April 3rd, 2016, 07:56 AM | #1 |
Join Date: Apr 2016 Motorcycle(s): 2005 honda cbr 600rr, 1988 ninja 600rr Posts: 2
1986 ninja 600r spark issue
I had the bike running and all of a sudden it died. I checked for spark and had nothing. Does anyone have the Haynes maul or knows what the resistance should be on the pickup coils and on my primary and secondary coils?
Any help would be greatly appreciated! |
April 3rd, 2016, 08:26 AM | #2 |
Vintage Screwball
MOTM - Mar '16
First things first, make sure they're getting power before you start checking the pickup.
There should be battery power at the coils with key on. 11-12 volts. Check the battery too. There should be the same colored wire going to each coil....that's power. The different colored wires are the trigger. All 4 plugs are dead or just the one you checked?
Goin' fast on slow bikes! |
April 5th, 2016, 11:43 AM | #3 |
I have good voltage from the battery, i charged it overnight. (Battery checks out good)
All 4 plugs are dead, that's why I was leaning towards the pickup coil. But let me check the wires going to the coils. |
April 5th, 2016, 11:48 AM | #4 |
MOTM - Sep '14
Did you check the battery volts under load?
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
April 5th, 2016, 11:49 AM | #5 | |
Vintage Screwball
MOTM - Mar '16
If battery voltage is present, next step should be checking the ground for the coils and making sure it's in good shape. Then you should start checking the trigger/CDI box.
1986 ninja 250 | james250ninja | Pictures | 12 | August 19th, 2014 05:58 AM |
Is it a huge issue not to use anti seize on spark plugs? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 27th, 2013 06:23 PM |
Removing spark spark plugs? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 26th, 2013 03:48 PM |
New here. Depressing issue. No spark on one side :( | 249cc | 1986 - 2007 Ninja 250R Tech Talk | 61 | October 4th, 2012 08:08 PM |
