September 1st, 2016, 06:15 PM | #1 |
Tru-Tension Chain Monkey
September 1st, 2016, 06:36 PM | #3 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
That's tight
September 2nd, 2016, 12:18 AM | #4 |
Join Date: Aug 2016 Motorcycle(s): Triumph Bonneville, Ninja 300 Posts: 204
And here I just put a screwdriver in between the chain and rear sprocket and call it a day. But hey, if you want to spend some money and add a medium sized, single-purpose tool to your toolbox, knock yourself out.
About 2min in, this shows *kinda* the method I use. Rolled back further, the screwdriver will very reliably set you up with around 1-1.5" of slack with no weight on the bike. Spec for the Ninja 300 is 0.8-1.2". Race/track types will typically run it a tad looser. https://youtu.be/5NiDFohUbYY?t=2m
Let he who has never re-used a crush washer cast the first stone... |
Chain Monkey | allanoue | General Motorcycling Discussion | 7 | March 24th, 2016 02:33 PM |
Correct chain tension | hereiam | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 26th, 2015 02:41 PM |
[motorcycle.com] - BMW C650GT and C600 Sport Recalled for Faulty Timing Chain Tension | Ninjette Newsbot | Motorcycling News | 0 | May 27th, 2014 12:40 PM |
Chain Tension Issues | menikmati | 2008 - 2012 Ninja 250R Tech Talk | 1 | February 12th, 2012 08:19 PM |
How long before your first chain tension adjustment.. and routine cable lubrication | reaubideux | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 12th, 2011 09:54 PM |
