Old January 6th, 2011, 11:19 AM   #1
nilo
Motorcycle(s): 250R Ninja
Ignition problem
Hello guys,
I started to see today a strange hesitation around 7000 rpm, after the bike is warmed. Seems like a spark plug failure or proper ignition faullt. Anyone has experienced this? I need to mention that this started after I washed the moto without the fairings, maybe some water got into the ignition sysrem? Any thoughts are welcome.
Regards
Posted via Mobile Device
nilo is offline   Reply With Quote
Old January 6th, 2011, 11:25 AM   #2
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
How long did you ride the bike after you had washed it? Alos, how many miles are on your bike now? May-be a good time for a tune up? Check the easy stuff 1st. Plugs, and connections.
scotty is offline   Reply With Quote
Old January 6th, 2011, 12:44 PM   #3
nilo
I rode it like one week after the wash. It is now 10.000km and it just came from the dealer where it was serviced.
Old January 6th, 2011, 01:06 PM   #4
dubojr1
dubojr1's Avatar
If it just came from the dealer being serviced, I would return it to them and let them you know your concern.
Old January 6th, 2011, 02:09 PM   #5
scotty
scotty's Avatar
Yup, maybe they had did something to cause the problem.
Old January 6th, 2011, 04:40 PM   #6
nilo
Just happened again when I was comming back from work. The first 10 miles are ok, the ninja is perfect and no signs of hesitation. However, after that period, I start to get the hesitation, like a missfire, at around 8.000rpm. Strangely, it started to hesitate a bit higher than when I was going to work, at around 8 and 10.000rpm. It seemed to me, also, that it was less intense than before. I donīt think it is water since it needs this 10miles to start doing that.
Do you guys have experienced any kind of hesitation due to coils or ignition modules maybe? Dos the ninjette have an ignition module or similar?
Regards
Old January 6th, 2011, 07:22 PM   #7
pull your plugs and check them. also, check for water that might have gotten into the plug towers.
Old January 7th, 2011, 02:16 AM   #8
nilo
Will do that tomorow, since I won't have time tofay. Will let you know the results! Thanks
Old January 9th, 2011, 04:23 PM   #9
nilo
Hello all,
Problem solved. It was a lose ignition wiring plug. I just took off the fairings and saw it right there. Thanks everybody for the help!
Tricky Ignition Problem smp 2008 - 2012 Ninja 250R Tech Talk 5 March 16th, 2015 03:07 PM
Ignition Problem - Multimeter and New Battery garman 1986 - 2007 Ninja 250R Tech Talk 6 June 27th, 2014 08:36 PM
ignition removal problem blegerton Ninjettes At Speed 27 January 28th, 2014 07:04 PM
Are Ignition Boxes a Common Problem bikertrash2001 1986 - 2007 Ninja 250R Tech Talk 1 June 5th, 2011 06:02 PM
problem with ignition? onizthegnome 2008 - 2012 Ninja 250R Tech Talk 8 May 5th, 2011 06:10 PM
Except where otherwise noted, all site contents are Đ Copyright 2022 ninjette.org, All rights reserved.
