Old November 3rd, 2012, 01:03 AM   #2361
Kstorm21
Kstorm21's Avatar
Motorcycle(s): 2009 Ninja 250R SE
Originally Posted by psych0hans View Post
Congratz
Thanks! I'm super pumped! The suck ass part of it, I have to wait to take the MSF class till mid-Dec.
Kstorm21 is offline   Reply With Quote
Old November 3rd, 2012, 01:19 AM   #2362
Graugaard
Graugaard's Avatar
Motorcycle(s): Ninja 250r
Changing oil, today just motoroil, but in the upcoming month i will change fork oil, last owner hasn't done it for 3-4 years! So i think the new 10w oil will do a massive change since my forks are very hard pt, during the old oil!
Also going to change the coolant, and bought a new air filter (uni-filter).
Graugaard is offline   Reply With Quote
Old November 3rd, 2012, 11:33 AM   #2363
lolibater
lolibater's Avatar
Motorcycle(s): 2005 ZX6R, 2011 Sprint GT
I somehow broke my bike again! Probably somehow got air in the fuel lines
"The enemy is fear. We think it is hate, but it is fear." - Gandhi
lolibater is offline   Reply With Quote
Old November 3rd, 2012, 10:39 PM   #2364
jwollam
Had my chain guard painted and had a carbon fiber hydrographic done over the top of it, and then finally got my Evotech exhaust hanger installed it and removed my rear pegs! So much better!
Close up of the chain guard, I know it may not be for everyone, but I kinda dig it, the guy at the body shop that does the hydrographics told me it would be a big difference in price to get the OEM paint, but he was just at a hobby shop down the road from his place and they had a color that was really close, Good enough in my book lol.
jwollam is offline   Reply With Quote
Old November 3rd, 2012, 11:11 PM   #2365
thumper64
Not really. They know what tune they want to deliver. There's sensors for air temp, engine temp, and other various parameters.
They can do the math and program it to do what they want at varying temps/elevations/engine temps/throttle openings/load etc. The O2 sensor is just a back up.
It's not the only fuel injected bike that doesn't have and O2 sensor. Look at the 650, some Yamaha's, etc.
If other parameters are set correctly, the O2 shouldn't be needed. Typically you would tune a little rich to stay safe, and as the air temp and things change, there's a compensation built in to adjust the fuel.
When the ecu uses the O2 sensor your air fuel ratios bounce back and forth because it's trying to reach a perfect 14.7:1 mix. However, they normally use a narrowband sensor that only reads a hair above and below 14.7:1, so it keeps overcompensating. Without an O2 sensor, it adheres just to the map. Ideally, the computer would use a wide band sensor that reads between 10:1 and 20:1 AFR, but those are a lot more expensive and tend to be more sensitive and fail easier. Plus they're typically 5 wires instead of between 1 and 4.
As someone above said, changing the intake or anything for that matter, could change the mix or way the cylinders fill. Even two engines using similar parts can require different fuel maps to run right. So maybe your motor may have been extra rich or could have been close to being too lean, your elevation, the gas you got last time at the pump, etc can all effect it. Even whether you get Shell vs BP vs noname gas.
I have a Honda Civic with a fully built, boosted Acura Integra GSR engine running a piggyback engine management (Hondata S300) and I have a wideband O2 sensor wired into the ecu and keep it disabled because otherwise my air fuel ratios bounce around way too much and it runs poorly. Granted, I may not have all my parameters set perfectly right and an auto manufacturer is able to sort that out. I'm no expert, but I'm not unfamiliar to the world of EFI either.
Motorcycle noob, feel free to ignore me.
thumper64 is offline   Reply With Quote
Old November 3rd, 2012, 11:15 PM   #2366
thumper64
I was at a bike shop a couple weeks ago and was told that automatic transmission fluid is the same weight and is interchangeable with 10wt fork oil. May save you a few bucks...
Nice to see other people using Uni filters. The oiled foam filters filter the best and don't clog and get restricted near as quick as oiled gauze like the K&N filters.
Old November 3rd, 2012, 11:18 PM   #2367
Yes, and...?
Old November 3rd, 2012, 11:38 PM   #2368
thumper64
Yes, and...?
An O2 isn't really necessary. The air fuel ratios bounce around a lot, but there's things they can't really tune for like winter fuel mix vs summer mix. With gas that has ethanol, they vary the amount throughout the year and your air fuel ratios will vary. So....kind of agreeing with you and disagreeing with Kawasaki on their decision.
Old November 4th, 2012, 09:35 AM   #2369
Gotcha.
Old November 4th, 2012, 05:46 PM   #2370
Originally Posted by cuong-nutz View Post
Marred the **** out of my wheels trying to mount the bt-45s. I got pissed off trying to mount the rear tire. Those Bias ply sidewalls are stiff as ****! I'm going to take it to a guy tomorrow to mount it. Never again am I doing this. My poor wheels.
Sounds like an attempt I made in the past except you didn't end up with blood running down your chin like I did.
Old November 4th, 2012, 08:12 PM   #2371
lolibater
lolibater's Avatar
got more issues fixed with a member from BARF. Feel confident that I won't get stranded on this bike now
Old November 4th, 2012, 09:12 PM   #2372
psych0hans
psych0hans's Avatar
Your bike looks SWEET!!! Good work!!!
On a side note, would painting the rims green be overkill?
Old November 5th, 2012, 01:16 PM   #2373
jwollam
I really apprecaite the compliment thank you!
For my tastes painting the rims would be a bit much, I'm still debating on adding the green rim stripes, we'll see what the future holds.
Next up for the little ninjette is pod filters, remove the airbox, and a full area p exhaust. Hopefully my wife gives the thumbs up LOL
Old November 5th, 2012, 01:34 PM   #2374
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
Adjusted valves, installed new speedo/tach
Adjusted the valves. Tiniest engine I've ever worked on (since my model airplane days).
Installed new speedo/tach:
Last futzed with by Chicagobob; November 7th, 2012 at 11:01 AM.
Chicagobob is offline   Reply With Quote
Old November 5th, 2012, 01:39 PM   #2375
lolibater
lolibater's Avatar
Damn Bob. That looks freakin sick.
Old November 5th, 2012, 02:39 PM   #2376
Old Guy on a '08
Chris
Old Guy on a '08's Avatar
Motorcycle(s): BLACK!!! '08 250R
Here's the speedo/tach:
Sweet... is the speedo calibratable???? Where'd you get it.
Some roads are too good to waste on four wheels!
Riding in a car is like watching a movie...
Riding on a motorcycle is like being in one....
Old Guy on a '08 is offline   Reply With Quote
Old November 5th, 2012, 03:10 PM   #2377
Chicagobob
Chicagobob's Avatar
Trailtech.net. It's the Vapor speedo/tach. It operates off a wheel magnet and sensor, and you calibrate it to the rollout length of your wheel.
Old November 5th, 2012, 05:28 PM   #2378
cuong-nutz
cuong-nutz's Avatar
Wow. My tire installer guy had a hard time getting the bead to seat until I suggested the ratchet strap idea. Riding the 250 feels Wierd after having been riding the r6 for the past few days. The bike feels so low and the ergo feels like I'm riding a horse! Makes me want to raise the rear some.
Turn in feels Wierd with my tire size combo. The 120 up front makes the front feel heavy and takes more error but the rear seems like it turns in faster than the front. It's aN odd feeling.
HalfFast Racing Team
Old November 5th, 2012, 08:37 PM   #2379
Daks
Jersey Devil
Daks's Avatar
Peeled off more decals. Still got the big mofo on the bottom but my fingernails needed a break. xP
Daks is offline   Reply With Quote
Old November 5th, 2012, 08:56 PM   #2380
Pics:
http://www.ninjette.org/forums/showp...&postcount=131
Old November 5th, 2012, 09:02 PM   #2381
psych0hans
psych0hans's Avatar
Are you using wd40? You should... Peel corner, spray, wait. Repeat.
Old November 5th, 2012, 09:53 PM   #2382
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Checked tire pressure and lubed the chain on the 250R.
Installed and calibrated a Speedohealer V4 on the ZX6R, stock speedo had an error of +6.2% at 60MPH (actual, 64MPH indicated).
menikmati is offline   Reply With Quote
Old November 5th, 2012, 10:00 PM   #2383
Daks
Jersey Devil
Daks's Avatar
I aint got time for that ****.
The only thing that loosened the adhesive was the heat from the sun anyway. What I couldn't get up with my fingers I used a razor on. Rubbed the leftover glue off with 99% rubbing alcohol and a shop rag.
Takes a bit but there's no greasy mess to clean up later.
Old November 5th, 2012, 11:23 PM   #2384
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Finally my handlebars came in so I installed them and my grips!! :squee:
<-- Linky
Old November 5th, 2012, 11:27 PM   #2385
Bassman
Bassman's Avatar
Motorcycle(s): 1986 Goldwing, 1996 CR500, 2011 Ninja 250, 2009 Harley Heritage Softail, 1941 Suzuki Gerbil 250
Dude, you bike looks soooo sweet! I am partial to Kawi green, but all your mods as a total look rock :-)
I know there's a 7th gear here somewhere...
Changing to 15T/41T, now I'll get that 7th gear, lol.
Bassman is offline   Reply With Quote
Old November 6th, 2012, 09:23 AM   #2386
lolibater
lolibater's Avatar
I fixed my idle with only the finest of materials; zipties, threadlocker, electrical tape, and super glue.
Old November 6th, 2012, 07:46 PM   #2387
jwollam
Thank you, that's very nice of you to say!
I'm pretty partial to the Kawi green myself
I think she'll look much better once she's got an area P exhaust, and pod filters
Old November 6th, 2012, 08:17 PM   #2388
cuong-nutz
cuong-nutz's Avatar
Got the new clutch cable installed. Thanks to @cuz for giving me his old one!
Old November 6th, 2012, 08:20 PM   #2389
lolibater
lolibater's Avatar
drove around the block a 2k for 30 min straight to log low rpm AFR data :/
Old November 6th, 2012, 11:19 PM   #2390
Dragonracer76
Dragonracer76's Avatar
Rode to about 60 miles to school and the barber. Got my new Pirelli Sport Demons in... now to have them installed..
Beards make everything better. ATGATT
Dragonracer76 is offline   Reply With Quote
Old November 7th, 2012, 09:49 PM   #2391
Mehbs300
Mehbs300's Avatar
Motorcycle(s): 2013 NINJA 300
Adjusted pre-load and attached rego tube to chain guard.
Mehbs300 is offline   Reply With Quote
Old November 8th, 2012, 09:07 AM   #2392
lolibater
lolibater's Avatar
I decided to give her a rest for one day and took the car
Old November 8th, 2012, 09:10 AM   #2393
Miles_Prower
One Loyal Fox
Miles_Prower's Avatar
Motorcycle(s): 2012 Ninja 250R (RIP), 2011 ZX-6R
hahaha i did this too!! but only because she was worried about snow/ice.
scaredy cat..didnt even end up snowing!
My riding blog! Check it out if you are bored!aninjaridingpandabear.blogspot.com
8.10.12
Miles_Prower is offline   Reply With Quote
Old November 8th, 2012, 09:55 AM   #2394
lolibater
lolibater's Avatar
It was supposed to rain here today too....... looks quite sunny out the office window. Probably directly related to my vehicle choice, I'm sure.
Old November 8th, 2012, 02:05 PM   #2395
Old Guy on a '08
Chris
No bad decision should go unpunished!!!
Old November 8th, 2012, 02:18 PM   #2396
Old Guy on a '08
Chris
Old November 8th, 2012, 02:25 PM   #2397
Kstorm21
Kstorm21's Avatar
^^agreed! What's that? I looked it up and I know its a tube to hold/display the registration or something? Is that something you have to do?
Old November 8th, 2012, 04:18 PM   #2398
Mehbs300
Mehbs300's Avatar
Originally Posted by Old Guy on a '08 View Post
Rego (registration) tube is just a little plastic tube that bolts onto the bike. In Australia all cars/trucks/bikes need to have a registration sticker. Most come from the dealer in a bulky rectangular plastic case hung from the number plate. The tube just cleans things up a bit.
In the pic is how it come from the dealer, there is just a temporary paper slip in plastic case from the dealer while I was waiting for the sticker to be posted out by the transport dept.
Old November 8th, 2012, 04:23 PM   #2399
Old Guy on a '08
Chris
so they do believe the bike is registered if there is a plate on it, they have to se to "rogo" too!!!???
Old November 8th, 2012, 04:32 PM   #2400
Mehbs300
Mehbs300's Avatar
Yeah, it shows the date that registration has been paid up to along with vin# and details of the bike.
I'm not sure how it works in the U.S. but from movies the cop pulls someone over and always asks for "licence and registration"
Here they just ask for "licence"
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
