August 17th, 2016, 11:50 AM | #1 |
Join Date: Jul 2016 Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6 Posts: 210
What do we think of Emgo Shorty slip-ons?
I regularly see them on eBay for $50 for a pair of them, but I'm curious if anyone has any experience with them.
I've watched videos to see how they sound, and they sound pretty bad-ass. It would go perfectly with the streetfighter/rat bike aesthetic that I'm going for with my Ninja 250. This video is my inspiration. I'm not quite sure if the mufflers in the video are Emgo Shortys, but they look very similar. |
August 17th, 2016, 12:00 PM | #2 |
The way they sit looks hideous.
August 17th, 2016, 03:47 PM | #3 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Looks good to me, I'd mount them straighter back instead of angled down though
August 17th, 2016, 06:40 PM | #4 |
Join Date: Dec 2015 Motorcycle(s): 2007 Hoodrat 250 Posts: 242
Shorty GP is similar for the same price.
Different angle, but it's on a newgen so who knows how it'll hang on pregen.
"Brah, you can't be looking like that on a 250, brah. You gotta mod a 250, brah. It's like the hachi-roku of bikes." |
August 21st, 2016, 06:39 PM | #5 |
August 22nd, 2016, 01:00 PM | #6 |
That makes sense, personally I'd be tweaking the pipes
August 22nd, 2016, 01:04 PM | #7 |
August 22nd, 2016, 01:17 PM | #8 |
Different strokes man
September 11th, 2016, 02:17 PM | #9 |
So I got around to installing these and holy **** they're loud. Probably not quite Harley loud, but certainly not subtle. Even with earplugs they're pretty loud.
Not sure if I'll stick with them--I mean, they're way better than the stock mufflers, which make the Ninja 250 sound like a glorified moped at best, but the new shorties will take some getting used to. Also can't really go back to the stock mufflers since I had to cut off the pipe section from the muffler (per the BCB install video), but I also don't want to spend a lot of money on aftermarket (hence why I got the Emgo Shorties at $25 a pop). EDIT: Here's a quick video sample of how they sound. I was so afraid of going over 7k rpms because they were soooo much louder than I was used to with the stock mufflers. https://youtu.be/2LHoQgYI6p4 |
September 11th, 2016, 03:51 PM | #10 |
And I thought stock pregen mufflers sounded really nicely quiet.
September 11th, 2016, 05:49 PM | #11 | |
I've been considering getting the trumpet mufflers that BCB sells. They're essentially just modified Emgo mufflers that have way better baffling, but at $200, even that's a bit more than I want to spend. |
September 12th, 2016, 11:49 AM | #12 |
Join Date: Aug 2016 Motorcycle(s): Triumph Bonneville, Ninja 300 Posts: 204
I had a set on my Bonneville once upon a time. Almost as loud and as little back pressure as running open pipes. If you granny shift in residential areas, you probably won't piss anybody off. Once you get into the power band, it'll be loud though. You'll need earplugs.
Let he who has never re-used a crush washer cast the first stone... |
September 12th, 2016, 01:04 PM | #13 |
Aftermarket Slip-ons | Ghostt | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 17th, 2016 12:16 PM |
Top 5 or 10 slip-ons? | fmx | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 29th, 2013 02:46 PM |
Slip Ons | YMCMB | General Motorcycling Discussion | 5 | August 7th, 2012 04:23 PM |
slip ons | play2pwn | 2008 - 2012 Ninja 250R Tech Talk | 28 | June 11th, 2011 12:54 AM |
[motorcyclistonline] - Gear - Superbike Slip-Ons | Ninjette Newsbot | Motorcycling News | 0 | July 9th, 2010 07:30 PM |
