Old February 14th, 2011, 12:05 AM   #1
kenji_808
Motorcycle(s): 2009 CT Blue 250R(Sold), 2008 Black & Silver Honda CBR600RR(Current)
DIY: Speed Bleeders
Ive finally installed the correct size speed bleeders on my ninjette the other day.
The M8x1.25 Bleeder screw PN:SB8125 is the correct size for the new gen ninjettes
Heres a picture comparison of the new gen OEM screw which is M8x1.25(#1), the correct Speed bleeder screw PN:SB8125(#2), and the old gen speed bleeder screw which is a M7x1.0 PN:SB7100S(#3)
http://www.ninjette.org/forums/attac...1&d=1297666990
kenji_808 is offline   Reply With Quote
Old February 14th, 2011, 08:59 AM   #2
wyckedflesh
wyckedflesh's Avatar
Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion)
As mentioned before, The advantage of a speed bleeder is for when your say at the track, just came off a really hard set of laps and your lever has become soft from boiling the fluid.
A simple crack of the speed bleed can release air, without drawing any air back in.
2009 KLE650 LSL bars, Full Muzzy PC-V
1995 900SS/CR mildly modified
wyckedflesh is offline   Reply With Quote
Old February 14th, 2011, 09:20 AM   #3
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Really? I've never heard of them. So, it'll bleed the air out but will any oil leak out as well?
Old February 14th, 2011, 10:12 AM   #4
kenji_808
no its a ball check valve when you loosen it a quarter turn,
when you squeeze the brake lever which hydraulicaly depresses a ball bearing against a spring to allow the fluid to bleed out of the system. Then instead having to tighten the screw down before you release the lever flike in a typical brake bleeding project). the ball bearing seats back down to close off the system preventing from air being sucked back in the system.
just FYI they're like $20 shipped for a set, maybe a little cause I'm in hawaii.
so they'are relatively cheap and very cost effective.
Old February 14th, 2011, 10:15 AM   #5
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Oh cool. Hmm...may have to consider this.
Old February 20th, 2011, 01:19 AM   #6
ungluck
sleeper
ungluck's Avatar
Motorcycle(s): '10 250r, '10 690 duke
me likey!!
ungluck is offline   Reply With Quote
Old February 20th, 2011, 08:34 AM   #7
Snake
Snake's Avatar
Great DIY, thanks!
Old February 20th, 2011, 12:28 PM   #8
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
Thanks kenji_808, I was sold the old (wrong) ones.
slolane is offline   Reply With Quote
[motorcycle.com] - 2013 AIMExpo: Speed and Strength Speed Strong Jacket Video Ninjette Newsbot Motorcycling News 0 October 18th, 2013 04:01 AM
Speed Bleeders?? kenji_808 2008 - 2012 Ninja 250R Tech Talk 22 November 13th, 2012 08:07 PM
DIY Double Blinker Speed ninja250 2008 - 2012 Ninja 250R Tech Talk 38 February 18th, 2010 12:39 PM
