Old January 12th, 2015, 10:35 PM   #1
psych0hans
psych0hans's Avatar
Exclamation Bike shuts off immediately after starting.
Like it says in the title, the bike shuts off immediately after starting. Giving it throttle doesn't help at all. I have been messing around a lot with the throttle off late getting it to snap back just right. I managed to do that by changing a few cables and making some adjustments but now the bike just won't run. Please help. Video below for reference.
p.s. my bike is the EU spec EFI model, not the carb'd one.
Old January 12th, 2015, 11:17 PM   #2
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
Faulty kickstand sensor?
Linkin is offline   Reply With Quote
Old January 12th, 2015, 11:19 PM   #3
psych0hans
psych0hans's Avatar
I've shorted that, also it is in neutral, so it shouldn't matter.
Old January 13th, 2015, 12:48 AM   #4
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
@psych0hans - Hello Hans,
sorry to read about your problem, maybe it's a help to look in the service manual "Section EFI" there you'll find some description about possible solutions.
I would think about a fuel-problem, but anyway from here it's not so easy to say.
Good luck
Old January 13th, 2015, 09:03 AM   #5
only firing one cylinder?
but it backfiring out of second? so must have fuel and air right?
sounds like no spark on a cylinder
Old January 13th, 2015, 10:45 AM   #6
EMSRacer07
EMSRacer07's Avatar
did u mess with the idle? maybe its closed too much. Maybe open it up again. Mine had this problem on ninja 300 when the idle was set too low. Could be that.
Old January 13th, 2015, 11:01 AM   #7
psych0hans
psych0hans's Avatar
I did mess around a lot with the throttle, so I'll try this first... Hope it works. Any other throttle setting I could do to try and rectify this?
Old January 13th, 2015, 11:35 AM   #8
Might want to confirm you have adequate fuel pressure. Does the pump have an audible priming sound when you turn on the key (not positive, but I think it should).
Plenty of fresh gas in the tank? Does it have a standard petcock with ON and OFF? If so, is the vacuum line to the petcock attached and in good condition?
Old January 13th, 2015, 11:51 AM   #9
EMSRacer07
EMSRacer07's Avatar
Like ^^^^ he said make sure fuel pump is priming and also when messing with the throttle cables did u unplug any of the electrical wires going to the butterfly's? Possibly the secondary ones. You should also hear the secondary butterfly's moving when the key is on.
Old January 13th, 2015, 01:06 PM   #10
Good point also.
I would figure out how to confirm that they are opening properly. As EMS noted, they may cycle, along with the pump, when the ignition is turned on.
Is there an idle speed screw you can adjust to bump the idle up and at least keep it running?
Bike not starting.... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 2 April 29th, 2012 07:33 PM
bike loses power and shuts off on freeway realmess 2008 - 2012 Ninja 250R Tech Talk 14 March 18th, 2012 03:37 PM
Bike not starting?! nightrider 2008 - 2012 Ninja 250R Tech Talk 32 September 5th, 2011 04:44 PM
Bike shuts off while riding coolbreeze 1986 - 2007 Ninja 250R Tech Talk 24 November 15th, 2010 10:54 AM
starting bike james250ninja 1986 - 2007 Ninja 250R Tech Talk 3 April 3rd, 2010 12:12 PM
