June 18th, 2014, 11:17 AM | #1 |
Join Date: Apr 2014 Motorcycle(s): 2003 Ninja 250 Posts: 11
Cannot Get Pads Aligned with Rotor
Hey everyone,
I've had a lot of front brake problems after installing new pads and rotors and rebuilding the caliper- Check out here for more info: http://www.riderforums.com/general-n...need-help.html I won't bore you with the details, but go there if you care. As for my question, I eventually realized that one of the pads I installed wasn't up against the rotor properly- only an edge of it was making contact, while the rest of the pad was 1-2mm off the rotor, tilted away. I took off the caliper, kinda jiggled the pads a bit, and stuck it back on. The brakes work better, but after a quick test around the block, they still don't feel right, and the new wear marks on the rotor tell the same story. They just don't provide very much braking power, about on-par with the rear brake, but nowhere near as smooth or feeling as well. So, does anyone have ideas on why they may be off? I'm planning on taking it off again and seeing if I can make it align better, but is there something else I missed when installing them to cause this? Any ideas are welcome, thank you. |
June 18th, 2014, 12:16 PM | #2 |
Join Date: Sep 2013 Motorcycle(s): Ducati 1198s, Triumph D675, Suzuki SV1000s, `08 Ninja 250, `11 Ninja 250, Suzuki GS750 Posts: 368
You've put something back together incorrectly, can you post pictures?
MCRA.com |
June 18th, 2014, 12:18 PM | #3 |
June 18th, 2014, 12:49 PM | #4 |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
Any possibility they gave you the wrong pads?
June 18th, 2014, 02:18 PM | #5 |
one of two things. either A (unlikely) you didn't put the pad bolts in or they are dragging on the pad bolts. if this is the case put in lubed up pad bolts. if they are in and they aren't dragging then it is probably one of the pistons is stuck. how did you clean them? i only glanced through your other thread. if the piston walls and the cylinder walls aren't nice and smooth they will easily jam
June 18th, 2014, 02:29 PM | #6 | |
For the pistons being stuck, I put a decent amount of lube on them but had to push them back in with a vice when I did the rebuild. They slowly worked out after I rebuilt the caliper, but just last night I took the caliper off, the pads out, and pushed the pistons back in as a way to "reset" things. The large piston worked out a bit fine- but slowly- however the small piston just moves in and out a tiny little bit instead of working its way out (This is with the large piston clamped down). I didn't spend a bunch of time on it last night to figure it out, so I'm just about to head to the garage to see what I can do. I think I just pushed it in too far, but is that a sign of another problem? I thought I lubed them just fine, but maybe not. |
June 18th, 2014, 02:38 PM | #7 |
the pad bolts meaning the caliper pins. they are bolts with axles on the end that fit through the holes in the pad.
with the brake line off you should be able to move the pistons without too much force
June 18th, 2014, 02:38 PM | #8 |
Use a brake hone or a piece of sand paper and clean up the bore in the caliper. Both pistons should move out equally when the brakes are applied.
And dont forget to put some lube on the piston seals before reinstalling |
June 18th, 2014, 02:44 PM | #9 | |
In terms of the pistons, do you think I did something wrong when installing them? I could only get either of them half way in when I rebuilt the caliper, like I said the vice was used to get them the rest of the way. I'm going to spend a bit more time with it, then take the caliper off again and take off/clean the pistons again. See if I can get them to slide in easier than the first time. |
June 18th, 2014, 02:48 PM | #10 |
When I rebuild a caliper I make sure I can slide the piston in and pull it back out with my fingers. So yeah I'd say 99% thats your problem.
June 18th, 2014, 05:13 PM | #12 | |
June 18th, 2014, 06:25 PM | #13 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Zip tie the brake lever to the bars and leave it overnight.
June 18th, 2014, 07:12 PM | #14 |
Thanks for the help everyone! I bled everything one more time, but no air came out. With my morals down, I decided as a last ditch effort to pump the brake as fast as I can for 100-200 times.
Well, what do yah know?! After about 75 times, the brake started to harden up, so I kept on going. Eventually, it started feeling really usable- the pistons actually moved out and the pistons were grabbing, with no pad alignment issue. I took it out for a ride, and while not perfect, useable and workable! Thanks for the help again looks like it really was the caliper pistons. I'm planning on doing that tonight, hopefully it'll help a bit more. |
Do I need a new front rotor? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 14 | August 23rd, 2014 10:11 PM |
Flip the rotor? | nickjpass | General Motorcycling Discussion | 5 | June 10th, 2014 08:30 PM |
Front brake pads/rotor scraping | WAGESLAVEesc | 1986 - 2007 Ninja 250R Tech Talk | 8 | June 3rd, 2014 06:13 PM |
Warped rotor | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 4 | August 11th, 2013 04:13 PM |
My knee pads are like shin pads | rasta | Motorcycle Gear | 20 | July 18th, 2013 12:43 PM |
