Old August 31st, 2009, 04:20 PM   #1
Kevinnolde
www.rentmyninja.com
Kevinnolde's Avatar
Motorcycle(s): A six Pack of Ninja 250s, a less frequently used ZX10r and a few Mini dirt bikes
Keyless ignition
One of my rental bikes has damaged an ignition unit making me think about doing keyless ignitions to the fleet and saving a lb. per unit. Anyone tried it? and can provide the wires to connect. It appears that if I connect the brown, the white and the grey at the key plug (harness side) and then connect that group to the red in the on off switch it should be ok. Another thing is why does the grey wire at the key plug read 11 volts instead of 13.8 like the rest of the hot wires at the plug. I know it goes to the ecu but then what? Be kind. Kevin
Kevinnolde is offline   Reply With Quote
Old August 31st, 2009, 06:22 PM   #2
Kevinnolde
www.rentmyninja.com
Kevinnolde's Avatar
wires
So I have connected the brown with the white and it will run, it will not run if the grey is not hooked up through the key. According to the diagram I could connect the white grey and brown and it should run, it does not. Kevin
Old September 1st, 2009, 05:30 AM   #3
Kevinnolde
www.rentmyninja.com
Kevinnolde's Avatar
The bikes all have the clutch and side safeties disabled and the bike was in neutral. The grey wire shoed 11 volts while running.
Old September 1st, 2009, 08:31 AM   #4
Kevinnolde
www.rentmyninja.com
Kevinnolde's Avatar
I'll fool with it in a minute, I can't remember all of the varients that I tried, I'll go write them down.
09 Keyless Ignition Chad4434 2008 - 2012 Ninja 250R Tech Talk 15 October 5th, 2016 04:12 AM
ninja 250 keyless ignition timone1002 Ninjettes At Speed 18 October 4th, 2016 08:00 PM
DIY Keyless Ignition for 08 250 garth285 2008 - 2012 Ninja 250R Tech Talk 9 July 18th, 2014 01:39 PM
Is there a DIY for keyless ignition? Triple R 2008 - 2012 Ninja 250R Tech Talk 8 June 26th, 2014 02:53 PM
Keyless Gas Cap LittleRedNinjette Items Wanted 7 March 15th, 2013 10:34 AM
