November 17th, 2014, 04:07 AM | #1 |
Join Date: Nov 2014 Motorcycle(s): 2010 Kawasaki Ninja 250r FI Posts: 205
Power Commander or Fl Micro WANTED!
Looking for a power commander or FL Micro for my 2010 Ninja. Will pay for item + shipping. PM me
November 17th, 2014, 05:03 AM | #2 |
Freedom for Germany
Hello Jason,
if you're really looking for anything good and since the Leovince FAST-Fuelsystem is not been sold anymore, I would strong recommend you only the PC-V and nothing else. |
November 17th, 2014, 05:46 AM | #3 |
KAWASAKI GURU
Join Date: Jul 2013 Motorcycle(s): Turbo Ninja 250 Posts: 863
One more thing, power commander has out now a PCFC which is a Power Commander Fuel Controller.
If you just need to adjust fuel and not timing you can load up to 10 maps, still able to tune each map as well as fast adjust them on the fly.... Its about $150 cheaper than the PCV with ign control.... check it out: http://www.powercommander.com/powerc...dl=264&yr=2010 |
November 17th, 2014, 07:59 AM | #4 | |
Im getting the AreaP full exhaust system. Will this 'power comander FC' be sufficient then? From what i've been led to believe all that needs tampered really is the fuel/air ratio. |
November 17th, 2014, 08:05 AM | #5 | |
KAWASAKI GURU
Correct, if you are just wanting to adjust fuel this will do the trick for you. The only downside is I dont think it will work with anything like the quick shifter or autotune module as well as you dont have the ability to adjust timing which most people will leave alone anyways but some with a dyno are able to get more power out of the bike with timing adjustments. 95% of the time people only touch the fueling of the bike though. A question I have to you is are you looking for something plug and play and load a map in and go or are you going to have the bike tuned or tune your self? |
November 17th, 2014, 08:08 AM | #6 |
KAWASAKI GURU
One more question for you.....
Do you know what the part number of your ECU is? |
November 17th, 2014, 08:10 AM | #7 |
Freedom for Germany
November 17th, 2014, 08:12 AM | #8 |
KAWASAKI GURU
November 17th, 2014, 08:15 AM | #10 |
Ive got a dyno quoting me £470/$734 to supply, fit and map a PC5.
Am i better off just saving the money with the same outcome with this PCFC? |
November 17th, 2014, 08:24 AM | #11 |
KAWASAKI GURU
So thats about $400 for the PCV and $330 for the install and mapping I take it?
I am a tuner over here in the States in South Florida and I'll try to steer you the best I can with a few questions. 1. What are you wanting to get out of the bike? meaning are you just installing the PCV because your getting a pipe? 2. What kind of riding do you do? track or street or mixed? 3. are you mechanically inclined and computer literate? 4. What are your future plans with the bike? There are a few options I can point you towards to get the best bang for the buck, let me know and I'll help you out! |
November 17th, 2014, 08:27 AM | #12 |
Freedom for Germany
Yes, this is the EU-Version (WVTA-Fullpower).
If you're looking for the best and at least all options then go with the PC-V and get it mapped to your bike, since each map from somewhere else would NOT fit to your conditons. I think 470 GBP is a good offer at all. Good luck |
November 17th, 2014, 08:33 AM | #13 | |
1. I would primarily like more power out of the bike. This is why i originally looked into aftermarket exhausts. The exhaust was a means to an end, and upon researching i realised the pc was a must. 2.All street riding, the track where im from wont allow anything under 400cc on it. 3. I am computer literate, i have a very basic mechanical understanding of bikes/pc5. 4. Future plans are to ride it for at least 2 years as im on a restricted licience, and if financially possible, to keep the bike along with my second bike that i will be purchasing then. |
November 17th, 2014, 08:34 AM | #14 | |
November 17th, 2014, 08:54 AM | #15 |
KAWASAKI GURU
Got ya!
OK well yes a power commander will do what you need it to do. Well another option you have would be to get the auto tune module from power commander, it will add a wideband heated o2 sensor to your exhaust which most of the time the the aftermarket pipes will include the bung already installed on it. It might work out to be the same price if not better to buy the PCV as well as the autotune module and self tune your self. The autotune module records your air fuel ratios at all RPM's and allows you to self tune the bike. You can input what air fuel ratios you want to target which is very easy to install which is really nice and your really getting a accurate tune for your bike with real world throttle and RPM input. Maybe check out the autotune stuff from dynojet if you can, a lot of times you can find a used system for under $200 USD I found a PCV with ign control on ebay for $340 USD so that plus the autotune say at $150-$200USD thats only $540ish? or £345 One more option would be to just run the PCFC which is part # FC17046 I found on on ebay for $228 shipped but thats inside the US maybe you can find one over there. You wont have the ability to hook up the autotune module but you can load up to 10 maps into the controller and test out each one and see which one may give you the best power at wide open throttle and which one gives you the best throttle down low and then merge the maps. What I use is actually a wideband data logger made by a company called Daytona Sensors and its called a WEGO 3. It records the air/fuel, RPM, and throttle positions, but they are are almost $400 alone for that. You have a few options but I guess the thing you need to figure out is how much $ you want to throw at the bike and how deep you want to get into it. By the way pretty much everything dynojet makes is VERY easy to install! Food for thought, hopefully I didnt confuse you! |
November 17th, 2014, 06:08 PM | #16 |
Freedom for Germany
Hi Jason,
on the given link I guess you'll find the best solution http://www.cjsracing.co.uk/news.htm Talk to Chris, when I remember it right then he's charging 150 GBP for the remapping of your ECU. He can do it on the dyno (what for sure means extra cost) if you bring your bike to him and there is no need for any piggy back system. This can give you exact what you're looking for. One thing is important to know, the maps of both cylinders are different and I with my limited knowledge am so not sure that Auto tune with only one o2 sensor is able to adjust the system for correct values. All serious Tuner in this case recommend the usage of the Auto tune with two o2 sensors for 2 cylinder bikes. I wish you good luck |
November 19th, 2014, 09:12 AM | #17 | |
KAWASAKI GURU
Wow if that guy is close to the OP That will be the best bet! For information on the ninja 300 the cyl1 gets 5% more fuel than then cyl2 |
November 24th, 2014, 09:01 AM | #18 |
I thank you for all the help, i think i may possibly be out of my legeue here and need to learn a bit more before i decide to do it lol
Also that guy is 530 miles away from me haha |
November 24th, 2014, 03:09 PM | #19 |
KAWASAKI GURU
You can always add the power commander later on, chances are you will have no problems with the bike with just the pipe on it.
Power commander 5 | joecool | 2013 - 2017 Ninja 300 Tech Talk | 27 | October 17th, 2014 05:03 AM |
power commander? | bandit_fosky | 2008 - 2012 Ninja 250R Tech Talk | 14 | January 16th, 2013 02:05 PM |
Dynojet Power commander 5 | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 3 | September 23rd, 2012 03:23 PM |
Power Commander for FI version? | raybolic | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 26th, 2012 06:34 AM |
Power Commander for new bike? | dive1tom | General Motorcycling Discussion | 5 | December 8th, 2009 08:53 PM |
