Old February 11th, 2010, 09:52 PM   #1
Poltart
Motorcycle(s): 09 250R
What resistor should I get for my LED's?
I am currently installing the Sportisi undertail kit, and for the LED turn signals I need a resistor, anyone know what OHM's it should be or anything?
Thanks in advance for the help.
Poltart is offline   Reply With Quote
Old February 11th, 2010, 10:02 PM   #2
randomwalk101
self wrencher
randomwalk101's Avatar
Elec flasher will solve the prob
Posted via Mobile Device
Old February 11th, 2010, 10:04 PM   #3
Poltart
Elec flasher?
Sorry I don't know much about electronics, just basics. I had no idea that a resistor was needed until Matt from Sportisi told me. . .
Old February 11th, 2010, 10:07 PM   #4
Snake
Snake's Avatar
Send an email to Matt, he should be able to reccomend the correct resistor.
Old February 11th, 2010, 10:13 PM   #5
Poltart
Yeah I did that, he does not know himself what OHM it should be or anything. . .
Old February 11th, 2010, 10:20 PM   #6
Snake
Snake's Avatar
Onother good source would be one of our members - ninja250. He is an electronics genious. Very nice guy. Give him some time to respond as he has a few projects he is doing and lots of people askinf for advice.
Old February 11th, 2010, 10:25 PM   #7
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
If you need a resistor for a single regular 12v LED, start about 470ohms.
You can adjust brightness by going down in value for brighter and up in value for dimmer. You'll likely end up going lower. If you go too low in value, you will fry it. So be careful.
I have no idea if this applies to motorcycle LED tail lights or not.
This would just apply to a regular LED plugged into a 12 volt supply.
So in essence, you should be safe plugging it in with a 470ohm resistor for sure. Unless it's more than one LED and draws more load than 20mah or something like a regular LED does.
What is the current rating of the LED's and how many of them are there? This will give us the current load requirement, for which you can set a resistance since you know you'll be running 12v.
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old February 11th, 2010, 10:46 PM   #8
Poltart
I am not sure what you mean by current rating of the LED's. But there are 4 per signal.
Old February 12th, 2010, 06:48 AM   #9
randomwalk101
self wrencher
What he meant was run to auto store and by a two prong elec flasher
Old February 12th, 2010, 07:51 AM   #10
jonthechron
Motorcycle(s): magHitVE
+1
It would be way simpler to find an electronic flasher relay. The one you need has 2 leads, so I recommend you go to the Napa and pick up a 2 lead electronic flasher relay, instead of adding resisor in all 4 corner of the bike and having to cut all 4 turn signal wires.
If you really want to add the resistors, then you must provide us with the current rating, usually displayed in (mA) (milliamps) or you might also see it in amps (A) this info is probably on the packaging or maybe not at all... GL
Once this info has been provided we can then calculate the proper value of the resistor.
Old February 12th, 2010, 09:09 AM   #11
HKr1
IC2(SW)
HKr1's Avatar
http://www.greggscustoms.com/instruc...istor_Inst.pdf
Old February 12th, 2010, 06:33 PM   #12
kevlar250
kevlar250's Avatar
Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1
If you're not doing LED's in the front your stock flasher might be fine. If not, get an electronic LED flasher. If adding load resistors you'd only need them in the front or the back, not all 4, as the wire is the same. I highly recommend NOT adding the resistors as they get fairly hot and the LED flasher shouldn't cost much more than the resistors, and a lot easier to install.
kevlar250 is offline   Reply With Quote
Old February 12th, 2010, 09:00 PM   #13
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
I can't help but to think that someone might be able to find resisters rated with the correct wattage to handle the heat if they did decide to go that route.
1/4 watt resistors from radio shack won't hang with a 12v, 10a system (120w) and LED's drawing an amp or two.
LMFAO!
Weaksauce
Old February 12th, 2010, 11:32 PM   #14
kevlar250
kevlar250's Avatar
Sure, a 10 ohm 10w would work fine but you still must mount it where it can get air and not touch other wires, I'm just saying that an LED flasher is the best way to solve "no-flash" syndrome.
Old February 18th, 2010, 12:25 PM   #15
DarkNinja52
DarkNinja52's Avatar
Motorcycle(s): Red 09 Ninja 250r aka Sheila (RIP), Red '10 Ninja 250r aka Sasha (Sold), White '13 Ninja 300 (To be Purchased)
Hmmm... from what i've read... and have learned, get an electronic flasher bc resistors are not always the best path, also if you plan on installing LED's for the front signals as well, youll need to install a diode under the dash, theres a thread somewhere on how to do that. Resistors can get kinda hot from what I know so I wouldnt go that route. Ill brb with the thread on resistors diodes and relays.
DarkNinja52 is offline   Reply With Quote
Old February 18th, 2010, 12:49 PM   #16
DarkNinja52
Heres some talk of resistors and relays
http://www.ninjette.org/forums/showt...=flasher+relay
Some more embedded in turn signal talk
http://www.ninjette.org/forums/showt...ight=resistors
heres one on the diode installation if you ever need it http://www.ninjette.org/forums/showthread.php?t=24500
I'm sure theres more places but I'm in class right now, hope these help.
ignition bypass? 100ohm resistor JarodVoss 2008 - 2012 Ninja 250R Tech Talk 11 June 30th, 2022 06:11 PM
Cant find my stock resistor!!!! (Mitsuba FR22-091) danjaho 1986 - 2007 Ninja 250R Tech Talk 2 February 28th, 2011 07:08 PM
