May 19th, 2020, 11:30 AM | #1 |
[motorcycle.com] - Church of MO: 2000 BMW F 650 GS Ride Report
A reading from the book of Schvetz: On this very day [almost exactly 20 years ago] I have been running errands in city traffic, cruising effortlessly on the highway, carving some canyons and trail riding on the same machine for you, the lazy mouse dragger, upon a strange yet captivating combination of curvaceous lines, purposeful looking parts and some really tacky details. Yea, and verily – BMW used to make some very nice big Singles.
———————————————————————————————– Think of it as a GS Lite By Yossef Schvetz*May. 20, 2000 Photos by Yossef Schvetz Tel Aviv, May 23, 2000*— Radical things have been happening at BMW lately. First they re-wrote the book on cruisers with their R1200C. Then they made a stormer of a boxer sporting twin, the R1100S – and now their attention has been directed towards big singles. By reading just the spec sheets you wouldn’t guess that the new F650GS is revolutionary by any means. You can go through the details in the First Look, but here are the basics for you, the lazy mouse dragger: A full downdraft intake system, an electronic fuel injection system, an under the seat fuel tank and a twin spar frame. Yep, the guys who have been known for their conservative approach have revolutionized the architecture of BMW’s single cylinder motorcycle. What do you get in return for all this mumbo-jumbo? How about a 113 mph top speed for a tall and aerodynamically-challenged 650cc single? Impressive, no?*The guys at BMW have taken an idea present in sportbikes for the last fifteen years and applied it to a single cylinder engine. The fuel injector throat, air filter and airbox now sit where the fuel tank used to be, giving the incoming air a straight shot to the motor. The tank has moved under the seat with the added bonus being a much lowered center of gravity for the entire bike. It all makes you wonder why BMW has never implemented the idea before. BMW has not forgotten those more inclined towards off-road adventures Coming up with a worthy sequel for the original F650 Funduro — a bike that sold more than 60,000 copies worldwide — couldn’t be an easy task. BMW didn’t stop at their thorough engine remake, however. The frame is a totally new twin spar design. This is not a first on an off-road* machine; it has been implemented before on the Honda CR250, but it is certainly new in a big trailie. To cap it all off, the designers have been let loose at their drawing boards and have created a truly impressive machine to look at. It is a strange yet captivating combination of curvaceous lines, purposeful looking parts and some really tacky details. The front end and the sexy curves around the filling cap near the rear can really make you drool, but the side grills and the big stuck-on BMW logo seem like some leftover car parts. Nevertheless, it is a head turner. I can’t recall any other dual-purpose machine that has drawn so many envious looks from car drivers at stop lights. How does it all work when you ride it? The first thing to greet you is an extremely muted, un-single like sound; the twin silencers (with a catalytic converter) see to that. Like its forbear, the old Funduro, the engine is lacking in bottom end grunt. As I fumble around the city traffic, the first few degrees of throttle movement have none of the snappy reaction associated with big singles. Fuel injection or not, this is no Honda XR600 or KTM 620 LC4. But as traffic thins, I wind the throttle on some more and*whoa, this engine flies! As soon as the* engine revs above 3,000 rpm, things start to happen quickly. The close gear spacing lets you keep the engine on the boil and then those big handfuls of throttle produce some serious forward thrust.On to the highway, then, where the engine really shines. A few bursts through the gears and the F650GS lunges to a very unstressed 100 mph. This motor is so smooth that it really makes you forget that there is just one cylinder beneath you. But the motor is not done just yet. Where other one-lunger’s breathing starts to taper off, this single is just awakening on its way to a heady 7,000 rpm that translates into more than 110 mph on top. Even at this speed the motor isn’t fazed. If it were a blindfold test, I could easy be suspecting that there is a twin cylinder engine hiding down there. This kind of performance is in the territory of twins like the old Honda Africa twin or Yamaha Super Tenere, both twin cylinder 750 cc machines. The only thing that stops you from tearing along at this elevated pace is the seating position that the BMW imposes on the rider. Regrettably, what felt like a very manageable and comfortable seating position turns out to be less so as the miles and speed build up. The seat is very low to begin with, but that is fixable by optional thicker padded seats that BMW can supply. The really bad part is the handlebar that had my elbows in line with my stomach. And no, you can’t rotate the bars forward since they will immediately touch the instrument panel on full lock. So seating position is OK as long as you don’t push speeds too* much. But this must be about the only serious flaw of the Beemer as a road machine. Everything else about the ride just shouts class and control. The frame turns out to be as rigid as it looks and the same goes for the fork and swingarm. Fast sweepers, slow turns and everything in between is handled by the Beemer in surprising control considering that it is, after all, a dual purpose machine.On my favorite mountain road, a demanding chain of decreasing radius corners with almost no straights, the BMW gives me those huge grins that are usually reserved for “exciting” machinery. The wide bars allow me to turn the bike into corners extremely quickly. Although soft, the suspension keeps the bike in control, and the Michelin T66 Radials let me get away with some silly lean angles. But all the tire adhesion in the world is useless without the excellent manners of the frame and suspension. Only when I aggressively toss the Beemer into a tight right-left chicane does the suspension lose its composure and allow the center stand to grind hard. Center stand? Yes. But this is jus t the tip of the iceberg as far as standard equipment goes. If you are used to dual purpose bikes as bare bones bikes, then the BMW is something else. Besides the center stand there is a side stand, a strengthening bridge on the fork legs, a burly sump guard, a remote adjuster for rear preload and heated hand grips. BMW’s superb Anti-lock Braking System is available as an option. Can the GS deliver in the off-road side of the dual-purpose equation? Even before the front wheel turns one revolution on dirt, one thing is for sure; you really don’t want to have this beautiful bike tip over on some rocks. There’s the one area where the designers might have got it wrong. The GS bodywork looks almost too fancy and fragile to get* really dirty or withstand any impacts. The possible costs of repairing panels, and the total lack of knobs on the tires are in the back of my mind as I hit a very mild and hard-packed trail. As it turns out, the GS can do pretty well on this easy trail. Here again, the closeness of the bars works against you, making it really difficult to stand on the pegs. Just as well because the softness of the suspension starts to show. Hit any mild bump at semi-serious speed and the suspension gets worked hard and the springs release themselves, sending the bike airborne. But then standing on the pegs in an aggressive motocross stance was not what this bike was intended for. If you sit back, relax, enjoy the birds, the trees and the scene, the BMW works fine. The* only other nuisance is that same lack of low end grunt. In slow sections, when confronted with any sort of challenging pass, the peaky engine and the traction-less tires make it a wheel spinning, feet paddling affair. Also, the rear brake that is already sensitive on the road locks under the lightest of touches off-road.It is really at the end of the day that the broad abilities of the GS hit you. On this very day I have been running errands in city traffic, cruising effortlessly on the highway, carving some canyons and trail riding on the same machine. Although the same could be said of any dual purpose machine, the Suzuki DR650 or the Honda XL650L for instance, the BMW is head and shoulders above them as a road machine. And let’s face it, that’s where these sort of bikes spend 90% of their time. Besides, BMW has not forgotten those more inclined towards off-road adventures. The “Dakar” version of the F650GS is already on sale and includes longer travel suspension with stiffer springs. For the real* desert racers there will be a RR version that is a replica of Richard Sainct’s last Paris-Dakar rally winner. This F650 GS is the bike that will give most of us the right balance of on and off-road abilities, albeit at a price. In some markets the GS’s price is 20-30% higher than other bikes in its class. Expensive bikes usually turn me off, but this is one case where the lavish equipment level and the real-world performance justify the price tag. Specifications Manufacturer: BMW Price: Not Availiable Yet Model: F 650 GS Engine: Single-cylinder, Water-cooled, 4-valve, DOHC, 4-stroke Bore x stroke: 100 x 83 mm Displacement: 652 cc Carburetion: EFI Bosch-BMW Transmission: 5-speed Claimed power: 50 hp at 6x.500 rpm Claimed torque: 43 ft-lbs at 5000 rpm (6 kgm at 5.000 rpm) Wheelbase: 58.3 in.i (479 mm) (58,6 in/1489mm for the Dakar) Rear Tire: 100/90 – 17 Tubeless Radial Front Tire: 130/80 – 19 Tubeless Radial (90/90 x 21 for the Dakar) Fuel Capacity: 4,57 gal. (17.3 L) Claimed Dry Weight: 388 lbs (176kg) (385.8 lbs/175kg for the Dakar) Color Schemes: Titan Blue, Red and Mandarin Yellow The post Church of MO: 2000 BMW F 650 GS Ride Report appeared first on Motorcycle.com. Click here for full story...
[motorcycle.com] - Church of MO: Yamaha YZF-R1 Y2K (2000) First Ride | Ninjette Newsbot | Motorcycling News | 0 | March 4th, 2018 09:40 AM |
[motorcycle.com] - Church Of MO Ride Report: 2003 BMW F650CS Scarver | Ninjette Newsbot | Motorcycling News | 0 | May 8th, 2017 08:51 AM |
[motorcycle.com] - Church Of MO 2007 BMW G 650 X Series | Ninjette Newsbot | Motorcycling News | 0 | September 27th, 2015 05:11 AM |
[motorcycle.com] - Church Of MO 2000 Honda Gold Wing Vs. 2000 BMW K1200 LT | Ninjette Newsbot | Motorcycling News | 0 | May 18th, 2014 07:40 AM |
[motorcycle.com] - Church Of MO First Ride: 2000 Honda RC-51 | Ninjette Newsbot | Motorcycling News | 0 | March 9th, 2014 11:50 AM |
