Old January 17th, 2013, 12:39 AM   #1
krolinked
Nerd
krolinked's Avatar
Motorcycle(s): Ducati Hyperstrada
HELP. WTF is This stuff?
Found it stuck to the top of my engine cover..... Idk what the heck it is? I do know its probably not supposed to be there.
It doesn't LOOK that steep. But you can go first...
krolinked is offline   Reply With Quote
Old January 17th, 2013, 05:30 AM   #2
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
Normally when you see that color, there is water in the oil. Never seen it stuck to the valve cover like that though. What does the rest of the oil/case look like?
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old January 17th, 2013, 06:07 AM   #3
tubarney
Motorcycle(s): Ninja 250r 2010 SE
or coolant. Maybe a head gasket leak. Check your coolant, what colour is it?
tubarney is offline   Reply With Quote
Old January 17th, 2013, 06:51 AM   #4
cuong-nutz
cuong-nutz's Avatar
What these guys said. If you live in a place with relatively high humidity and you run your bike for short periods where the bike does not reach operating temps to cook of the water, it will accumulate like that on the valve cover.... But what you have there is a whole lot.
Another possible culprit is the coolant tube looking at the rear of the cylinder head. Mine was leaking slightly and getting past the valve cover gasket. Just pull the tube out and replace the o-ring. The o-ring is the same small o-ring used for your oil filter change. You may also want to replace the 2 rubber dampeners that keep the coolant tube from rattling.
HalfFast Racing Team
Old January 17th, 2013, 11:29 AM   #5
bruce71198
bruce71198's Avatar
Thats definaitley moisture in the oil. What color is the oil in the sight glass? To many short trips and not letting the engine get up to temp can cause this too. As can a bad water pump seal.
Old January 17th, 2013, 11:34 AM   #6
coolant in the oil. usually means a blown head gasket.
Old January 17th, 2013, 12:59 PM   #7
krolinked
Nerd
krolinked's Avatar
When i was using my homemade carb sync thing. water was splashing into the vacuum lines. Could this be why? Everything else is normal color oil.
Old January 17th, 2013, 01:31 PM   #8
bruce71198
bruce71198's Avatar
Most likely not. Water ingested at the carbs would be sucked in and turned to steam in the combustion process and spit out the tail pipe. Its not uncommon to get moisture build up in the crank case. Usually when the engine warms up to operating temperature this moisture steams off and exits via the crancase breather. Short trips and infrequent trips hinder the ability of this process, thats why I asked about your driving habits. It may be normal for your situation if the oil in the sight glass isn't milky. Or it could be an early sign of what lies ahead.
Old January 17th, 2013, 06:53 PM   #9
tubarney
Unless the water is not making it into the combustion chamber, Maybe turning into steam before. Or it could be steam mixing with the oil after it leaves the chamber and not making it to the exhaust. Steam would have to be heavier than air so I doubt it would flow. Also depends on just how much water was splashing into those lines.
How old is the bike? Is it second hand? If it is it might have had a problem in the past which has been fixed but the build up of crap was not cleaned off.
Old January 18th, 2013, 01:24 PM   #10
NinjaBoyEddy
NinjaBoyEddy's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r special edition
Maybe its that oil **** you put into your homemade carb sync tool. Look grimmy like that **** lol
NinjaBoyEddy is offline   Reply With Quote
Old January 18th, 2013, 07:17 PM   #11
mgentz
Board Member
I'm going with water in the oil as well. my only other addition to this is that my chrysler motor keeps getting weird crap in the breather tube up front from the breather hose, but I doubt this to be your case.
Old January 20th, 2013, 02:56 AM   #12
krolinked
Nerd
krolinked's Avatar
The carbs sucked in water. Not just a splash; like full hoseline of water. It has never been like that. its even in the sight glass.
Old January 25th, 2013, 07:05 AM   #13
bruce71198
bruce71198's Avatar
If its in the sight glass there is a large quantity of coolant in the oil. I would be looking towards head gasket or water pump shaft seal. Any water injested into your carbs would be bumped out the tail pipe just like the air/fuel mixture that gets pumped through the engine.
Old January 25th, 2013, 08:22 AM   #14
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
No bueno is what that stuff is.
Old January 25th, 2013, 12:44 PM   #15
if you sent a bunch of water into the cylinder then you probably waterlocked the engine and blew out your head gasket now you are sending coolant through the head gasket gap into your oil, contaminating the oil.
Old January 25th, 2013, 03:09 PM   #16
bruce71198
bruce71198's Avatar
Did the water intake kill the engine ? And if so did it start back up after this event? Also how did your bike run after this happened?
Old January 26th, 2013, 03:13 PM   #17
krolinked
Nerd
krolinked's Avatar
It's all sorted out. I raced the bike and it worked fine.
Old January 26th, 2013, 11:18 PM   #18
tubarney
What was it?
After pulling apart a ninja 250 cylinder head what I said before seems pretty stupid. No water getting sucked in the carbs is going to make it into the top of the cylinder and do that.
My advice, take it to a mechanic, get the combustion chamber pressure tested or do it yourself. If thats all good it's a upper cylinder head gasket leak.
Also, check the rubber thing on the water pipe, my bike is only 2 and half years old and mines already cracked pretty bad
Old February 9th, 2013, 12:04 PM   #19
cuong-nutz
cuong-nutz's Avatar
So where did all that sludge come from?
Old February 9th, 2013, 12:57 PM   #20
Hey guys, so *apparently* some Kawi mechanics put... lithium grease on the valve shim buckets for lubrication instead of engine oil when doing valve adjustments This gets literally everywhere in the engine. Not sure if it's bad for it but it looks horrible
Old February 9th, 2013, 06:28 PM   #21
tubarney
Lithium grease! wtf? What they should be using is Molybdenum Disulfide assembly paste, looks like this.
If you use the correct stuff it won't do this.
[roadracingworld.com] - What's Better Than Cool Stuff? Cool Stuff For Free! Take The Ninjette Newsbot Motorcycling News 0 March 12th, 2014 12:20 AM
WTF!!!!!!!! LNasty Ride Reports 19 December 28th, 2013 02:29 PM
WTF Proflowers! cuong-nutz Off-Topic 7 February 14th, 2013 06:58 PM
WTF is going on here? Rekognize General Motorcycling Discussion 19 November 20th, 2012 02:51 PM
Wtf??!! nutless_neo General Motorcycling Discussion 14 September 3rd, 2010 09:35 PM
