August 28th, 2010, 07:11 PM | #1 |
Did you get him?
Join Date: Jul 2010 Motorcycle(s): 2009 2fiddy SE Posts: 54
Oil change issue?
I just did a oil change, Used a K&N filter changed both O rings and filled it up using the recommended amount. I look at the window and nothing is showing up.
What could this be? Bike has 400 miles on it this is my third oil change first time this has happened. |
August 28th, 2010, 07:20 PM | #2 |
Join Date: May 2010 Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color Posts: 285
Is it standing straight up or on the side stand, stand it up straight then look.
"Well you know, for me, the action IS the juice" |
August 28th, 2010, 07:22 PM | #3 |
Did you get him?
It was 100% vertical just like it says in Kkims oil change instructions, This is the first time i have used the K&n filter could that have something to do with it?
Edit If i tilt the bike to the right just a bit the window starts to fill up. Which leads me to think i dont have enough oil. But i used the recommended amount and dont want to over fill it. |
August 28th, 2010, 07:30 PM | #4 |
I trust my gut, I don't like that little window, I use K&N filter also, as long as I have put the proper amount of oil in, the engine sounds right, and there is no leak I trust it, the window is just a little hokey for me.
August 28th, 2010, 07:41 PM | #5 |
Did you get him?
I am almost positive i put the correct amount in.
August 28th, 2010, 07:43 PM | #6 |
How much did you put in? What oil filters did you use in your last two oil changes?
August 28th, 2010, 08:03 PM | #7 |
Did you get him?
Gosh now i am all confused. I put in 1 qt and put in another one to the 300ml left line.
Which means if my math is correct. And tell me if this is wrong. The recommended 1.8 Quarts is equal to 1703.44 Milliliters With each quart containing around 946 Ml My math tells me i put in with 300ml left in the bottle around 1592 ML which comes out to 1.68 Quarts. Does this sound right? lol i think i am just thinking about this to much.... |
August 28th, 2010, 08:10 PM | #8 | |
Small Bike Abuser
Join Date: Aug 2010 Motorcycle(s): 2010 Ninja 250R SE, GSX650FK8, DL650K5, CH80K2, AN400K7, SH150i Posts: 95
August 28th, 2010, 08:11 PM | #9 |
you're thinking too much. fill up the oil till it's in the sight glass window with the bike sitting level and vertical and you're done.
August 28th, 2010, 08:23 PM | #10 |
Did you get him?
August 28th, 2010, 08:25 PM | #11 |
remember to start the bike up after you do that and let the oil circulate. stop the engine and check the level again after a few minutes. top off if needed.
August 29th, 2010, 11:11 AM | #12 |
Join Date: May 2010 Motorcycle(s): Totaled 2010 Ninja 250r :( Posts: 77
I have done 4 oil changes now and I've seen this same issue. Like another said, after the initial fill, I idle the bike for about 2 minutes to circulate. Then I shut it off, wait 2 minutes, then check the oil. After the initial fill it usually is not showing in the sight glass (yes, while vertical).
After this I go through a process of adding 100 ml at a time, then repeating the whole idle & shut off exercise. It usually takes about 3-5 cycles of this to get the sight glass showing oil. Also BTW I consider it done when the oil is a little above the lower limit line. I find out that a day later (for some reason) the oil is higher in the sight glass, which would still put it below the upper limit line. One time when I was changing it I was doing the same math thing as you and it started to drive me crazy, so I just ended up relying on the sight glass... |
August 29th, 2010, 04:31 PM | #13 |
Just curious....why?
Currently own: 2006 H-D XL1200L, 2009 Kawasaki Ninja 250R Previously owned: 1980 Suzuki GS450, 1996 Honda VLX 600, 2000 Ducati 750 Monster Dark, 2004 Buell XB9S, 2000 BMW R1100SA |
August 29th, 2010, 04:47 PM | #14 |
Heck, by some standards on this board he should be to his 8th or 9th oil change by now. (personally, I go by the manual on this one...)
Is it normal for oil to increase a bit in the crankcase after an oil change? | cadd | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 15th, 2014 08:38 PM |
Synthetic oil at 300 mile oil change? | anacron | 2013 - 2017 Ninja 300 Tech Talk | 14 | July 29th, 2013 04:58 PM |
Oil drain plug gasket for oil change. | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 10th, 2012 01:00 PM |
change oil filter, without draining oil? | peter330 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 30th, 2010 01:08 PM |
First ever oil Change! | Samer | 2008 - 2012 Ninja 250R Tech Talk | 2 | December 31st, 2009 07:49 PM |
