Old January 13th, 2011, 02:57 PM   #1
Colezombie
Colezombie's Avatar
rear suspension settings?
I was reading the reviews of the 08+ 250s in the stickys above. In the review from a guy named gary, he noted that he was 170lbs and had his suspension set on #3. I'm quite short and weigh roughly 100lbs. Is there a better setting for me than stock?
I bought my ninja from a friend who is most likely in the 140lbs range..
'09 250R
woodcraft clip-ons
2 bros slip-on
Colezombie is offline   Reply With Quote
Old January 13th, 2011, 02:59 PM   #2
at 100lbs, I would suggest the lowest setting on the shock.
Old January 13th, 2011, 04:00 PM   #3
Agreed.
Old January 13th, 2011, 04:05 PM   #4
here's a link on how to adjust the rear shock preload...
http://www.ninjette.org/wiki/Setting..._Shock_Preload
Old January 13th, 2011, 05:17 PM   #5
Colezombie
Colezombie's Avatar
Thanks guys, so would the lowest setting make it not so firm?
and how do I know which setting mine is on currently?
'09 250R
woodcraft clip-ons
2 bros slip-on
Old January 13th, 2011, 06:50 PM   #6
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
The lowest would make it less firm. To find out where yours is, just take a look at it. You want it on the lowest setting, like Kelly had said.
I keep mine on th highest setting. I read somewhere on the site that it's better for the curvs. I haven't been able to test this for myself due to this white stuff all over the ground. Blah..
scotty is offline   Reply With Quote
Old January 13th, 2011, 09:36 PM   #7
Colezombie
Colezombie's Avatar
haha, yeah I havent been able to ride either lately, but if you say highest is better for curves, then I may keep it high.. I love taking curves so if that helps ill keep it that way.. but Ill check it out and do a little testing.
thanks for the info and help!
'09 250R
woodcraft clip-ons
2 bros slip-on
Old January 13th, 2011, 09:52 PM   #8
they make the shock preload adjustable to suit a range of riders. while a firmer setting does help the suspension during faster cornering speeds, the feature to adjust is to match the shock to the rider's weight and riding style.
My recommendation is to start at the softest setting, then bump it up after a few rides, then keep doing so until you feel the shock is too stiff, then back it down one notch.
Old January 13th, 2011, 10:00 PM   #9
scotty
scotty's Avatar
Well said. All last year I kept mine on the 2nd setting. I weigh only 120-125pounds, but the wife likes to ride with me at times so the 2nd setting seemed ideal.
Old January 16th, 2011, 07:33 PM   #10
Colezombie
Colezombie's Avatar
Sounds good to me, Ill give that a shot
'09 250R
woodcraft clip-ons
2 bros slip-on
Old January 17th, 2011, 08:47 AM   #11
wyckedflesh
wyckedflesh's Avatar
Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion)
if your adding a passenger, you should be bumping the preload up at least 2 positions. Its harder for us fat gits to do this, so usually I don't ride 2 up or the front end gets light way to quickly and makes cornering sketchy.
2009 KLE650 LSL bars, Full Muzzy PC-V
1995 900SS/CR mildly modified
wyckedflesh is offline   Reply With Quote
[sportrider - latest stories] - Suggested Suspension Settings Updated Ninjette Newsbot Motorcycling News 0 December 1st, 2010 01:50 PM
[sportrider - tech] - Suggested Suspension Settings Ninjette Newsbot Motorcycling News 0 April 13th, 2010 04:00 AM
[sportrider - tech] - Suggested Suspension Settings Ninjette Newsbot Motorcycling News 0 March 29th, 2010 11:40 PM
[sportrider - latest stories] - Suggested Suspension Settings Ninjette Newsbot Motorcycling News 0 November 24th, 2009 11:50 AM
[sportrider - tech] - Suggested Suspension Settings Ninjette Newsbot Motorcycling News 0 January 16th, 2009 01:23 PM
