Old September 11th, 2014, 07:04 PM   #1
eramz
Motorcycle(s): 08 ninja 250
Installing a 49-state tank on a ca model 08 ninja 250
I deleted this. I searched and found the answer.
eramz is offline   Reply With Quote
Old September 11th, 2014, 07:06 PM   #2
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
Originally Posted by eramz View Post
Hello everyone, I bought a tank on ebay but the seller didn't mention it didn't have the 3 ports (CA model). I would like to install this tank on the CA model. Would there be any problem doing so? Thanks
you will not be able to keep the CA box on the left side of the bike.
Old September 12th, 2014, 12:05 AM   #3
eramz
changing a ca spec 08-12 ninja 250 to a 49 spec
I had to do this conversion since i decided to keep the tank.
Ill break it down so its easiest for someone with the same case.
1. Remove the box, separator, valve, hoses etc.
2. Replace the 3-way splitter with a 2-way splitter so the carb connects to the tank.
3. Keep that 3/4" hose and the gold keeper and connect it to the original location
4. Buy a hex bolt 1/2" x 1" and a 3/8" - 7/8" hose clamp at home depot
5. Insert the hose clamp on the 3/4" hose and insert the bolt
6. Tighten the clamp
7. At autozone buy vacuum elbow assortment for 5 dollars, use the 2-way splitter
8. Enjoy
Old September 12th, 2014, 09:03 AM   #4
xorbe
xorbe's Avatar
It's also covered on the twiki. The '06 I bought had the hardware removed, but they didn't tie up the hoses properly.
Reconnecting fuel tank, installing new levers, help? Sytiane 1986 - 2007 Ninja 250R Tech Talk 3 July 9th, 2014 07:15 AM
Installing a California tank on a 49 state bike tdecotis 1986 - 2007 Ninja 250R Tech Talk 4 September 8th, 2013 02:20 PM
Ninja 250 model LNasty General Motorcycling Discussion 7 August 9th, 2013 06:31 PM
FS: 2008+ RED Ninja 250R fuel gas tank (non-CA model) nst416 Motorcycle-related 22 May 24th, 2012 04:39 PM
08+ Ninja 250 CA model Gas tank port questions (Evap System Removal) abhijitz 2008 - 2012 Ninja 250R Tech Talk 2 April 3rd, 2012 09:59 PM
