Old May 2nd, 2013, 08:02 AM   #1
cuong-nutz
cuong-nutz's Avatar
What's this odd sound?
Valves tapping?
Also running on 87 octane. I forgot to bump it up. Looks like I need to bump up the mains as well. Currently using 40 pilots and 110 mains with stock air box. SAE 30 oil.
edit:
HalfFast Racing Team
Last futzed with by cuong-nutz; May 2nd, 2013 at 09:19 AM.
Old May 2nd, 2013, 08:32 AM   #2
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
do you have a vid, or a similar vid of the sound or at least describe the sound?
Old May 2nd, 2013, 08:52 AM   #3
from listening to your sound from here at my desk, i would say that sound is DEFINITELY an air conditioner.
Old May 2nd, 2013, 08:53 AM   #4
lgk
running lean?
used 112 jets when i had a k&n filter and carbs at sea level.
you should using at least 115s at the minimum.
Old May 2nd, 2013, 09:18 AM   #5
cuong-nutz
cuong-nutz's Avatar
Forgot to post it
Old May 2nd, 2013, 09:23 AM   #6
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Not 100% which sound but maybe cam chain? maybe your CCT is loosing tension? When you were on the right side of the bike by the Cam Chain i could hear it but again not sure if that is what you are talking about and it didn't sound terrible.
Old May 2nd, 2013, 09:33 AM   #7
it sounds like 2 things. your cam chain hitting the chain guide. probably stretched. and also one or two of your intake valves is way loose. like WAY loose.
also there is another sound... not sure what it is... maybe the clutch or crank. its an odd wobble. hard to tell, could be background noise.
Old May 2nd, 2013, 09:48 AM   #8
cuong-nutz
cuong-nutz's Avatar
Damn, looks like I have to check the clearances again.
Old May 2nd, 2013, 01:37 PM   #9
cuong-nutz
cuong-nutz's Avatar
I think I found the problem. Not timed:
Because I forgot to install this:
Found it missing and found it under my pile of rags.
Old May 2nd, 2013, 02:34 PM   #10
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Are you missing some teeth on the cam sprocket/gear or just the way it looks?
Old May 2nd, 2013, 02:40 PM   #11
dino74
dino74's Avatar
110 Mains with stock air box seems way too rich.
Most people I know are running 92 to 98 with stock airbox.
CVMA #55
Old May 2nd, 2013, 03:39 PM   #12
bahahahahahah! nice one.
Old May 2nd, 2013, 04:40 PM   #13
mgentz
Board Member
ouch. Hopefully you didn't ruin anything.
Old May 2nd, 2013, 04:59 PM   #14
cuong-nutz
cuong-nutz's Avatar
I'm bored out to 265cc
It's just the shadow that makes it look like it's missing teeth.
It was an epic fail.
yeah I should be ok it just jumped a tooth on both cams. Anymore might have been bad.
Old May 2nd, 2013, 05:06 PM   #15
i *think* with this engine skipping a tooth slowly like in your case, it will stop firing before the valves hit. so you would have to jump timing with the bike in gear & moving or use the starter to bend a valve from bad timing right? maybe wrong with this engine.
Old May 3rd, 2013, 04:55 PM   #16
cuong-nutz
cuong-nutz's Avatar
Damn the noise is still there and I'm having trouble with the transmission shifting.?!
Old May 3rd, 2013, 08:29 PM   #17
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
bump
THE GOOD LIFE
cuz is offline   Reply With Quote
Old May 5th, 2013, 06:32 PM   #18
cuong-nutz
cuong-nutz's Avatar
I'm thinking my chain is stretched. I'll have to measure it tomorrow. The cam chain guide I forgot was on the exhaust side but it should be okay since the exhaust side chain is under tension since the engine rotates counter clockwise. Odd thing is why does the FSM say to rotate clockwise? I attached the section 2-22 where it states so.
Either way, I am willing to attempt to replace the chain without splitting the case. What prevents you from replacing the cam chain is the guide/stay loop thing. I could grind at it and cut it out to where the chain can get through and loop around.
Only issue is I'm having shifting issues. I can shift into first but afterwards I hit a hard false neutral trying to shift into second and same goes trying to get into first.
Last futzed with by cuong-nutz; May 5th, 2013 at 08:06 PM.
Old May 5th, 2013, 07:36 PM   #19
mgentz
Board Member
I believe you rotate clockwise to keep the flywheel bolt from coming undone.
Keep us updated on the progress.
Old June 3rd, 2013, 03:56 PM   #20
cuong-nutz
cuong-nutz's Avatar
Well I found the source of the noise.........
The pistons were slapping against the exhaust valves and head. 1-2 tooth retarded on the exhaust cam? I'm surprised the motor even ran as it is which leaves me wondering if the exhaust valves are now bent. I didn't check piston to valve to head clearances before closing everything up
Now I got to recheck all the bearings to make sure I didn't damage them.... Joyous me.
Old June 3rd, 2013, 05:04 PM   #21
mgentz
Board Member
How did you end up 1-2 teeth off? Did you line everything up per the manual?
Sorry to see but glad you found it early.
What is this sound? Is this what out-of-spec valves sound like? CZroe 2008 - 2012 Ninja 250R Tech Talk 24 November 15th, 2021 05:48 PM
Odd sound after chain tightened JohnnyBravo 2013 - 2017 Ninja 300 Tech Talk 18 October 7th, 2013 11:44 AM
Odd Atiaga 1986 - 2007 Ninja 250R Tech Talk 8 April 14th, 2013 07:04 PM
Odd sound, not major NDspd 2008 - 2012 Ninja 250R Tech Talk 7 January 16th, 2012 02:52 PM
Odd sound (don't worry, NOT gas tank) :D Seattle_Chris 2008 - 2012 Ninja 250R Tech Talk 4 March 15th, 2010 01:36 AM
