September 20th, 2015, 10:13 PM | #1 |
Join Date: Sep 2015 Motorcycle(s): 2010 ninja 250 Posts: 127
Big boys on 250?
Hey. So I just picked a 2010 wrecked 250 for. $300. The bike runs but have a bit of damage such as bent fork and brake and clutch pegs. All the plastic is gone bit is not a problem since I will be doing a street fight build....
This is my first bike I hope to ride. But I'm 260lbs. And I don't plan on trying to be a speed demon. The reason I wanted to get the 250 was from everyone saying how you had to rev it to the moon and how light the bike is. I'm sorry but for me that's a plus. I don't need something that I wouldnt ride due to fear. If I'm going a bit slower then other riders on 250 I won't mind....is there anything else I should be concerned about. Should I change my sprockets? |
September 21st, 2015, 05:03 AM | #2 | |
MOTM - June '15
Great bike, rev the piss out of it. Have fun. It will be plenty fast.
September 21st, 2015, 05:08 AM | #3 |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 718
QFT. I weighed about 235 when I started riding my 300 and it was no problem.
DISCLAIMER: I generally have no idea what I'm talking about. |
September 21st, 2015, 06:23 AM | #4 |
Join Date: Dec 2010 Motorcycle(s): 2007 EX250 black. Previously Suzuki DR650, Suz SV650, Honda Hawk GT, Yam XT225, BMW F650 Posts: 23
I'm about 220 with a pre-gen 250. Power is fine for my NC moutain roads. I upgraded to new-gen rear shock which you already have. I've ordered heavier front springs, but yours may be able to be shortened with longer spacers to get a bit more front end firmness. I also changed to 15 tooth front sprocket to reduce revs a bit and experienced no perceptible loss of speed.
So you should be good to go.
Bill Price Waynesville, NC Old, slightly big guy who likes small bikes |
September 21st, 2015, 06:24 AM | #5 |
I think you will be fine with stock gearing.
Lot of owners like to go +1T on the countershaft sprocket to drop some revs while cruising, but I don't think you would want to do that. You aren't going to want taller gearing, but I don't think you want to gear it down either. The "New Gen" Ninjas, like yours, are designed with a bit more midrange in mind, which will be a good thing for you especially when taking off from a stop. Once you are rolling you will want to keep the revs close to 10,000 if you are looking for any acceleration. You may want to make some suspension changes though. |
September 21st, 2015, 06:55 AM | #6 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
I'm 6'4" 340 lbs As Crocodile Dundee said:" Now THAT's a knoyfe!"
If you like to shift gears and carve corners; you will love the Ninja 250R. I forgot how much fun a small displacement bike can be! As long as you don't expect sportiness on the highways! It shines in the city, twisty side roads and smaller tracks. I love my 250! Even when bone stock I was very impressed with the behaviour of the suspension considering what I was subjecting it to! My only real beef was how ridiculously lean the stock jetting is set which required 10 minute full choke warmups even in the summer! My suggested "Big Boy" mods for you are (in order if you are tall): - Add 1 1/2" - 2" padding to the seat thickness. - Find out from your local area 250R racers what jet kit to install. - At the very least get your local suspension shop to supply you with the correct or best available springs both front & back. Even better is if you spend another $100 - $200 for the fork valving they recommend! Also if in your budget, a properly adjustable shock. - Frame sliders. The above are the basics. Get them done and you will be very satisfied with your ride! Beyond those items you might want to consider: - If you are mostly riding in the city or smaller tracks; change your front sprocket to a 13 tooth and your rear sprocket to a 47 tooth. It will give you increased acceleration in the city to keep up with the little people 250 riders! You'll still be able to do 90+ if you need to but you're at or near redline. If you must commute on highways for much of your riding then probably best not to do this change. - Get some good rubber! Lots of threads here about that! You may need to move this option further up the list if the tires you have ow are original (old) or worn out. - Floating front brake rotor. Enjoy! You've got a fun and very capable machine when used as it was intended! I'd post a picture but this website unfortunately does not let allow simple copy & paste from a device and I don't use online photo servers! That makes me sound like I'm from the Stone Age but in fact it's this web format! Lol! Not that I want them to change it! Cheers! Last futzed with by SLOWn60; September 21st, 2015 at 09:57 AM. |
September 21st, 2015, 07:36 AM | #7 | |
Certified looney toon
MOTM Jul '13, Jul '14
What device are you using? I've been able to attach locally stored files from both my Android and iOS gizmos. The Quick Reply at the bottom of the thread only shows limited functions, but if you click on the Go Advanced button, you'll be taken to a reply screen with a lot more. In the center of the top row is a paperclip that'll let you attach files that will then be stored here on Ninjette. It puts the file at the bottom of your post, but if you want to embed it into your text, all you need is the address where the pic is stored here.
September 21st, 2015, 09:16 AM | #8 |
n00bie to wannabie
MOTM - Nov '15
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
September 21st, 2015, 09:37 AM | #9 |
n00bie to wannabie
MOTM - Nov '15
In my whale costume!
Photo 4.pdf The point being OP; if it can fit me and be a really fun ride: you will enjoy your 250!
September 21st, 2015, 09:59 AM | #10 |
Motorcycle Hypermiler
Join Date: Jan 2012 Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's Posts: A lot.
Gotta agree , the ninjette will work fine for a larger rider like the OP . The stock ninjette gearing should work well. If the stock gearing is not satisfactory it's easy to change.
235 MPG Hypermotorcycling to a better tomorrow |
September 21st, 2015, 10:53 AM | #11 |
I was about 260lbs(18 stones for my mates) with gear, I have since lost about 50 lbs.
I've put about 8k miles on SERENITY, gearing is +1/-2 and no problems whatsoever, local back roads, interstate, etc....
September 21st, 2015, 06:36 PM | #12 |
Join Date: Nov 2013 Motorcycle(s): 08 Ninja 250, 09 650 V-Strom, 07 CRF230F Posts: 42
I'm feeling small at 215.
September 21st, 2015, 07:50 PM | #13 |
ChocolateMilk Addict
Join Date: Mar 2015 Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock" Posts: 329
164... 7 body fat though, so i guess its cool or whatever
< ATGATT > Sweat you can wipe off, Road rash you can't. Burn Rubber, not your Soul. |
September 23rd, 2015, 01:23 PM | #14 |
Join Date: Aug 2015 Motorcycle(s): 2009 250R, 2014 CBR650F Posts: 46
Same here. I'm 235 and loving the little 250. It moves me around much better than I thought it would. I'm a new rider though, so I don't really know what a fast bike feels like haha.
September 23rd, 2015, 01:24 PM | #15 | |
September 24th, 2015, 08:04 PM | #16 |
Well the bike is a project. Since I got it wrecked. But a 2010 with $300 is a good deal to me and by the time I put 1k into the buy it will have everything I need and want. So that's a steal. Has far a riding. I live in the Bay Area. But not the heart. I'm on the edge. I have to be at work at 530am weekdays and. Go against traffic. The freeway has been slimmed down for the last few years due to Bart getting extended so from my house to work is about 50% 2 lane freeway. But I'm able to do 85mph in my bronco so it's pretty clear.
I've been working out at least 5 days a week and I'm slowly dropping down. I'm at 255lbs now and August 31 I was 263. So by the time the bike is ready to hit the road I say I will be at 250-. Also I've never rode a bike before so there won't be any speed coming from me in a while..... I didn't get the bike for speed but to learn and have something around if anyone else wants to learn. I've seen too many thing go wrong and last thing I want to do is get big headed.... So I'm getting replacement forks since these are bent. Should I get a kit to stiffen the springs or add the bigger spacer. Don't want to spend a lot of money...at least not yet
Never rode a motorcycle but own 2 |
September 24th, 2015, 08:42 PM | #17 | |
n00bie to wannabie
MOTM - Nov '15
If I read you right; you're a very new rider. If you're truly just starting out it doesn't matter much how the bike is set up. Try to get an experienced rider that does his own maintenance to give it a once over to be sure everything is in reasonably safe condition including the age and condition of your tires. As i mentioned in an earlier post; i was impressed how well the stock suspension performed given my size. Here's a couple of youtubes from Traxxion Dynamics. The first (about 5 minutes) explains about springs and the second (over an hour but full of gold!) shows you how to measure your sag. Once you know what your springs are doing you can adjust or more likely, replace them with the correct springs for you and your bike. https://youtu.be/aETae3J5jBQ https://youtu.be/f3xdM8E_q-I
September 24th, 2015, 11:20 PM | #18 | |
Freedom for Germany
And after that always remember the most important note from that: "The correct spring is the softest spring available, that is able to support the bike and rider under the hardest of braking/accelerating while still leaving some room for the system to travel if a bumb is encountered in this state." At least nearly everybody here will advice you stiffer springs, but it is also the viscosity of the oil and very important the air gap which can make a (big) difference! Good luck |
September 24th, 2015, 11:20 PM | #19 |
cadd cadd cadd
MOTM - May '15
Holy crap dude!!! What is your inseam??? 50?!?! You make the 250 look like one of those pocket bikes!
September 25th, 2015, 04:52 AM | #20 |
Hey let's not be mean he knows that already.....but thanks you everybody I haven't really but any time in research and never knew how important Nike shocks were...I guess after I put everything together I will really have someone look at it for me
September 25th, 2015, 05:48 AM | #21 | ||
MOTM - June '15
I actually rode mine stock, and it was fine, not perfect, but fine.
September 25th, 2015, 06:06 AM | #22 |
Not an expert on Ninjas, just bought my first one, but I'm learning. A couple of observations (I'm at about 210-220):
1) I haven't pushed it, but my Ninja dives less under firm braking than my previously owned Suzuki SV650, so it's not horrible. 2) The idea of going to a heavier fork oil while you are developing skills is a cost effective first step. 3) For an 07 the spring static length is not a lot longer than the minimum effective length, so no real room for cutting. Don't know about new gen, but the forks are recognized to be much improved. So you may be OK with fork oil. There are a lot of posts on spring substitutes. I decided to go ahead and order Sonic springs to make that part of the bike less "experimental". Have fun with it.
September 25th, 2015, 06:52 AM | #23 | |
That's unusual. It's usually the other way around. |
September 25th, 2015, 07:02 AM | #24 |
cadd cadd cadd
MOTM - May '15
My comment wasn't intended to offend in any way! I'm sorry if it came across that way. He looks like he's 6'5" with a 35" inseam in that pic to me.
September 25th, 2015, 07:16 AM | #25 |
MOTM - June '15
No offense taken, I'm a big dude, I know it. Lol
September 25th, 2015, 07:47 AM | #26 | |
5
I wanted another bike but wasn't sure what I ultimately wanted. Also I had been off two wheels for over two years. I like smaller bikes and had always thought these were interesting. The roads around here are wonderful but speeds are typically 45 - 60 mph, so speed is not an issue. I've been riding since 1968, but still appreciate the appeal of a light bike. I've been eyeing new Bonnevilles, Honda's CB500s, and similar, but this will probably keep me amused for a while at a very reasonable cost. Sorry for the long explanation.
September 25th, 2015, 08:51 AM | #27 |
Honestly, I'm surprised at how many 200lb+ riders are on Ninja 250s. It proves that it's a very capable small bike.
I'm a big fan of small bikes myself. Even though I have 2 SVs I still like the smaller bikes. I also have a Derbi GPR 75cc 2-stroke that I really enjoy riding. Around 200 pounds wet. I steer a lot of new riders to the Ninja, but sometimes the bigger guys (mostly on other forums) don't feel it's enough. I think the number of larger experienced riders that are on Ninjas should tell them something. I'll have to link this thread next time it comes up. Last futzed with by jkv45; September 26th, 2015 at 02:27 PM. Reason: spelling correction... |
September 25th, 2015, 04:55 PM | #28 | |
September 25th, 2015, 04:57 PM | #29 |
I know I was just making a fuss lol....
September 25th, 2015, 08:15 PM | #30 | |
Intrepid Adventurer
He rescued it from my twisted world and transformed it into a beautiful bike. You should get yours rid-able and customize it and build it into something you really love. congrats on the bike.... I would start with the bent forks.... then zip tie the rest. just ot get it on the road while you order more parts! The Ninja is plenty of bike for just about anyone. I want a 300 now. EFI is so nice.
LIFE IS NOT FOR REGRETS OR EXCUSES. Breath deep, seek peace. Embrace the Madness. Life is good, let it be |
September 25th, 2015, 08:36 PM | #31 | |
September 26th, 2015, 05:46 PM | #32 |
Intrepid Adventurer
@Sharkride
You may want to look that frame over very carefully the bike I got I looked it over and did not see anything when I went and got it running I found small little stress marks here and there. And that bike was not crashed to the extent yours was. It looks like yours met a stationary object at speed. ouch. you have a real nice cheap project. Check the forum classifieds for parts. The people on this forum are super helpful with used parts and what not.
September 26th, 2015, 09:36 PM | #33 |
forks bent like that, check and double check the steering mount.
September 26th, 2015, 11:52 PM | #34 |
Man now I'm worried. Now I wonder who I can get to look at the frame. And what is the streering mount?
September 27th, 2015, 09:28 AM | #35 |
MOTM - June '15
Hah, thanks. it went from this:
To this: Using rashed up parts that I fixed and painted so I didn't spend a ton of money.
September 27th, 2015, 05:13 PM | #36 |
its where the forks mount to the bike.
September 27th, 2015, 10:02 PM | #37 |
Yeah I plan on avoiding the plastics and going street fighter. My problems is find forks for a good price. I'm temped to buy a set of 500 forks since they are the same size and I can find them for half the price. Not sure what problems I would run into
September 28th, 2015, 06:54 AM | #38 |
Chances are the lower triple is tweaked with that amount of bending of the forks - I would plan to replace it. I would first pull the tank and look closely at all of the welds and corners in the area around the steering head for any sign of damage. Flaking paint is a good indicator, but also look for hairline cracks.
If you aren't looking for a project/challenge, and just want to ride it, I would stick with a set of original forks. You can easily run into all sorts of challenges if you try to fit a set of forks that "will work". I would plan on purchasing a set of fork springs with a rate closer to correct for you. Sonic Springs would be a good choice. They have a calculator on the site to help you figure out what you need, but Rich Desmond (owner) is very knowledgeable and can help you if you are unsure what would be the best for you. |
September 28th, 2015, 10:44 PM | #39 | |
Another small bike bullying the big boys. | Flying | Videos | 9 | October 19th, 2014 05:50 AM |
[topix.net] - Big boys in action | Ninjette Newsbot | Motorcycling News | 0 | February 2nd, 2013 11:40 PM |
Riding with the big boys!!! | dark_beaverezt | Pictures | 1 | June 28th, 2012 07:53 PM |
My ride with the big boys!! | Wicked808 | Pictures | 16 | February 22nd, 2012 02:11 AM |
[topix.net] - Toys for big boys draw a crowd | Ninjette Newsbot | Motorcycling News | 0 | January 16th, 2011 10:30 AM |
