Old September 2nd, 2011, 11:36 AM   #1
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
guys w/pod filter &or slip on
did y'all change the pilot jet when you dropped in the 0990(K&N) or new exhaust or does the ideal screw level the air/gas mix out? well txs
THE GOOD LIFE
cuz is offline   Reply With Quote
Old September 2nd, 2011, 11:48 AM   #2
boytoy101
Motorcycle(s): ninja250r 2009model
subscribing in here because i order a K&N r0990 already...looking forward to gather some good information...
boytoy101 is offline   Reply With Quote
Old September 2nd, 2011, 12:09 PM   #3
Review the Jetting Database thread, where a whole bunch of folks have shared their setup.
Old September 2nd, 2011, 12:31 PM   #4
Skippii
Milkshake Drinker
Skippii's Avatar
No, I did not.
Posted via Mobile Device
Old September 2nd, 2011, 01:11 PM   #5
cuz
cuz
cuz's Avatar
i guess my question is that if i change the idle screw(to my setting) then that will eliminate the fact of getting a bigger idle jet am i right?
THE GOOD LIFE
Old September 2nd, 2011, 07:46 PM   #6
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
When i did pod filters i rejetted and had to play with idle mixture screws, no pilot jet change needed on mine. Full exhaust and airbox delete. Keihn110 mains.. Shimmed with 3 washers.. Idle mixture screw 3 turns out.
#1
greatwhiteninja is offline   Reply With Quote
Old September 5th, 2011, 09:45 AM   #7
cuz
cuz
cuz's Avatar
all right thank you ill be going a little less dan you a Leo Vince slip on
& delete the air box txs again
THE GOOD LIFE
Old September 5th, 2011, 01:15 PM   #8
greatwhiteninja
Ridin Dirty
Not much less..I think with no airbox you need minimum of a 108 jet..
#1
Old September 5th, 2011, 10:54 PM   #9
cuz
cuz
cuz's Avatar
well yeah where ever your altitude is like im at sea level so ill be using a 112
THE GOOD LIFE
Old September 6th, 2011, 05:24 AM   #10
greatwhiteninja
Ridin Dirty
Yeah I'm sea level also.. 110main works good, except on really hot and humid days like 95+ deg out its a Tad rich when winding it all the way out like in the 11k + rpm ..
#1
K&N Pod filter mwirrick Ninjettes At Speed 13 January 10th, 2014 05:57 PM
BNIB K&N pod filter cuong-nutz Motorcycle-related 5 September 17th, 2013 12:27 PM
K&N Pod Filter Peanut_EOD 2013 - 2017 Ninja 300 Tech Talk 23 November 15th, 2012 08:35 PM
K&N Pod Filter with Stock Exhaust? krolinked 2008 - 2012 Ninja 250R Tech Talk 3 August 6th, 2012 07:47 PM
K&N Filter or Pod jonthechron 2008 - 2012 Ninja 250R Tech Talk 6 February 17th, 2010 12:07 PM
