Old December 2nd, 2020, 02:41 PM   #1
[motorcycle.com] - 2021 Ducati Monster First Look
Ducati revealed a new Monster with a 937cc engine, modern electronics and, in a departure from the line’s history, replaced the traditional steel trellis frame with an aluminum alloy frame.
The new model will simply be called the “Monster” with no displacement numbering, and it replaces both the air-cooled Monster 797 and liquid-cooled Monster 821 in Ducati’s lineup. The Monster 1200 and 1200 S will return for 2021 as the only holdover from the previous generation. Like the 1200, the new Monster is liquid-cooled, meaning there will no longer be any air-cooled Monsters in Ducati’s lineup.
The switch away from the steel trellis may be a bit of a shock to some purists, but in retrospect, the move is not a complete surprise. The trellis frames in the 821 and 1200 Monsters were noticeably smaller than in previous generations, mounting only to the engine heads. In this respect, the new Panigale V4-derived aluminum front frame is similar, with the added benefit of weighing 10 pounds less than the Monster 821’s frame.
Further contributing to weight reduction is a new glass fiber reinforced polymer subframe and a new double-sided aluminum swingarm design that resembles the unit on the Multistrada V4. According to Ducati, the new Monster has a claimed curb weight of 414 pounds, about 40 pounds lighter than the Monster 821.
With the new frame, Ducati had to reposition some components such as the radiator. This allowed the Monster to offer a 36° steering angle, 7° more than the Monster 821 lock to lock. Combined with a slightly shorter wheelbase, the new Monster should be more agile than the 821.
The new Monster is powered by Ducati’s liquid-cooled 937cc Testatretta 11° V-Twin engine with four desmodromic valves per cylinder. The Euro 5-compiant engine is similar to the one powering the SuperSport 950, claiming 111 hp at 9,250 rpm and 69 lb-ft. at 6,500 rpm. Those numbers are higher than the Monster 821’s claimed 109 hp at 9,250 rpm and 63 lb-ft. at 7,750 rpm, but Ducati claims there’s a 20% improvement in torque at 6,000 rpm. Ducati also says the engine requires oil services at every 9,000 miles while valve inspections are needed every 18,000 miles.
Ducati equipped the new Monster with an assist and slipper wet clutch, claiming a 20% lighter pull than the previous clutch design. An up-and-down quick shifter comes standard.
The electronics package includes cornering ABS, traction control, launch control and wheelie control. The Monster offers three selectable ride modes: Sport, Touring and Urban. Each mode adjusts the throttle response, traction control, ABS and wheelie control systems to suit the different riding styles.
A 4.3″ color TFT display shows the necessary on-board information. It also works with the optional Bluetooth-equipped Ducati Multimedia System.
The suspension system appears similar to the Monster 821’s setup, with a 43mm inverted fork with 5.1 inches of travel and a preload-adjustable rear shock offering 5.5 inches of travel. Twin Brembo M4-32 radial-mount four-piston monoblock calipers are matched with 320 mm discs up front while the rear wheel uses a 245 mm disc and two-piston caliper. Both clutch and brake levers are adjustable.
The Monster is equipped with an egg-shaped daytime running light that surrounds the main LED headlight. Ducati introduces a novel design for the turn signals, shaping them in line with the bodywork. The indicators light up in a swiping pattern, flowing outwards toward their respective directions. The signals are also self-canceling, a convenient feature that really should be more common-place.
Compared to the 821, the new Monster’s handlebars are 2.8 inches closer to the rider for a more upright riding position. The footpegs are positioned 0.4 inches lower and 1.4 inches farther back for a slightly less cramped leg position. The seat has a new shape and uses an exclusive foam material Ducati claims is more comfortable than the previous saddle. The standard seat height is 32.3 inches, but Ducati offers an accessory lower seat at 31.5 inches as well as a suspension lowering kit that further reduces the height to 30.5 inches.
The 2021 Ducati Monster will be available in three colorways: Ducati Red with black wheels, Aviator Grey with red wheels, and Dark Stealth with black wheels. Ducati will also offer a selection of sticker kits for further customizing the Monster’s look. There’s also a Monster Plus version that adds a flyscreen and passenger tail cover.
U.S. pricing starts at $11,895 for the Monster, which is $100 less than what Ducati asked for the Monster 821. The Monster Plus will set you back $12,195.
2021 Ducati Monster SpecificationsEngine TypeTestatretta 11°, V2 – 90°, 4 valves per cylinder, desmodromic valvetrain, liquid cooledDisplacement937 cc (57 cu in)Bore x Stroke94 mm x 67.5 mmCompression Ratio13.3:1Power111 hp (82 kW) @ 9,250 rpm (claimed)Torque9.5 kgm (93 Nm, 69 lb ft) @ 6,500 rpm (claimed)Fuel InjectionElectronic fuel injection system, Ø 53 mm throttle bodies with Ride-by-Wire systemExhaustPre-muffler and twin muffler, catalytic converter and 2 lambda probesTransmission6 speedPrimary DriveStraight cut gears, ratio 1.85:1Gear Ratios1=37/15, 2=30/17, 3=28/20, 4=26/22, 5=24/23, 6=23/24Final DriveChain, front sprocket z15, rear sprocket z43ClutchSlipper and self-servo multiplate wet clutch with hydraulic controlFrameAluminum alloy front frameFront SuspensionØ 43 mm usd fork, 5.1 inches of travelRear SuspensionProgressive linkage, preload adjustable monoshock, aluminum double-sided swingarm, 5.5 inches of travelFront WheelLight alloy cast, 3.5″ x 17″Rear WheelLight alloy cast, 5.5″ x 17″Front TirePirelli Diablo Rosso III 120/70 ZR17Rear TirePirelli Diablo Rosso III 180/55 ZR17Front Brake2 x Ø 320 mm semi-floating discs, radially mounted Brembo M4.32 monobloc 4-piston callipers, radial master cylinder, Cornering ABSRear BrakeØ 245 mm disc, Brembo 2-piston floating calliper, Cornering ABSInstrumentation4.3″ TFT colour displayDry Weight166 kg (366 lb), claimedCurb Weight188 kg (414 lb), claimedSeat Height“820 mm (32.3 in)
800 mm (31.5 in) (accessory low seat)
775 mm (30.5 in) (accessory low seat + low suspension kit)”Wheelbase1,474 mm (58.0 in)Rake24°Trail93 mm (3.7 in)Fuel Tank Capacity14 l (3.7 US gal)Number Of Seats2Safety EquipmentRiding Modes, Power Modes, Cornering ABS, Ducati Traction Control, Ducati Wheelie Control, Daytime Running LightStandard EquipmentDucati Quick Shift, Ducati Power Launch, 4.3″ TFT colour display, Full LED headlight and lighting system, Dynamic turn indicators, USB power socketReady ForDucati Multimedia System, Heated gripsWarranty24 months, unlimited mileageMaintenance Service Intervals15,000 km (9,000 miles) / 12 monthsDesmoservice30,000 km (18,000 miles)Become a Motorcycle.com insider. Get the latest motorcycle news first by subscribing to our newsletter here.
The post 2021 Ducati Monster First Look appeared first on Motorcycle.com.
Click here for full story...
[motorcycle.com] - 2021 Ducati Panigale V4 SP First Look Ninjette Newsbot Motorcycling News 0 November 19th, 2020 08:10 AM
[motorcycle.com] - 2021 Ducati SuperSport 950 First Look Ninjette Newsbot Motorcycling News 0 November 18th, 2020 02:54 PM
[motorcycle.com] - 2021 Ducati Scrambler Nightshift Ninjette Newsbot Motorcycling News 0 November 11th, 2020 05:30 PM
[motorcycle.com] - 2021 Ducati Multistrada V4 First Look Ninjette Newsbot Motorcycling News 0 November 4th, 2020 02:24 PM
[visordown.com] - Is this the 2021 Ducati Monster 821? Ninjette Newsbot Motorcycling News 0 September 16th, 2020 01:31 AM
