Old June 25th, 2009, 08:55 PM   #1
savag3
Motorcycle(s): 09 Black Ninja 250
Slip-on question
Ok so I recently got a 09 ninja 250 and I'm enjoying every minute on it. I guess my only complaints are the bright chrome exhaust (on my all black bike), and the bike is a tad bit too quiet for my taste. The best solution, in my eyes, is a Yosh slip-on. Problem being that I've talked to a few people about this, including a local dealership mechanic, and some say I might have problems with the bike running lean? Is this true? I guess I'm just asking if it's okay to throw a slip-on on my bike without changing any other ratios or parts.
Thanks
savag3 is offline   Reply With Quote
Old June 25th, 2009, 08:58 PM   #2
if yoshi recommends a rejet, yes it will cause it to run lean. I'd recommend just shimming the needles instead of buying a jet kit.
welcome to the forum. search and you'll find many threads on this subject.
Old June 25th, 2009, 09:03 PM   #3
CANTFUNCTION
CANTFUNCTION's Avatar
Motorcycle(s): 09 ninja 250(red)
http://www.ninjette.org/forums/showthread.php?t=11963
CANTFUNCTION is offline   Reply With Quote
Old June 25th, 2009, 09:05 PM   #4
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Welcome Matt! If you read the jetting threads, you may find that your bike is already lean... it's really easy to throw a couple of washers in there and smooth things out.
Also, if you haven't already pulled the snorkel, you might give that a try, as it does give the bike a throatier growl.... but again, it might make it a little lean and require a rejet....
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old June 25th, 2009, 09:08 PM   #5
don't pull the snorkel w/o at least shimming the needles. the bike WILL run too lean.
slip on question dbking321 2008 - 2012 Ninja 250R Tech Talk 4 May 20th, 2013 08:37 AM
Filter and slip on question 2vegas50r 2008 - 2012 Ninja 250R Tech Talk 18 December 5th, 2012 10:41 PM
Question about slip-on exhausts... Advincula 2008 - 2012 Ninja 250R Farkles 8 October 27th, 2012 08:12 PM
question on Yoshi slip-on kashun84 2008 - 2012 Ninja 250R Tech Talk 0 August 17th, 2010 07:02 PM
2 Bros Slip on Exhaust Question Jiu Jitsu Player 2008 - 2012 Ninja 250R Tech Talk 12 July 16th, 2009 08:43 PM
