October 21st, 2010, 06:26 PM | #1 |
Join Date: Apr 2009 Motorcycle(s): 09 Ninja 250 Posts: 184
GoPro Helmet Mount
My sweet husband bought me the GoPro HD camera for my birthday but now I can't decide the best way to mount it to my helmet. I've seen several videos where you can see the helmet in the video. Is there any way to avoid this? Would those of you who own this wonderful gadget mind posting up photos of your lid with the camera mount so I can see how everyone else is mounting them?
October 21st, 2010, 07:01 PM | #2 |
Professional belly dancer
Join Date: Apr 2009 Motorcycle(s): 1992 GSX-R 750 Posts: A lot.
I stick mine on my bike. Usually on the tank.
Edit: Ok uhh...I was going to post up a vid I took of me and my 250 with the camera mounted on the tank. It had music and everything. I have no idea where it went |
October 21st, 2010, 07:25 PM | #3 |
I don't have a picture of my setup, but I mounted mine on the lower right hand side of the helmet chinbar. I can barely see the camera out the right side, but I can see if it's there or not.
I had to play with placement a lot to minimize the helmet intrusion into the video frame. Not able to fully get rid of the helmet in the vids, but this is the latest placement of where it is presently mounted. If you want, I can take a pic of the setup later. have fun... it's a great toy. |
October 22nd, 2010, 05:18 AM | #4 |
Thanks Flash & Kkim. I think I like the setup with it on the chin bar because if I turn my head you can see surrounding scenery. I was concerned that you would see the helmet in the video but that looks like a great location. I also like that you can see if the camera is still there. If it falls off you would at least have a chance of finding it. I can't wait to get it mounted and go for a ride.
BTW KKim - I'm jealous. I would love to have a dirtbike. I have never ridden one but they look like so much fun. |
October 22nd, 2010, 06:01 AM | #5 |
October 22nd, 2010, 11:28 AM | #6 |
Lisa,
I have another mount on my street bike helmet (the one in the vid is a dual sport helmet) and with the Go Pro mounted in a similar location, the helmet cannot be seen in vids shot with that helmet. The trick is finding a spot on the helmet where the curved mount that they give you will fit properly. Every helmet has a different curvature and finding a spot for that mount can be tricky. here's some pics of the case mounted on the street bike helmet. notice the weird angle which the camera needs to be mounted to eliminate the helmet from the vids. http://picasaweb.google.com/kkim993/GoProCamera# |
October 22nd, 2010, 12:51 PM | #7 |
Thank you so much! That helps me out alot!
October 23rd, 2010, 12:25 AM | #8 |
Join Date: Feb 2010 Motorcycle(s): 2008 Ninja 250R Posts: 36
This is mine:
October 23rd, 2010, 07:29 AM | #9 |
Did you have to buy that mount seperately? I don't think that one came in the kit I got.
October 23rd, 2010, 11:51 AM | #10 |
Lisa,
I believe he used the "J" shaped mount, on the left in this picture, that should have been included with your camera. The problem is finding a helmet with a flat enough area in the front to mount the base. |
October 23rd, 2010, 05:07 PM | #11 |
Correct I used the J type mount and a slightly modified curved adhesive do-dad.
I built up the mount with some two-part plastic to suit my helmet. It's real easy to do, you can look at the rest of the photos on flickr for more detail: http://www.flickr.com/photos/3085969...7624643948626/ |
October 24th, 2010, 01:48 AM | #12 |
Ramen Rider
Join Date: Jan 2009 Motorcycle(s): 2015 BMW R1200R, 08 Honda VFR800A (sold), 09 Ninja 250R (sold) Posts: A lot.
i have the chest strap mount and that seems to work pretty well. i have only tried it once, and i gotta tweak it a bit more, but overall, the view is pretty good.
it is a good alternative between mounting it on the bike and the helmet. it doesn't shake as much as attached to the bike since the body absorbs some of the vibration. it is also not affected by body movement as much as a helmet mount such as turning the head to look around. of course, if you are in a full tuck, then all your camera will show is the top of your gas tank. |
October 24th, 2010, 01:59 AM | #13 |
Miz and Buzz
Join Date: Oct 2010 Motorcycle(s): 09 Kawasaki Ninja 250r Posts: 15
I've mounted mine to the LeftHand Fairing with the Big zigzag mount, and the one on the helmet on the front of the chin piece with the smallest mount. My fairing moiunt gets excellent video (got some footage today and its awesome) and with the helmet mount you get No pesky helmet interruptions, but if i head check, you can see exactly what i see...
http://canberrariders.org.au "Every garage needs a Ninja, even if it is only a little one" http://mizrx3.livejournal.com/ |
February 14th, 2011, 07:41 PM | #14 |
hey Gordo, what adhesive did you use to stick the plastic bond to the helmet?
February 14th, 2011, 08:10 PM | #15 |
It is the same adhesive that is on the original GoPro mounts. 3M VHB 4991.
I ordered a sample from 3M. Took about 3 weeks to arrive but it's free and there's plenty of it. |
Trying out suction cup mount (gopro) | Jason5885 | Videos | 3 | April 8th, 2015 08:49 AM |
[motorcycle-usa.com] - KillerShot GoSwivel GoPro Helmet Mount Peek | Ninjette Newsbot | Motorcycling News | 0 | February 26th, 2014 05:50 PM |
The best GoPro mount ever! | Peanut_EOD | Ninjettes At Speed | 2 | October 23rd, 2013 09:48 AM |
How do you mount a GoPro on a helmet/bike? | michael38 | General Motorcycling Discussion | 6 | August 2nd, 2013 08:18 PM |
Best place to mount GoPro to minimize shake? | ajcadoo | Videos | 8 | June 24th, 2013 05:39 PM |
