Old January 6th, 2009, 06:04 PM   #1
aloh
lolwut
aloh's Avatar
Rust forming on chain?
Ive noticed small bits of rust forming on the chain on my 250. The bike only has 4300 miles on it. Its not a huge amount of rust though. Should I be worried? Any suggestions for chain cleaning/maintenance?
08 Blue Ninja 250R
aloh is offline   Reply With Quote
Old January 6th, 2009, 06:05 PM   #2
When was the last time you cleaned and lubed your chain?
Old January 6th, 2009, 06:10 PM   #3
aloh
lolwut
aloh's Avatar
I lubed the chain when i first bought the bike in October. I think the rust may be due to the fact that the bike has to stay outside since there is no room for it in the garage. I finally bought a quality bike cover to put on it (the first cover i had was garbage), but im afraid it was a little too late since it has already been rained on a couple times
08 Blue Ninja 250R
Old January 6th, 2009, 06:16 PM   #4
So, you have 4300 miles on it and have never lubed and cleaned the chain since new? It should be done every 400 miles according to the maintenance schedule. Leaving it outside doesn't help, but chain lube on bare metal would prevent most of the rust from forming.
Speaking of chain lubes, this is what I prefer...
Old January 6th, 2009, 06:32 PM   #5
aloh
lolwut
aloh's Avatar
Bought it when it had 4100 miles...so it wasnt new.
What do you do use clean it? Ive heard some people use kerosene while others use wd-40.
08 Blue Ninja 250R
Old January 6th, 2009, 06:40 PM   #6
I spray WD-40 on it and wipe it off with a clean rag. Get as much dirt/grime off as you can. A kerosene soaked rag will work well, too.
After it's relatively clean, apply lube of your choice.
Doing this while the bike is on a rear stand really makes the job easy, but it's not necessary. When you have the bike up on the rear stand, be mindful not to get your fingers caught between the chain/sprocket while cleaning.
Old January 6th, 2009, 06:44 PM   #7
Or anyone else's fingers, either.
Old January 6th, 2009, 06:56 PM   #8
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
I try to spin the wheel backwards when I do it so if anything does snag it's not pulled into the rear sprocket (ie. FINGERS).
VeX is offline   Reply With Quote
Old January 6th, 2009, 07:01 PM   #9
...unless you are cleaning the top of the chain run.
I usually make sure to work on the center section of chain while I clean it (between the sprockets) but one does tend to spin the wheel when drying it off, hence the caveat.
Alex, I don't have "little helpers" like you do, so I'm left to do the dirty, grimy work.
Old January 7th, 2009, 02:09 PM   #10
Sailariel
Sailariel's Avatar
Kelly, The Maxxima Lube is really great stuff. You use the same routine I do. I use Kero or WD-40. I like to buy WD-40 by the gallon at Home Depot. The only departure from your routine is that after I have applied the Maxxima, I spin the rear wheel very slowly and put a hair dryer to the chain on the LOW setting. I wait till the next morning to wipe off any excess. This is what I do with my racing bicycles. My customers win races.
Old January 12th, 2009, 11:04 AM   #11
Dan Kyle
Motorcycle(s): 1098 848 ZX10R GSXR1000
I rarely clean the chain.
I prefer:
PJ1 in the Blue can, there is a yellow as well, that is for dirt bikes.
The Honda chain lube.
Repsol chain lube.
If the chain is rusting, either you are not lubing it enought, or the chain lube is not a good one. Or both.
Dan Kyle is offline   Reply With Quote
Old May 5th, 2009, 09:59 AM   #12
travis5018
so say my chain has a decent amount of rust on it from the combination of leaving it outside in the rain without a cover and my lack of lubing/cleaning the chain. I sprayed some wd-40 on a rag and did some work yesterday but there is still a decent amount on the chain. Time for a new chain?
travis5018 is offline   Reply With Quote
Old May 5th, 2009, 11:34 AM   #13
capt_bugaloo
motorcycle rider
capt_bugaloo's Avatar
Can you post a photo?
Old May 5th, 2009, 12:56 PM   #14
Rocketman
Rocketman's Avatar
Motorcycle(s): 2009 250r special edition
Are you sure it isn't the fog lamps making them win all of those races ?
Interesting method
Rocketman is offline   Reply With Quote
Old May 5th, 2009, 03:59 PM   #15
Buffalony
Buffalony's Avatar
IMO WD-40 is the worst idea on cleaning the ninjettes o-ring chain.
I use a foaming degreaser then HHS 2000
WD-40 is like a penetrating solvent. I feel it can possibly get past the o-ring and attacking the lube around the pins. Good cleaner other wise. IMO.
Chain wax is good stuff.
Old May 5th, 2009, 04:08 PM   #16
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
I use Rost Off then HHS2000. Seems to be working well, but as Kelly pointed out before it's too expensive and difficult to obtain for most people.
Old May 5th, 2009, 04:28 PM   #17
Kolya1981
Generic User Title
Kolya1981's Avatar
Motorcycle(s): Green 2008 Kawasaki Ninja 250R, Slate 2009 Triumph StreetTriple R
I use Fuchs Silkolene Pro Chain Synthetic Race. Great stuff, have to apply it every 300 miles or so. You can ride immediately after applying it, won't fling off.
2008 Ninja 250R Kawi Green - Bikelitez Fiberglass Undertail w/LED Turn Signals, Carbon Fiber Tank Protector
2009 Triumph StreetTriple R Matte Graphite - Arrow Titanium Exhaust, Belly Pan
Last futzed with by Alex; May 5th, 2009 at 04:35 PM. Reason: smaller pic
Kolya1981 is offline   Reply With Quote
Old May 5th, 2009, 04:38 PM   #18
Buffalony
Buffalony's Avatar
Yay. Another HHS2000 user. Great stuff though.
Post #20
http://www.ninjette.org/forums/showthread.php?p=39178
Old May 5th, 2009, 04:41 PM   #19
TnNinjaGirl
Ms. Personality
Hi everyone, I'm Corey and I am a HHS2000 user. Please don't judge me...
Old May 5th, 2009, 04:47 PM   #20
Buffalony
Buffalony's Avatar
That stuff is really called fuchs.lol
Old May 5th, 2009, 09:05 PM   #21
Lurkable
250Arrrgh!
Lurkable's Avatar
Motorcycle(s): 2009 250R, 2001 996
I've been using brake cleaner + towel/rag to clean off chain before applying Maxima.
Lurkable is offline   Reply With Quote
Old May 5th, 2009, 09:13 PM   #22
Sound Wave
Ramen Rider
Sound Wave's Avatar
i am using this one. i don't know if it is any good, but this is the only thing the shop i go to sells:
http://www.motorexusa.com/prod_detail.asp?id=98
http://www.motorexusa.com/prod_detail.asp?id=100
no problem with rust yet.
Old May 6th, 2009, 07:17 PM   #23
chess
Ninjette Afficionado!
chess's Avatar
Motorcycle(s): Red...the sexiest color.
Dupont Teflon Chain Lube ($7 at Lowe's).
http://www.webbikeworld.com/t2/motor...chain-lube.htm
chess is offline   Reply With Quote
Old May 7th, 2009, 02:36 AM   #24
Buffalony
Buffalony's Avatar
I hear good things about this stuff.
Old May 7th, 2009, 05:12 PM   #25
chess
chess's Avatar
Love it.
Been using it for about a year on my Virago with no problems. It's clear and doesn't get thrown around...plus it's cheap!
Old May 7th, 2009, 05:16 PM   #26
Buffalony
Buffalony's Avatar
Love it.
I assume it doesnt gather dirt either.?
Old May 7th, 2009, 07:23 PM   #27
chess
chess's Avatar
No. It dries more like a "wax" than like a "grease"...if that makes sense.
Edit to add: It also does a great job of CLEANING the chain while it's still in liquid form...then it dries into a clear wax. My chains look great. Apparently, they sell the same stuff for industrial chains (the kind that run all day).
It really is great stuff...cleans like WD-40 and dries like chain wax...plus it smells like coconuts!
Old May 8th, 2009, 03:50 AM   #28
Buffalony
Buffalony's Avatar
mmmmm. Coconut
Thanks. Wont be for another 600 miles or so but Im gonna check this out.
Sorry......
Removing rust from chain kennetht 2008 - 2012 Ninja 250R Tech Talk 5 November 2nd, 2013 03:07 PM
[motorcycle.com] - Valentino Rossi Forming VR46 Moto3 Race Team Ninjette Newsbot Motorcycling News 0 September 21st, 2013 09:50 AM
Getting rid of stubborn rust in the chain... dark_beaverezt 2008 - 2012 Ninja 250R Tech Talk 7 June 22nd, 2013 06:01 AM
Cola to remove chain rust? alex.s General Motorcycling Discussion 20 June 5th, 2010 07:39 PM
my '08 chain has rust spots! poo poo 2008 - 2012 Ninja 250R Tech Talk 7 January 1st, 2010 09:03 PM
