Old July 11th, 2011, 08:46 PM   #1
miss_connie
~08 ninja 250~
miss_connie's Avatar
Motorcycle(s): 08 ninja 250
Plug, patch or replace?
I picked up a screw in my new front tire (700kms on it) and am getting conflicting info on whether or not to have it repaired or replaced.. I've also been searching different forums n sites trying to find actual facts on blow outs due to plugging the tire and I have not found any facts only "coulds"..
What are your opinions and has anyone here experienced anything negative with a plugged tire on your bike or car?
miss_connie is offline   Reply With Quote
Old July 11th, 2011, 08:51 PM   #2
where, on the tire, is the screw located?
Old July 11th, 2011, 08:52 PM   #3
Jesse8931
Jesse8931's Avatar
Motorcycle(s): 2007 ninja 250r
Plug it.
Jesse8931 is offline   Reply With Quote
Old July 11th, 2011, 08:57 PM   #4
miss_connie
~08 ninja 250~
Just off center..
Old July 11th, 2011, 09:00 PM   #5
I'd say you would be okay to have it plugged. Make sure whoever you have do it does quality work. The plug is only as good as the guy that does the work.
btw, what kinda tire are you trying to save?
Old July 12th, 2011, 02:26 AM   #6
miss_connie
~08 ninja 250~
it's a Dunlop gt501
Old July 12th, 2011, 03:32 AM   #7
Snake
Snake's Avatar
I personally prefer a patch instead of a plug. I have been running with a patched rear tire for approximately 500 miles with no problems.
Old July 12th, 2011, 03:35 AM   #8
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Have it patched. Having a plug put in does further damage to the tire if your hole is small. The hole must be enlarged to make room for the plug which holds a chance of starting some belt separation.
If out on the road sure I would plug a tire, but if I have a choice and can have it patched, then a patch is the way to go. On motorcycles, I consider a plug to be a temporary fix to get me home and then get a new tire asap. I consider a patch to be a permanent fix and use the tire until it needs replaced due to wear.
Old July 12th, 2011, 04:42 AM   #9
HKr1
IC2(SW)
HKr1's Avatar
I dont/wouldnt use a patch/plug on any front tire, car or bike.
Old July 12th, 2011, 08:26 AM   #10
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
But not everyone's a baller like you Kerry
The www.ModMy250.com guy
Old July 12th, 2011, 08:29 AM   #11
Jesse8931
Jesse8931's Avatar
Well Ill take your good tires.
A plug will not hurt your tire but if you can have it patched cheap enough do it. but if not a plug works fine.
Old July 12th, 2011, 09:56 AM   #12
rockNroll
rockNroll's Avatar
Putting a plug in a tire almost always does more damage to the tire. If the puncture/hole is smaller than the reamer, you're doing more damage to the tire.
That being said... the sales guy that sells us our tire repair equipment and supplies drives around in a ford explorer. He has four different brands of tires on this thing, each with about 50 plugs... about 20 of em are right in the middles of the the sidewalls.
Old July 12th, 2011, 10:03 AM   #13
Jesse8931
Jesse8931's Avatar
It does not cause more damage. I know you don't know but my family sells and repairs tires and when plugged by some one who knows what there doing it will be fine.
Old July 12th, 2011, 10:07 AM   #14
rockNroll
rockNroll's Avatar
Don't you usually have to increase the size of the hole in order to install a plug? If you do, then it doesn't matter what skills you have or what you think you might know, you're making the hole bigger. This is more damage. I stayed at a Holiday Inn Express a couple weeks ago.
Old July 12th, 2011, 10:10 AM   #15
Jesse8931
Jesse8931's Avatar
Sometimes the hole does need to be enlarged but for the most part you just cleaning up the whole so the plug sticks good.
Old July 12th, 2011, 10:26 AM   #16
bdavison
Wartown, USA
bdavison's Avatar
I guess a plug/patched tire would be ok for inner city commuting....but if you spend much of your time at 70mph or more on the interstate. Heck no.
Old July 12th, 2011, 10:28 AM   #17
Jesse8931
Jesse8931's Avatar
Why give me one legit reason.
Old July 12th, 2011, 11:02 AM   #18
bdavison
Wartown, USA
bdavison's Avatar
Speed.
Its why tires are rated by speed they are going to be used at. There are no speed rated plugs/patches.
Old July 12th, 2011, 11:18 AM   #19
Jesse8931
Jesse8931's Avatar
You know nothing about plugs or patches. My dyna has a plug and I run it way above 80 and rode it from mi to tn with two plugs in it
Old July 12th, 2011, 12:28 PM   #20
Ramen
Frak It
Ramen's Avatar
I've had a plug in my rear tire for about 4000 miles now. Keep an eye on tire pressure the first couple of days. The bump of the plug will eventually wear down and vulcanize and you'll have to really look for it to find it after awhile, so no worries.
I now keep a set of plugs and a small 12v air compressor under my rear seat.
Ramen is offline   Reply With Quote
Old July 12th, 2011, 12:58 PM   #21
Momaru
Momaru's Avatar
Any notable difference between a standard tar plug and a mushroom-type plug? I was told a while back that the tar's only barely worth using on a moto tire, so I bought one of the Stop-n-Go kits, but have not needed it in the last 15,000mi.
Proud member of the Blue Army
Old July 12th, 2011, 02:53 PM   #22
Snake
Snake's Avatar
+1 I have a patch on my rear tire (500+ miles) and constantly do 75 to 80 on the highway for 1/2 hr or more at a time with no problems. Balancing the tire after the repair is a very important key.
Old July 12th, 2011, 06:06 PM   #23
2011Ninja250R
2011Ninja250R's Avatar
Motorcycle(s): 2011 Ninja 250R SE (Green) Previous bikes R1, Daytona 675, GSXR600, Pre-Gen 250R
Exclamation
Odds are you'll probally not have any problems with a good patch or a plug. Odds also are you'll have absolutely no issues with a brand new tire.
2011Ninja250R is offline   Reply With Quote
Old July 12th, 2011, 06:11 PM   #24
ducducgooseit
Motorcycle(s): ...
I dunno, but it seems to me that the consensus of this thread is that there is no consensus.
ducducgooseit is offline   Reply With Quote
Old July 12th, 2011, 07:06 PM   #25
Snake
Snake's Avatar
So what are you trying to say? Patch/Plug or Brand New Tire?
Old July 12th, 2011, 07:08 PM   #26
2011Ninja250R
New tire- ain't worth taking a chance...
Old July 12th, 2011, 07:09 PM   #27
Jesse8931
Jesse8931's Avatar
unless you hit another screw nail etc
Old July 12th, 2011, 07:12 PM   #28
2011Ninja250R
just my $0.02.
Old July 14th, 2011, 06:09 AM   #29
Floyd had a plug failure, IIRC. First hand forums experience. Could've been the installer's fault, I dunno.
Hit a patch of gravel, lowsided. Sirref !%@*#$%!)@#&!%@ I crashed! 51 April 27th, 2014 07:34 AM
[sportrider - latest stories] - Rebound Damping Adjustment and Plug Patch | Ask the G Ninjette Newsbot Motorcycling News 0 May 30th, 2012 06:10 PM
WTB - Ninja patch treehero6 Items Wanted 1 August 14th, 2011 10:46 AM
[roadracingworld.com] - Thursday Video: It's Not Replace And Ride--It's Replace, Adju Ninjette Newsbot Motorcycling News 0 October 1st, 2009 01:10 PM
