Old January 4th, 2015, 06:56 PM   #1
buffaloejon
Motorcycle(s): '09 Ninja 250R
Bike starts, but starter clicks anyway?
So here's a weird problem. My bike turns over just fine, but the starter (or something) clicks while I'm hitting the start button. JUST had the carbs cleaned, and the dealer that fixed it killed my battery (so I got a new one), and I'm thinking they caused this problem too by trying to start the bike too much. Is there a solution/anything even wrong?
I've tried googling this problem, and it's just flooded with the starter clicking and NOT starting, literally couldn't find the same problem anywhere.
buffaloejon is offline   Reply With Quote
Old January 4th, 2015, 07:28 PM   #2
You may have to post a video of it to give us a better idea of what it's doing.
For starters (no pun...) I would check your battery. Not all new batteries are fully charged, and it may be right on the edge of having enough power to start it. Also make sure all of the battery connections are tight, and it has a firm ground to the frame.
After riding, let it sit for a few hours before checking it. It should read at least 12.7V. It could read more if there's still some additional charge on it from the alternator, but it shouldn't be less.
Then check it as you are cranking it over. You could leave the choke off so it will crank but not start to give you more time to read it. A strong battery should hold around 11V during cranking. Below 10V would suggest a weak battery (even if it's 12.7 before cranking).
If that checks out, there could be an issue with the starter, starter solenoid, or wiring.
Old January 4th, 2015, 08:02 PM   #3
buffaloejon
Thanks a ton for the help! I forgot to mention, it starts up STRONG, and I've ridden it for ~2 weeks now, definitely long enough for the battery to charge, and then started it back up and still the clicking.
So, ya think a video might help? I can try to grab one tomorrow
Old January 5th, 2015, 12:28 AM   #4
the relay solenoid on the starter normally makes an audible click when activated.
Old January 5th, 2015, 06:02 AM   #5
buffaloejon
But not a repeated clicking, like it would if the battery were dead, right? That's what's so weird, is that it clicks repeatedly, exactly like it would if the battery were dead, but it still turns over and starts up, stronger than it did before the carbs got cleaned.
Bike won't start using starter switch lilgreenninji 1986 - 2007 Ninja 250R Tech Talk 36 October 31st, 2012 08:28 PM
Starter bike help? akshay11 General Motorcycling Discussion 30 February 12th, 2012 07:34 PM
Friend needs advice on a starter bike. Jiggles General Motorcycling Discussion 10 August 7th, 2011 09:13 PM
New 2012 addition to the starter bike group gogoKawi General Motorcycling Discussion 16 July 6th, 2011 08:02 AM
[crash.net - WSBK] - Rea: The bike is just clicks away Ninjette Newsbot Motorcycling News 0 January 25th, 2010 03:24 AM
