July 1st, 2009, 09:03 PM | #1 |
self wrencher
fuel position question
when the petcock is set to PRIME and bike is off, does fuel flows out? I set it to prime and bike off, I do not see any fuel flow (through my clear fuel filter). However, if I disconnect the hose off the carburator, fuel will flow out from tank. Can someone confirm this?
July 1st, 2009, 09:06 PM | #2 |
yes, that's how it's supposed to work. It won't flow when you have it connected to the carbs cause the fuel valve inside the carbs is being held closed by the floats if the carbs are filled with gas.
if you disconnect the fuel hose from the carbs, it should pour out of the end of the fuel hose in the prime position. |
July 1st, 2009, 09:19 PM | #3 |
self wrencher
thanks kelly..just wanted to be clear cuz i was trying to help a poor guy with leaking fuel problem on the kawi board..may be you can jump in and give him a few pointers if you have time.
Fuel tap question and bike surging | agentbad | 1986 - 2007 Ninja 250R Tech Talk | 23 | February 24th, 2014 10:26 AM |
Petcock / Fuel Tap question | pdxdavid | 2008 - 2012 Ninja 250R Tech Talk | 9 | October 9th, 2013 08:28 PM |
Fuel Gauge Question | Little Green Machine | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 30th, 2012 05:36 PM |
Fuel Tank Question | Jim Moore | 1986 - 2007 Ninja 250R Tech Talk | 8 | June 13th, 2012 06:23 PM |
Question to old gen owners w/o fuel gauge | Rosie | General Motorcycling Discussion | 19 | August 19th, 2010 12:29 PM |
