Old September 11th, 2014, 08:33 PM   #1
Insane Pie
Motorcycle(s): '08 Ninja 250
Has anyone used the Uni Air Filter Service Kit or something similar?
A friend gave me this kit: http://www.revzilla.com/product/uni-...er-service-kit and my air filter needs to be cleaned.
Anyone use this before or a similar product?
Insane Pie is offline   Reply With Quote
Old September 12th, 2014, 08:48 AM   #2
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
I use that oil for the filters in my dirt bikes. I wouldn't use it for the filter in the ninjette though, I just use cheap 10w30 dino oil for that. The uni air filter oil is really sticky/tacky which is what you want for a dirt bike that sees nasty off road conditions, but I don't know if it's what you want to use for a street bike.
Old September 14th, 2014, 06:46 AM   #3
DaBlue1
DaBlue1's Avatar
I use a similar kit on my Pipercross air filter.
Word of warning... the oil is tacky, so you only need a tiny bit only on one side (facing away from engine) of the filter. Too much oil will cause air flow problems.
Use the cleaner outside and make sure the filter is completely dry before applying the oil.
I do not recommend using this oil on the stock filter as the pores are too small. Uni filter and Pipercross use only.
K&N air filter to stock air box Graugaard 2008 - 2012 Ninja 250R Tech Talk 29 July 28th, 2012 06:33 AM
Anyone know an air filter I can replace the OEM filter with? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 5 July 22nd, 2012 09:34 AM
Yet another alternate air filter Q (UNI pods) indr 2008 - 2012 Ninja 250R Tech Talk 6 February 6th, 2011 01:26 PM
Question about UNI pods\K&N air filters cbass78 1986 - 2007 Ninja 250R Tech Talk 6 March 22nd, 2009 06:28 PM
