June 6th, 2011, 10:01 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): kawasaki ninja 250r Posts: 66
spark plugs
hey guys im wondering what people have found work good for plugs on these bikes. ive got a 08 250 that just turned over 18,000 and she is starting to run a little rough. so im going to do a full tune up and such.
blue is better! |
June 6th, 2011, 10:29 PM | #2 |
use the stock NGK recommended plugs. cheap and effective. they've lasted you 1800 miles.
have your valves ever been adjusted? |
June 6th, 2011, 10:53 PM | #3 |
i took it in at about the 8,000 mile mark had it all checked out and they checked them and said they were fine.
blue is better! |
June 6th, 2011, 11:09 PM | #4 |
you do know the valves should be checked every 7,500 miles? you're due again. that could be the reason for the rough running.
June 6th, 2011, 11:09 PM | #5 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
what kkim said...NGK CR8E
June 6th, 2011, 11:16 PM | #6 |
no i didnt know that. the tech at the shop i bought it from said if at the first checkup they were fine i shouldnt have a issue. is there a fourm on here that explains what needs to be done?
blue is better! |
June 6th, 2011, 11:23 PM | #7 |
here's the maintenance schedule for the new gens...
http://www.ninjette.org/forums/showthread.php?t=10577 |
June 7th, 2011, 04:52 AM | #8 |
IC2(SW)
Get the cr8eK, much better for the hemi head.
Spark plugs, which and why? | subxero | 2008 - 2012 Ninja 250R Tech Talk | 17 | June 3rd, 2014 08:49 AM |
spark plugs | juanpak87 | 1986 - 2007 Ninja 250R Tech Talk | 12 | October 3rd, 2013 09:44 AM |
Spark plugs? | corksil | 2008 - 2012 Ninja 250R Tech Talk | 12 | October 1st, 2013 11:04 AM |
Removing spark spark plugs? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 26th, 2013 03:48 PM |
Spark plugs... | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 23rd, 2010 04:02 PM |
