#1 |
QrtLtrDog
New here. Depressing issue. No spark on one side :(
Hey everyone. I hate that my first post is a cry for help but I'll be sticking around afterward.
My 02 ninja 250 was riding really sluggish. Wouldn't go past 40 in any gear. I read a ton of FAQs and articles before I decided to post. I checked my carb, my air box...basically everything but the sparkplugs. When I finally checked those, I realized my left plug wouldn't spark (I grounded it against the valve cover). I tried everything. I swapped and tested new plugs, swapped plug cables, and even swapped my coils from each side. Both coils are working but I'm still not getting spark from that left side. I even bought a multimeter to test the coils. They're within specs. What more can I test? I'm tearing out my hair. A couple notes: I have the bike sitting now with no tank, gauges, or fairings as I was working on a street fighter build. It was working before. I thought it might have something to do with me removing the gauges as that was the only electrical modding I've done. |
#2 |
QrtLtrDog
![]() My progress. |
#3 |
Jigglin' your Jiglets
MOTM - Apr '13
Maybe change your name to 124.5cc and call it a day?
If the Ninja 250 doesn't have enough power for you, then you don't know how to ride it. AFM #676 ![]() Supersports are for n00bs |
#4 |
did you check everything against the wiring diagram?
#5 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
Engine Compression!
I'm looking at the schematics and it says there is a green wire that comes out of the "ignitor" to ignition coil 1, and a black wire that goes to ignition coil 2 from the ignitor. Also, a red wire comes from your right handlebar switches (start button and engine stop switch) to both ignition coils in parallel. Check those out to see if they have been damaged from heat or anything. Just curious- what happens when you take off your odometer? Or do you just tuck it somewhere? |
#6 | |
#7 |
it sounds like right now you dont know if the cdi is even sending current to that coil... you tested the coils... check and make sure power is actually getting to both coils then check and make sure power is getting sent out the plug wires
#8 |
This is true, you can get a clamp-type ammeter for about $50-80 to quickly check if there is current flow from part to part.
#9 |
QrtLtrDog
Thanks for all your input. I'll reply to each of you when I get home.
All I have is a multimeter I literally bought today to test the ohm reading of the two coils. I'm pretty certain it's not the coils. What and how do I test using this multimeter beyond what I've done? Im not good with it so a detailed explanation would be greatly appreciated. |
#10 |
Make sure you don't have Champion plugs in there. You'll have nothing but headaches if you do. The bike does not like them.
I'm curious how you managed to swap plug cables given that they are molded into the coil. Anyhow, use a very small 12V light bulb to measure the voltage going into the coil while its running. You should see it flickering.
My Ninja Blog ![]() Proud member of ABATE.My NYC Road Rage documentary - CENSORED! |
#11 |
put the multimeter on DC volts 15, disconnect the coil that isn't firing and instead connect those wires to the multimeter probes. if you see the gauge getting voltage as you crank the bike you know the cdi is trying to power the coil for that cylinder. in which case the issue would have to be on the other side of the coil... the coil itself, the plug wire, the spark plug, or the ground connection going to the head.
if you see nothing going into the coil, it means there is a problem with either the CDI (seems unlikely since its sending power fine to the other coil) or the wiring between the cdi and the coil. since you replaced the CDI/plugwires, plugs and the other cylinder fires. the biggest target would be the wiring between the CDI and the coil.
#12 |
I UPGRADED to a YZF-R6 Mods: Shermoto LF7 Levers / Proton Flushmounts / Puig Smoked DB / Woodcraft Sliders / Tech Spec C3 Tank Grips / Rizoma Grips / Jardine |
#13 | |||
QrtLtrDog
By plug cables, I meant I swapped the part that attaches directly to the plugs. Quote:
So did I...after being frustrated a bit. |
#14 |
The 12v should be coming from the taco meter but you said it's disconnected which means maybe tat wire leading to the dash is shorting out against a +12v somewhere
#15 | |
The igniter could be bad, but its pretty rare. Try disconnecting it and measure the voltage and see if its still 12.5V. EDIT: Since the left coil is hooked to the tach, what does is it doing when you crank.
#16 | ||
QrtLtrDog
Also, I multi'd the battery and it reads 12.5 v. |
#17 |
I say again... Your wires going to the tachometer are touching things they shouldn't.
#18 | |
QrtLtrDog
I'm going to tear open the electrical tape and remove all the tach wires. That should do it, right? |
#19 |
I wouldn't go crazy until you know what the problem is.
Disconnect the cdi and coils and check for continuity from the wire going from the cdi to the coil and check it against the positive terminal cable that goes to the battery Battery should be disconnected when doing ohm or continuity checks so you don't damage your meter
#20 |
Any chance you tightened a nut on the wire and squished it?
The CDI is on the left side. Disconnect both cables and see if you are still getting 12.5V. Attached is a schematic that might be helpful. As a side note, its a good idea to save all your parts so that you can restore the bike when selling it later. Naked bikes don't sell for very much.
My Ninja Blog ![]() Proud member of ABATE.My NYC Road Rage documentary - CENSORED! Last futzed with by n4mwd; October 3rd, 2012 at 06:17 AM. Reason: typos |
#21 | |
QrtLtrDog
And thanks for the tip. My front fairings are pretty much after I wrecked. If anything, I could always sell my bike to my girlfriend for parts. ![]() |
#22 |
Important: The red wire goes to the lower tab in both coils.
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#23 |
Just so we're clear, this is the thing you swapped:
Did you check for 12.5V on the wire with the CDI disconnected?
#24 | |
QrtLtrDog
Yup. That's the thing. I'm really starting to think it has something to do with the tach. The bike was working great until I started taking off things from the front end ![]() |
#25 |
To answer your question about buying the clamp ampmeter: No it is not necessary at all because you have a multimeter that will do the same job just with more fuss. I would recommend you do a continuity test on the wires I mentioned in my above post. GL
#26 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
I am going to take a leap and say the #1 coil (the one on the left) is the one not working right?
Take a look at the wiring diagram @n4mwd posted. The #1 coil wire also goes to the tach. If you are reading 12.5 V without cranking then there is a wire shorted to ground somewhere (more than likely at the tach since that is where you were working. Last futzed with by flynjay; October 3rd, 2012 at 01:11 PM. Reason: Remove incorrect data |
#27 | |
QrtLtrDog
#28 | |
Check all three wires against ground (measuring resistance). Basically if it reads some value there is a connection there. Report your findings. |
#29 | ||
#30 | |
#31 | |
http://en.wikipedia.org/wiki/Straight-twin_engine Parallel twin engines with 180 degree crankshaft need separate carburetors and separate ignition systems.
#32 | |
#33 |
QrtLtrDog
I filmed the voltage tests. I filmed them in case I screwed something up.
https://www.youtube.com/watch?v=jZJC...e_gdata_player I also filmed the continuity tests but theyre taking a bit to upload. I got no readings on the continuity test I noticed that when the kill switch is off, I get a low voltage from the battery from both pairs of coil wires. When I flip the kill switch to RUN, the cylinder 1 coil wires put out 12.18 volts while cylinder to stays at 0.02 volts. I get no ohm readings when I tested the tach wires to ground. I did this by setting one problems to the wiring harness connector for each wire and the other probe to the valve cover. |
#34 |
@249cc take a photo of the wires that previously led to your tachometer and post it here.
#35 |
#36 |
QrtLtrDog
Pretty sure that isn't it because I've been swapping them for a while one between another and I still only get spark on one side. Even swapped the coils so I don't think it's a bad coil wire.
#37 |
umm...
1: bike worked fine 2: gauges removed 3: bike no work A: cylinder one no go boom. B: coil one feeds cylinder one, C: coil one connected to gauges... D: but gauges removed... wires leading to gauges are........?????????? all signs point to the gauge wires leading to the tachometer. several people have come to the same conclusion.
#38 |
QrtLtrDog
https://fbcdn-sphotos-b-a.akamaihd.n...80922710_o.jpg
In the second picture you can see the block connectors in the front. No loose wiring. https://fbcdn-sphotos-f-a.akamaihd.n...42341795_o.jpg |
#39 |
i see. i was under the impression the gauges were disconnected. what happens when you disconnect the black wire connected to the tachometer
#40 |
For testing here, lets always keep the kill switch set to RUN.
Ok, a quick look at the schematic shows that when the key switch is ON then the red wires to BOTH the coils should have 12V on them. The other wires, black for cylinder #1 and green for #2, go to the CDI. The black wire also goes to the tach. It is not a ground wire. IMPORTANT: Disconnect the CDI. The video shows it still connected. The black and green wires should read identical but not connected. Using the ohms setting on the DVM, check for resistance of each to ground (Engine block or neg terminal of battery). If it shows low resistance, then you have a short to ground somewhere. If you forget to disconnect the CDI, the readings are incorrect.
Changed Spark Plugs; Right Side Boot Won't Snap In Easily | Lil_Green_Demon | 2008 - 2012 Ninja 250R Tech Talk | 8 | February 16th, 2015 10:09 AM |
Is it a huge issue not to use anti seize on spark plugs? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 27th, 2013 06:23 PM |
Removing spark spark plugs? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 26th, 2013 03:48 PM |
[crash.net - MotoGP] - Depressing race for Ducati | Ninjette Newsbot | Motorcycling News | 0 | July 18th, 2011 03:30 AM |
[topix.net] - Motorcycles promoted to fight the most depressing day of the year | Ninjette Newsbot | Motorcycling News | 0 | January 16th, 2010 01:00 PM |
