Old June 22nd, 2013, 06:28 AM   #1
webfoot
Motorcycle(s): 2012 ninja 250R
bellmouth diameter?
need the bellmouth diameter on carbs so can order slip on K&N filters.
Dont want to disconnect everything to measure. Anyone have this measurement for the 2012? thanks
webfoot is offline   Reply With Quote
Old June 22nd, 2013, 06:34 AM   #2
DaBlue1
Long Time Rider
DaBlue1's Avatar
Wouldn't it be easier to order with a P/N?
http://www.ninjette.org/wiki/Air_filters_for_newgens
Old June 22nd, 2013, 06:44 AM   #3
webfoot
I am removing stock box. they dont make the duel slip ons for the 2012 so have to mount 2 universal 1,s. to do that I need diameter of opening to get correct 1's, thanks
Old June 22nd, 2013, 08:21 AM   #4
webfoot
the thread you posted is incorrect for the listings, the pods are what I want but the listings are not for 250 kawi,
all I need is a number, 1 inch, 2 inch, 2.25? the parts numbers you gave on the thread dont match 2012 250R
Old June 22nd, 2013, 09:02 AM   #5
DaBlue1
Long Time Rider
DaBlue1's Avatar
Every part listed fits the Kawasaki Ninja 250 and 300. This is what everyone that runs pod filters (in the U.S.) uses and have been for years. The dimensions of the CVK32 carbs are the same size worldwide.
The reason K&N does not list the 2012 Ninja 250R on it's website is because the pod filters were not and are not purposely designed with the Ninja 250 in mind.
Sorry you didn't find the information useful.
Old June 22nd, 2013, 09:19 AM   #6
jman511115
Motorcycle(s): Ninja
http://www.knfilters.com/mobile/mPro...x?&prod=r-0990
That will fit.
2010 with some stuff...
Next mod: ZX6R front end.
jman511115 is offline   Reply With Quote
Old June 22nd, 2013, 09:40 AM   #7
DaBlue1
Long Time Rider
DaBlue1's Avatar
Originally Posted by jman511115 View Post
That's not the one he wants. He wants dual pods. K&N- P/N: RU-1822 is what he is looking for, but for whatever reason he feels it won't work or it's incorrectly listed.
http://www.amazon.com/RU-1822-Univer...owViewpoints=1
http://faq.ninja250.org/wiki/Which_a...e_Ninja_250%3F
Old June 22nd, 2013, 10:02 AM   #8
webfoot
I have twin CVK 30's, stock on my 2012 250R, not 32's. bought new here in philippines guys
Old June 22nd, 2013, 10:44 AM   #9
DaBlue1
Long Time Rider
DaBlue1's Avatar
The CVK 32 on the 86-87's, however the RU-1822 will fit on them as well as the CVK-30. The 30 or 32 in the name represents the venturi exit diameter.
On the individual K&N's (RU-1822) the limiting factor is that unless you are very careful, putting the second one on knocks the first one off because the carbs are so close together.
The R-0990 single unit takes care of this problem. It has two boots sized and spaced perfectly to fit over the necks of the carb intakes. Each boot has its own hose clamp to tighten it down. It's also less expensive.
The R0990 Flange Inside Diameter is 1.875 in (48 mm)
The RU-1822 Flange Inside Diameter: 2 in (51 mm)
Old June 22nd, 2013, 01:22 PM   #10
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Pwnd
AFM #676
Supersports are for n00bs
Old June 22nd, 2013, 05:14 PM   #11
webfoot
@Blue, thats the stuff I needed, you rock, sorry for the confussion on my part. You saved me lots of work with that info, who would of thought opening same on 30 and 32. Great update! Even K&N was confused on this one.
Old June 22nd, 2013, 05:24 PM   #12
webfoot
Originally Posted by Jiggles View Post
Pwnd
Hahaha, hear this from many but it is an ego statement on your part, this is my 33rd cycle and on every 1 of the jap bikes I have installed aftermarket upgrades because I can, and to improve something is to help stimulate the economy, and make me feel like the cycle is truly mine not some government regulated clone like everyone else has,Whats wrong with installed something like exhaust, jet kit and filters to improve all around performance? I could get on my 1000 and go a lot faster, so your statement is a non issue. Besides, gearing would have to be changed to get anymore top speed for the 250, which I am not looking for, I want better performance of something so I dont know how to ride, give me a break.
Old June 22nd, 2013, 05:34 PM   #13
DaBlue1
Long Time Rider
DaBlue1's Avatar
@Blue, thats the stuff I needed, you rock, sorry for the confussion on my part. You saved me lots of work with that info.....
Old June 22nd, 2013, 05:41 PM   #14
Jiggles
Jiggles's Avatar
MOTM - Apr '13
That there is a fine story sir
AFM #676
Old June 22nd, 2013, 06:28 PM   #15
webfoot
@jingles, hello sir, was living san jose when started racing in 1969, livermore, carnigue (spelling error hehee), pal, I remember orchards, lots of orchards, lots of fun, changed alot.
when got ama license was normal weekend hwy 9 racer, now I know why I fell 3 times on that road, to much power, to little rubber on those bikes then, kawi 750 2 stroke triple and suzuki 380 home made cafe bike. Plus experimented with lay down shocks and frame mods, dumb kid and everyone in those days said when in doubt gas it, wrong, haahaa, please ride safe and and visit the carls jr, on Bowers.
Used to have great burgers.
bought my cz, maico, Dkw, penton, super rat and steen there, modified all because it was what we did.
Got my first sponsership for Harley 125 motocross but duty called and went in Navy.
what is the diameter in the fram under the seat? peterpayne 1986 - 2007 Ninja 250R Tech Talk 2 September 15th, 2014 03:55 PM
Injectors' capacity? And aftermarket primary pipe diameter micoulisninja 2013 - 2017 Ninja 300 Tech Talk 25 July 16th, 2014 01:44 AM
Valve shim diameter? smokinsingle Ninjettes At Speed 2 February 8th, 2013 04:31 PM
Exhaust Diameter zzrguy General Motorcycling Discussion 12 March 31st, 2012 01:32 AM
exhaust piping diameter? J Walk 2008 - 2012 Ninja 250R Tech Talk 1 February 9th, 2011 06:09 PM
