November 4th, 2013, 04:22 PM | #1 |
Join Date: Jan 2009 Motorcycle(s): '13 Ninja 300 '09 Boulevard C50. '08 250r(TOTALED BY DEER) Posts: 467
Targa signal burnt out
I have had a Targa(22-472led-m) tail kit with led signals for this season. I now have 1 signal burnt out. What are my options? Can I replace just the LED bulbs? Noone seems to sell just the bulb, or just the 1 signal. If I have to to replace the signal, or more, I might go bigger than the micro.
Thoughts? Should the Targa led flasher relay work with any similar LEDs I find? Or are they very specific to the amount of bulbs?
CHEERS!!! |
November 4th, 2013, 04:52 PM | #2 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Sounds like they have a led problem, LED's shouldn't burn out that quick... Contact targa!!!
November 4th, 2013, 05:17 PM | #3 |
Targa didn't care that it burnt out. I am trying a direct replacement with the larger arrow signals. for $40. Fingers crossed.
CHEERS!!! |
November 4th, 2013, 05:48 PM | #4 |
Durn I won't be going through them for purchases, no standing behind their products at all. Hope the replacements don't break the bank
December 18th, 2013, 04:00 PM | #5 |
Join Date: Apr 2013 Motorcycle(s): '13 Ninja 300 Posts: 33
Same issue with the micro LED signal. The LED array itself is flopping around inside the housing and is now intermittent. I just called Targa and they want to charge me $34 for a pair of new bulbs. I've only been running the micros now for 5 months. Pretty crappy life span if you ask me. It seriously sucks that they don't back up their products.
I think I'll try prying apart the housing and repair the thing myself. Probably just a crappy solder job. |
Saved the bike..burnt my leg | mustang5.0 | !%@*#$%!)@#&!%@ I crashed! | 25 | February 28th, 2012 01:06 PM |
burnt chrome exhaust | Rayme | 2008 - 2012 Ninja 250R Tech Talk | 15 | February 24th, 2012 11:46 PM |
Headlight lo-beam not working; burnt bulb? | HorizonXP | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 14th, 2010 02:39 PM |
Targa Question | Minnesotah | Motorcycle-related | 12 | August 14th, 2010 10:30 PM |
Burnt leg on tail pipe | Anthony_marr | General Motorcycling Discussion | 32 | August 7th, 2009 11:53 PM |
