Old January 22nd, 2015, 11:51 AM   #1
The Red Scourge
The Red Scourge's Avatar
Motorcycle(s): '76 Yamaha RD400, '71 Kawasaki G3SS, '88 Honda CBR400RR, '90 Yamaha FZR400/600 hybrid
A Few Questions About Replacing Brake Rotors
I apologize ahead of time if this has already been covered. I can't find this info by searching. My front rotor is warped and I'm about to replace it with a Galfer Wave rotor. Do I need to replace the pads at the same time? I have a lot of life left in them. I can't find anything conclusive regarding this. Also, is there a need to replace the rotor retaining bolts when replacing a rotor? I was at a shop yesterday having my rear tire replaced. I was talking to one of the guys about replacing my rotor and he mentioned that those bolts are expensive. Is there a reason to do that? Thanks in advance.
"When in doubt, gas it!"
The Red Scourge is offline   Reply With Quote
Old January 22nd, 2015, 12:00 PM   #2
Ghostt
Ghostt's Avatar
My 2˘,
Personally I would replace the pads as well with some name brand HH ones. Also while your in the neighborhood take the time to disassemble, inspect, clean the caliper. And flush and fill with new brake fluid.
Remember it's your safety, so what's it worth to you in the end.
violente et ignorantia
ZX-2R BLOG
Old January 22nd, 2015, 12:16 PM   #3
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
They are just bolts, not very expensive, no reason to replace.
Used pads should be fine, probably just clean the caliper up all that jazz, scuff the pads up a just a bit (using some method ?? IDK someone else can give details) so that they can bed with the new rotor better. Replacing the pads is never a bad idea and probably recommended but if you are on a tight budget what I mentioned above should be fine
No reason to replace the front rotor bolts either they are GTG
Old January 22nd, 2015, 12:31 PM   #4
The Red Scourge
That's what I was thinking! Thanks for the suggestions, guys. I will definitely consider replacing the pads too.
Old January 22nd, 2015, 11:26 PM   #5
maybe the guy was thinking of head bolts or something
Old January 22nd, 2015, 11:45 PM   #6
Ghostt
Ghostt's Avatar
I know when I did mine, I found out that Kawasaki used Red Loctite on the rotor bolts, so the first one was a pain, the other weren't thanks to my torch
ZX-2R BLOG
Old January 23rd, 2015, 01:24 AM   #7
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
Pads aren't expensive so i would replace them with the new rotor, and depending on how you bed them in they can take a few hundred miles to feel normal again.
Questions about Replacing Chain/Sprockets Bones85 2008 - 2012 Ninja 250R Tech Talk 11 April 29th, 2015 06:44 PM
Deglazing Brake Rotors Motofool Videos 4 January 7th, 2015 07:17 PM
[RoadRUNNER] - Replacing Brake Rotors and Pads Ninjette Newsbot Motorcycling News 0 April 26th, 2013 03:00 PM
Replacement brake rotors blades8306 2008 - 2012 Ninja 250R Tech Talk 7 September 11th, 2012 12:49 PM
New Brake Pad=New Brake rotors???? kenji_808 2008 - 2012 Ninja 250R Tech Talk 3 July 20th, 2011 06:34 AM
