Old November 23rd, 2010, 02:03 PM   #41
Momaru
Momaru's Avatar
Originally Posted by romeo127 View Post
i was just reading your forum! so your saying it might be the flash relay? i bought a fl thermal flasher i should exchange that one then, this wiring is a pain! but thanks for the advice i'll try it out and let you know how it goes in acouple of hours
Might that be an "FL-32" thermal flasher? If so, I can say that's almost definitely your problem. That's what I had in to generate the weird stuff in the post I linked above. Most 'thermal flashers' are mechanical and not designed for the low resistance from LED flasher bulbs.
To solve it, I purchased a CF12ANL-01 from SuperBrightLEDs.com (direct link) which seems to correct it. Also the LF1-S-PIN & LF1-S-FLAT should work, but will require a little wiring to bridge the relay and the stock wiring. There's a bunch of other LED flashers on the market, many of them less expensive, but that's what I used. I can't guarantee the relay is your issue, but that's what it sounds like to me and it's a very common problem.
Unfortunately I'll be on the road for a couple days, but the others around should be able to help out if that's not it and I'll check back soon as I can.
Proud member of the Blue Army
Old November 23rd, 2010, 02:58 PM   #42
romeo127
romeo127's Avatar
Motorcycle(s): 2008 ninja 250
thanks for all the help!!
romeo127 is offline   Reply With Quote
Old February 4th, 2012, 01:15 PM   #43
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Hey Paul im not doing the fancy way and just striping wire and connecting them. Does the black from the protons go to the green wire from the stock harness or does it go to the black/yellow wire from the stock harness?
And from what I read its the red and orange wire to get normal blinking?
HELP I am trying to do this today.
Old February 4th, 2012, 01:32 PM   #44
massacremasses
Avid Kitteh Poster
NVM! I read better this time. lol thanks.
Old February 4th, 2012, 03:58 PM   #45
Momaru
Momaru's Avatar
Reading is your friend
But JIC, it should be black on protons to black/yellow on stock.
And orange (to stock harness green) is all you need for normal. You could attach red as well, but it makes no diff. I just did it that way b/c I didn't know better and figured it shouldn't hurt.
Old February 4th, 2012, 06:06 PM   #46
massacremasses
Avid Kitteh Poster
lol ok.
I also noticed mine sat in there kinda weird. Not noticeable but there was a little gap that I noticed... but again I am super picky..
Old February 8th, 2012, 08:03 PM   #47
Momaru
Momaru's Avatar
Originally Posted by massacremasses View Post
lol ok.
Don't forget they're especially molded to fit one side, so if they're swapped they won't fit well. But the fit isn't perfect; had to make some allowances for manufacturing variation in the fairings. That's another reason I went with the silicone bead around the 'lens,' to close that gap.
Old February 8th, 2012, 08:19 PM   #48
massacremasses
Avid Kitteh Poster
how is there a left and a right they look exactly the same?
Old April 1st, 2012, 06:21 PM   #49
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I will be doing this soon. I already have rear leds and a new led flasher. Will I need to do the diode mod too? I will be using the orange wire only for power.
Old April 1st, 2012, 09:52 PM   #50
massacremasses
Avid Kitteh Poster
YESSSSSSSSSSSSSSSSSSSSSs you will
Old April 9th, 2012, 05:48 AM   #51
Risky
Motorcycle(s): Ninja 250 2012
I have searched all threads to find none that address my specific issue and hope someone may be able to help me.
I just installed proton flushmounts on the front and have retained stock on the rear. I added a new flasher relay (Tridon HD12) to address the issue of rear lights not flashing and now all but my front left proton lights work properly. The front left one is dismally underpowered and struggles to light up much at all. I tried plugging this seemingly faulty left side proton light into the right harness to check if it was an issue with my left side wiring but it still flashed abnormally.
The inexplicable thing is that it worked great, then didn't, then had a couple of erratic moments before displaying the behaviour above.
Granted my relay is not ideal as it's an electro mechanical version but was the only one in my local auto shop that came close. As mentioned, it fixed the rear light issue instantly. I tried returning to the stock relay but the left proton, where it had worked fine under the stock before, now remained dimly lit. Would a fully electronic relay really fix this issue? I'm now not so sure.
I have them wired for strobe with the red and yellow proton wires to the ninja's stock green and of course the black to the stock black/yellow. I tried snipping the red wire but this had no effect on the poor light output.
I am out of ideas cannot see any other reason for it other than a faulty proton light. Any body have any ideas?
Risky is offline   Reply With Quote
Old April 9th, 2012, 07:05 AM   #52
Momaru
Momaru's Avatar
I assume you have LED rear signals as well? If so, one diagnostic you might try is plugging in stock (incandescent) blinkers in the rear with protons up front. If they behave normally, I can pretty much guarantee it's your flasher.
I had a standard electro-mech blinker at one point and had some very strange flash issues as well. Frankly, I'd try getting a proper, fully-electronic blinker first. When I had mine, the proton would flash irregularly, sometimes bright, sometimes dim, but the rears worked just fine. Getting an electronic relay usually corrects unusual blinker issues.
I cannot remember a single instance of a faulty HTS proton flasher. That said, there's always a first time and I have seen a lot of instances of other LEDs permanently damaged by a power surge.
Old April 9th, 2012, 11:09 AM   #53
kevlar250
kevlar250's Avatar
Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1
If one works when plugged into the right and the other one doesn't when plugged into the right then it's the Proton unit.
kevlar250 is offline   Reply With Quote
Old April 9th, 2012, 11:23 AM   #54
mustang5.0
Motorcycle(s): 2011 GIXXER 600
nice...i just ordered the flush mounts
"You see it's not the blood you spill that gets you what you want. It's the blood you share, your family, your friendships, your community. These are the most valuable things a man could have."
mustang5.0 is offline   Reply With Quote
Old April 10th, 2012, 02:40 AM   #55
Risky
Hey Momaru, I have stock on the back. Just scored a fully electrical one but to be honest, I'm hesitant to bother because of the below.....
Exactly. How could it possibly be anything else? I emailed Mike at High tech to explain and he's sending me out a new unit. Stay tuned, this may just be the first time Momaru! I bloody hope so as I'm all out of ideas.
Old April 21st, 2012, 06:48 PM   #56
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Thanks to all of you I completed the mod and everything works great! Thank you for posting all the step by step.
Old April 21st, 2012, 07:35 PM   #57
Malicious Logic
hates stupid people
Malicious Logic's Avatar
Motorcycle(s): 2005 ZX6R
Originally Posted by Betlog View Post
BTW, did you replace your stock relay?
So...I need to replace my stock relay in order to use these??
My vlogging channel: Ma1iciousLogic
Malicious Logic is offline   Reply With Quote
Old April 22nd, 2012, 04:35 AM   #58
snot
sammich maker
snot's Avatar
MOTM - Apr '15
You need an electronic flasher relay EL34.
Old April 22nd, 2012, 04:44 PM   #59
Malicious Logic
hates stupid people
Great...couldn't be something simple.
Old April 23rd, 2012, 03:31 PM   #60
snot
sammich maker
snot's Avatar
MOTM - Apr '15
This may help
http://www.ninjette.org/forums/showt...buying+flasher
Old May 1st, 2012, 03:14 PM   #61
Risky
So the Proton flasher unit itself was indeed faulty. I received a replacement in the mail from Mike at HTS, switched it in and it works perfectly. Great service from HTS, couldn't be better. Just don't ever think that it can't be the LED unit itself, because it can, and you'll drive yourself banana's looking for an alternate explanation!
Old May 1st, 2012, 03:30 PM   #62
Momaru
Momaru's Avatar
Heh, wow, guess you were the first I've heard about. Glad you got it sorted out, hope ya enjoy them!
Old May 4th, 2012, 05:44 AM   #63
Risky
They're great. I love them. But they certainly do cut down the visibility of my indications so I also mounted Oberon bar end LED indicators and together, they rock.
Old May 10th, 2012, 03:25 PM   #64
folky15
folky15's Avatar
Motorcycle(s): '08 Ninja 250R
I installed the Protons today and everything works great (thanks to this DIY!!) except for one minor problem:
To get the Protons to act as running lights, I tapped into the license plate light wiring and connected it to the red Proton wire. I can hear the relay clicking at the same time as the rear LED signals flash, but the front Protons are 'un-synced.' I also did the diode mod and everything looks great except that the front and rear LED's don't flash at the same time.
When I disconnect the red Proton wire from the license plate wire, everything is synced and works as it should. Is there some other power source I should be using for the running lights?
update: I tried using some other power source (tail lights, straight from the battery) and I still have the weird flashing when I connect the running late. Freakin' annoying. Any advice?
Done: Fender Eliminator Kit, Shogun frame sliders, Rim Tape, Freeway Blaster horn, Protons, Rear LEDs, Brake Modulator
Planned: Comp Werkes Slip-on, Snorkel Delete, Shimmed Needles
Last futzed with by folky15; June 8th, 2012 at 09:46 AM. Reason: provided update
folky15 is offline   Reply With Quote
Old June 24th, 2012, 09:07 PM   #65
sleepless
Motorcycle(s): '11 250 SE
Are you trying to use the Protons ONLY as running lights? Or have them be dimly lit at all times and full brightness when you put your turn signals on?
I didn't think the Protons had the ability to act as both running lights and turn signals. That would depend on the board inside the lights, but as far as I know, it's not meant to do that.
If you just want them as running lights, you could try tapping into the actual running lights wire in your taillights. It is the red wire IIRC.
sleepless is offline   Reply With Quote
Old June 24th, 2012, 09:13 PM   #66
sleepless
One more thing, a idiot's guide PSA if you will
You need to REUSE the stock metal mounting bracket when installing the Proton lights in the fender. If for some reason you are having an off day and simply install the included washer and nut right up against the rubber grommet in the fairing, the bolt in the Proton WILL break in half on your FIRST ride out after reassembling your machine.
(From personal experience..)
Parts:
Protons
2 Position 050-HC Connector (http://www.easternbeaver.com/Main/El...onnectors.html)
Stranded wire (~22AWG)
Shrink tubing (3/16" & 3/32")
Solder
Soldering iron
Wire stripper/cutters (I had two pairs, not pictured)
Crimper
Liquid electric tape (optional) (also not pictured)
Gasket sealer (optional)
Momaru, might want to include that in the parts list for the fellow thick-headed riders. Great diy though!
Old June 24th, 2012, 09:58 PM   #67
folky15
folky15's Avatar
I'm trying to use the Protons as running lights that are on all the time, and then have them act as turn signals when needed. I believe that they are supposed to be able to function properly in that type of set-up. I talked to the Proton support people and they suggested I try some different relays to see if that fixes the problem.
Ordered the Proton Flush Mounts today Old Guy on a '08 2008 - 2012 Ninja 250R Farkles 5 September 10th, 2012 03:32 PM
Proton Flush mounts 08-09 Specific Sloppy2nds 2008 - 2012 Ninja 250R Farkles 132 February 6th, 2012 03:10 AM
Shinto Clip-ons, Bike Monkey Integrated Tail and Proton Flush Mounts Mac Motorcycle-related 9 November 21st, 2010 02:52 PM
Proton Flush Mounts Jerkson Motorcycle-related 6 September 23rd, 2010 05:23 PM
cheaper Proton flush mounts istreefitty 2008 - 2012 Ninja 250R Farkles 8 July 19th, 2009 08:47 PM
