August 11th, 2022, 01:02 PM | #1 |
[motorcycle.com] - MO Tested: Michelin Road 6 Tire Review
While magazine editors and track riders may wax poetic about the leaps in performance of the latest super-grippy sport and track tires, the vast majority of sport-focused street riders spend their money on sport-touring rubber. Why? Well, two reasons, actually. First, once you look beyond the arid Southwest where the bulk of the U.S. motorcycle industry resides, riders have to deal with rain, making the way tires handle in the wet of great importance. Then there’s the fact that sport-touring tires offer almost the same level of grip as their sportier siblings – at street temperatures – while offering significantly better longevity. (At lower temperatures, sport-touring tires can offer more real-world grip than even the stickiest of sporting rubber, which are designed to work their best at elevated temperatures.) With the release of the Michelin Road 6 sport-touring tires, Michelin claim an increase in both wet grip and wear characteristics when compared to their precursors, the Michelin Road 5.
Michelin Road 6 Tires</p>Michelin claims 15% better wet traction and 10% better wear. Our experience says these claims are true. + Highs</p>
The Recipe The headlining claim in the announcement of the Road 6 tires was that they offer a 15% increase in wet grip. Michelin says this is the result of both updating the rubber compounds and refining the tread design. Silica has been known for its wet/cold weather grip for some time, but it hasn’t always played well with tire durability in dry, warm weather. The improvements in the durability of the silica compound comes from a combination of changes to the compound itself and the altered tread design.* When the Michelin Road 5 was released, its wet grip was credited to the development of its X-Sipe technology. Essentially, the smaller grooves in the tire open up to a wider space as you go deeper within the rubber compound, and as the tire wears, the widening of the grooves allow for the tread to displace similar amounts of water. (You can read an in-depth explanation of it here.) Next, dubbed Michelin Water Evergrip Technology, the void ratio, the ratio of grooving to the rubber on the tire’s tread, was optimized to improve wear in both wet and dry conditions. Michelin claims that this, when combined with the X-Sipe technology, is not only responsible for the increase in wet grip, but also for the consistent behavior of the tires even when worn. The big change for the front tire’s construction is the way the harder, center compound (blue) goes under the softer compound all the way to the sidewall to give better stability on turn in. Riders who are familiar with the Road 5s, will remember that the front tire used Michelin’s 2CT carcass structure on the front and the 2CT+ on the rear. With the Road 6s, the front now receives the 2CT+ treatment, meaning that the firmer center tire compound now extends under the softer compound used on the sides. This additional support from the harder compound is said to contribute to front tire stability (thanks to less flex in the contact patch) when entering corners.* As with the Road 5 tires, the Michelin Road 6 tires will come in two versions. Most bike applications will use the standard Road 6; however, the beefier Road 6 GT tires are designed for the additional forces generated by larger, heavier, and more powerful grand-touring motorcycles (such as the BMW K1600 GT/GTL). To handle the additional stresses experienced by the tires, they get an additional ply sandwiched between the two plies used on the standard Road 6. This Michelin Reinforced Radial-X EVO ply helps prevent tire deformation during cornering.* What makes a Road 6 GT a GT? The additional ply (white) added to handle the additional loads heavyweight sport-touring bikes generate. The Result Although I don’t have a set of Road 5s to do a direct comparison, the Road 6 tires, when mounted on my KTM 790 Duke, appear to have a slightly rounder profile. My memory from riding the tires supports this, but the change is slight, with the turn-in being a bit more predictable (which is not to say that the Road 5s fell into corners). While not as snappy steering as hyper-sport tires, the Road 6s handled every type of corner I threw at them in my local SoCal stomping grounds. Constant-radius, decreasing-radius, off- or positive-camber, single, or linked corners, the Road 6 steered precisely and allowed mid-corner corrections without complaint. The speeds I was riding – as were the roads – were the same as the ones I used when running the more sporty Michelin Power RS tires. Frankly, at street speeds, I don’t think I could tell the difference between the two tires. When leaned over on their edge, the Road 6 tires feel just as planted – again, on the street. However, unlike the Power RS (or their replacement the Power Cup 2), I wouldn’t run the Road 6s at a track day.* As you can see, I haven’t been shy about taking the Road 6 rear tire right up to its edge. The section of the tread without the grooves as you near maximum lean plays an important role in this level of grip. But I’m burying the lede with the Road 6’s wet weather performance. During my testing, despite the drought conditions in California, I got a chance to test the tires in some pretty epic rains. The conditions ranged from merely wet pavement to actively rained on pavement to pavement with varying levels of standing water (up to several inches deep). Taking the Road 6s out on a rainy canyon ride revealed excellent traction, allowing leans as far as I was willing to test (which was reasonably far by the end of the ride). The only time the tires squirmed was when the water was actively running from one side of the road to the other and had washed some barely visible sand onto the surface. I came back from my wet weather testing extremely impressed with the tires and would recommend them for people who frequently ride in the rain. And the longevity claims? All I can say is that after 2,500 miles of sporty riding, the Michelin Road 6 tires still look pretty dang new. Surprisingly new, in fact. I haven’t babied them, either. Michelin Road 6 Available SizesFrontRear110/70ZR17 54W140/70ZR17 66W120/70ZR17 (55W)150/60ZR17 66W120/70ZR17 (58W)150/70ZR17 (69W)120/70ZR18 (59W)160/60ZR17 (69W)110/80ZR19 (59W)170/60ZR17 (72W)120/70ZR19 (60W)180/55ZR17 (73W)190/50ZR17 (73W)190/55ZR17 (75W)The Recommendation Since I primarily ride my 790 Duke on canyon roads, I have previously run the stickiest rubber I could get. Unfortunately, that meant that my No-Mar Tire Changer was getting lots of use. The Michelin Road 6 tires have made me rethink this approach because of the similarity in street performance and the longevity I have experienced so far. Michelin Road 6 tires come in a wide variety of sizes to fit lightweight sporty bikes to heavyweight sport-touring rigs. Front tire prices range from an MSRP of $262-$289, and the rear MSRP is $291-$401. So, Road 6 tires aren’t cheap, but if they continue to wear as well as they are for me now, the investment appears to pay off in the long run. If you’ve had any experience with Road 6s, let us know in the comments.* FAQ Are Michelin good tires? Michelin tires are ranked among the top premium motorcycle tires available. If you doubt their quality and commitment to new technology, consider this: Michelin provides the spec tires to MotoGP as a means of furthering their development. If Michelin tires are good enough for the fastest riders in the world, we mere mortals will probably be quite happy with their performance, as the review above demonstrates. When did Michelin Road 6 come out? The Michelin Road 6 tires were first available to the public on January 1, 2022. What is the difference between the Michelin Road 6 and the Road 6 GT? The difference is the inclusion of an extra ply in the rear tire to handle the extra weight of heavyweight sport-touring motorcycles. The compounds and tread design used in the tires are identical. Additional Resources Best Sport-Touring Tires To Take You The Long Way To Anywhere Michelin Introduces The New Road 6 Tire For Sport Touring Motorcycles Black Magic: Motorcycle Tires Michelin Motorcycle Tires: Everything You Need To Know We are committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works. Become a Motorcycle.com insider. Get the latest motorcycle news first by subscribing to our newsletter here. The post MO Tested: Michelin Road 6 Tire Review appeared first on Motorcycle.com. Click here for full story...
[motorcycle.com] - MO Tested: Michelin Road 5 Tire Review | Ninjette Newsbot | Motorcycling News | 0 | February 26th, 2018 11:22 AM |
[RoadRUNNER] - Michelin Announces Road 5 Motorcycle Tire | Ninjette Newsbot | Motorcycling News | 0 | November 14th, 2017 07:31 AM |
[motorcyclistonline] - Michelin Power RS Motorcycle Tire Review | Ninjette Newsbot | Motorcycling News | 0 | April 17th, 2017 03:10 PM |
[motorcycle.com] - Michelin Anakee Wild Tire Review | Ninjette Newsbot | Motorcycling News | 0 | April 4th, 2016 04:50 PM |
[motorcycle-usa.com] - Michelin Power SuperSport Tire Review | Ninjette Newsbot | Motorcycling News | 0 | April 26th, 2013 01:50 AM |
