December 7th, 2010, 06:59 AM | #1 |
Join Date: Aug 2010 Motorcycle(s): 2009 Ninja 250r Posts: 61
What spark plugs...
is everyone using on their bikes? I figured I would change mine to a fresh set before I start to tune it after all its changes.
December 7th, 2010, 11:24 AM | #2 |
Join Date: Mar 2010 Motorcycle(s): Ninja 250R '09, SV650s '07 Posts: 52
The spark plugs that can be used on the 250 is either the NGK CR8E or the Nippon Denso U24ESR-N
Do not purchase the NGK #CR8HSA or Nippon Denso #U24FSR-U as listed on the wiki as that is reffering to the pre-2008 models. You can use a 16mm plug wrench, or the wrench included in the tool kit; torque specs of 115 lb. Here's a helpful video of how it's done: http://www.youtube.com/watch?v=3POFTC_i_N4 |
December 7th, 2010, 11:37 AM | #3 | |
December 7th, 2010, 12:50 PM | #4 |
Unless you want your spark plug ***really*** tight.
(safety tip: don't do this. )
December 8th, 2010, 12:04 AM | #5 |
Join Date: Sep 2010 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 139
You can also use the Iridium version of the NGK plug (NGK CR8EIX)...IX = iridium.
I am currently using them in my bike....iridium plugs last longer but that's about the only difference. Also heard of people using NGK CR7E plugs, difference is heat range - with NGK the higher the number the colder the plug. If I remeber correctly people using those plugs were using them in winter etc.... If you don't have a torque wrench, tight as you can with your hand then 1/4 of a turn with the ratchet. |
December 8th, 2010, 06:36 AM | #6 |
IC2(SW)
CR8EK is a nice plug choice too... double ground electrodes
Spark plugs, which and why? | subxero | 2008 - 2012 Ninja 250R Tech Talk | 17 | June 3rd, 2014 08:49 AM |
spark plugs | juanpak87 | 1986 - 2007 Ninja 250R Tech Talk | 12 | October 3rd, 2013 09:44 AM |
Spark plugs? | corksil | 2008 - 2012 Ninja 250R Tech Talk | 12 | October 1st, 2013 11:04 AM |
Removing spark spark plugs? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 26th, 2013 03:48 PM |
Spark plugs... | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 23rd, 2010 04:02 PM |
