom
Track Junkie
Broom's Avatar
hacksaw or a dremel works
JonBroom.com
Old April 24th, 2009, 02:07 PM   #13
1hardryder4life
taped mine off to prevent collateral damage then hit it with a hacksaw. Hand power baby!
Old April 24th, 2009, 02:12 PM   #14
Ash
Ash's Avatar
What is the cover made of? Metal? Plastic?
Thx!
Old April 24th, 2009, 02:32 PM   #15
1hardryder4life
its not plastic, def metal. I had to put some time and elbow grease into mine with my dull hacksaw.
Old April 28th, 2009, 07:01 AM   #16
Ash
Ash's Avatar
I've got the Shogun frame sliders installed, along with the bar extenders and spools. Thanks for all the info!
Old April 29th, 2009, 01:26 AM   #17
watcanido
watcanido's Avatar
Nice! got pics?
watcanido is offline   Reply With Quote
Old May 1st, 2009, 07:50 AM   #18
randomwalk101
self wrencher
hey guys...just got the Shogun slider in. There is no label whatsoever on the kit itself. Even after reading the installation instruction, I'm still uncertain of which side is the actual left and right frame slider rail . they curve differently. Is the more "straight" one is on the right side?
Old May 1st, 2009, 08:48 AM   #19
1hardryder4life
hold it up to where it will mount at each point. It should be obvious which side is which at that point.
Old May 4th, 2009, 09:53 AM   #20
randomwalk101
self wrencher
Thanks guys.. Just finished installing it yesterday.
One thing to note though. The rear engine bolt, it appears I can slide it out with my bare hand (after removing the nut)...stock bolt that is.
Is this the case with you guys?
Old May 4th, 2009, 10:14 AM   #21
1hardryder4life
I wouldnt worry about it. As long as the bolt goes all the way thru everything that its supposed to go thru, and the nut is properly torqued, have fun.
Old May 6th, 2009, 11:15 AM   #22
1hardryder4life
Here are some pics of mine installed in case anyone can benefit from them.
Old May 12th, 2009, 09:25 AM   #23
Ash
Ash's Avatar
I just got around to taking some pics of the bike, so here are some pics of the sliders.
Shogun frame slider - 08-12 Bigballsofpaint Motorcycle-related 17 May 10th, 2015 08:11 PM
Shogun frame slider differences Bob2010 2008 - 2012 Ninja 250R Farkles 6 July 20th, 2014 08:17 AM
Shogun S5 Frame Slider Bolts MyronGanes 2008 - 2012 Ninja 250R Tech Talk 10 February 20th, 2013 09:53 PM
Shogun frame slider frame bolt question crankinaway 2008 - 2012 Ninja 250R Tech Talk 7 June 22nd, 2010 06:46 PM
